Question about Singer CSP1 Iron
Transfering photos I am trying to tranfer photos on fabric, I have done it before but will not work now, is it the length of time to leave it on? I know it ia high heat. Help me PLEASE.
  • holmes49 Dec 21, 2008
    Yes I have the heat on cotton
    Sergeant:
    Champion:
  • 304 Answers
Hi there may i know if get any error on the unit..?be sure that there was an adequate heat on the machine,.
Posted on Dec 20, 2008
Home Touch clothes Steamer! Won't turn on..
Steam is a tried and true sanitize. And unlike some abrasive cleaners, steam is both penetrating and gentle at the same time. It effectively sanitizes because it can reach high temperatures (above the boiling point of water) in pressurized atmospheres. And, by effectively re hydrating and breaking the bonds of muck and dirt, it's highly effective at spot-cleaning and deodorizing without all that rough treatment. And irons, of course, use steam to work the wrinkles out of fabrics when dryers don't cut it.
Sep 16, 2017 | Irons
How can I clean the plate of my Oliso pro. It has wonder under on it
get the iron hot. Take a piece of fabric and a dryer sheet. Put the dryer sheet between two layers of fabric. Place this at the edge of your ironing board. With the iron hot, run the sole place over the "fabric/dryer sheet set" several times. This will remove wonder under and many other adhesives from your iron.
May 31, 2016 | Oliso Tg1600 1800 Watts Smart Iron Pro
My GS23R fabric steamer does not work.
Time to return under warranty. There are no user serviceable parts.
Nov 06, 2014 | Conair GS33R Compact Fabric Garment...
Why When I press it leaves brown spots
Try running a mix of water and vinegar through your device to clean the steam pathways. you can also try C.L.R the same way.
Jun 20, 2014 | Singer Electronic Steam Press
Clogged steam holes
If the approved cleaning procedure does not work, your Rowenta iron may have failed.
Jan 09, 2014 | Irons
How do you remove melted plastic ironed into fabric
Did you try a ice cube or goo be gone you can get it at walmart.
Dec 25, 2012 | Irons
The top plastic piece that runs the length of the top of my Rowenta DE 831 broke. Can I get a replacement part for this? Can an exploded view of the parts be obtained, or a manual? Thanks.
Only if you check up with Rowenta this part will be available but if you can search around in service shops you may be able to salvage one from a coil damaged iron that was discarded.
If not fabricate the top with a fibreglass or plastic repair shop and it can be doe to suit the top after a paint job.(If broken use good glue and then paint on top)
Aug 31, 2010 | Rowenta DE851 Iron
My iron smells bad and transfers the smell to clothing. I have had my iron for 10 years and love it, but my housekeeper left water in it.
Hey, You have a "Mildew" issue. Just like leaving clothes in the washer too long before putting them into the dryer. If you read your iron's manual, it is recommended to use "Distilled" water...not tap water. Tap water has impurities...Distilled water does not. Here's the fix...MAKE SURE YOU ARE HOME WHEN YOU DO THIS! Get distilled water (From Grocery Store) Mix 1/2 cup distilled water with 1/2 cup vinegar. Put this into your iron and leave it on. To help it along, push the "Steam" button frequently. You can do this several times...the acid in the vinegar will clean out the residue. Once this is done, fill the iron with water, add a couple of drops of lemon juice and you'll be good to go. I know this to be fact...just did it myself : )
Jun 16, 2010 | Rowenta DE851 Iron
What is the temperature of the synthetic setting?
I would use some scraps of fabric and transfers to do some trial and error experimenting.
Keep in mind that the iron will not produce steam until the internal temperature is 212 degrees farenheit.
good luck with this.
Jan 06, 2009 | Rowenta Professional DM890 Iron with Auto...
Singer CSP1 Iron Logo
Top Singer Irons Experts
Chance Miller
Are you a Singer Iron Expert? Answer questions, earn points and help others
