Remote wont work with the unit but both work on its own
Hello i have a panasonic sc-ht540/sc-ht990 home cinema system, all of a sudden the remote stop working, took the remote to the shop and they tested it and said the remote is ok. the unit works on its own but not with the control
What is "F61"
Posted on Dec 07, 2010
Fault code fg1
If it's a panasonic the number are f61 and means the audio amplifier's IC's are damaged and need to be replaced
Feb 02, 2010 | Audio Players & Recorders
Repeated F61 fault code on Panasonic Home cinema system Model: SC-HT990 Is it the fan in the sub woofer?
Hello
F 61 error means the failure of FAN
most probably dust in the fan made it to stop working so clean the dust and connect the fan to an external supply of 12v(using red and black wire) for 5 minutes and reconnect it to the unit otherwise replace the fan with new one.
Surely this will solve the problem.
Kind regards
Andrea
Dec 12, 2009 | Panasonic Home Theater System System
NOISEY FAN
You may need a new fan, but you can try cleaning the fan. Remove fan from player. use a few drops of WD-40 or another similar lubricant, the fans label may need to be removed. Note Panasonic fans must be rotating or f61 code will appear. Hope this helps.
Jan 10, 2009 | Panasonic Home Theater System System
NOISY FAN ON PANASONIC SC-HT990
you cant stop it, the fan is going bad, it isnt verry expencive, you should be able to order from there website, i wouldnt hold off verry long, if it is going out, it isnt cooling your reciver correctily, and could cause other damage
No picture on TV through Sky, Home Cinema is on but have sound.
do have sound and picture at same time you will need a fibre optical cable, you connect that from your cinema system to your tv. then you need to set your cinema system to digital input or fibre optic or check by pressing aux on your remote and see which is the right one. i am not familier with panasonic as i have samasung.
Dec 10, 2008 | Panasonic SC-HT75 System
Error Message F61
Hi guys,
just had the f61 error code on my home theatre system, now i work with samsung dvds and tv's so the background knowledge is there ( i hope), i dont know if u guys noticed the fans making a noise whenever you switched it on before the fault happened but mine were making a hell of a noise, this prompted me to have a look inside and find 2 fans both of which were very dusty, just a 10 minute clean and a 10 min reassemble and im back up and running on all channels.
hope this helps guys
Aug 08, 2008 | Panasonic Home Theater System System
Unlock panasonic sc-rt 50 home theater
theater sound system sa ht540 region hack
Mar 18, 2008 | Audio Players & Recorders
F61 code on SA HT540 system
i think it means that the cooling fan is faulty.
cheers Mark
Jan 06, 2008 | Lands Phones
PANASONIC Home cinema SC-DT100 - Flat cable connection
Hi, when you say it doesn't work, will it just not play/read the disc? Mine has to be "initialized" every time or it shows "No Disc". To initialize I turn the unit on then press and hold "Stop" on the unit and the "10-" button on the remote, then it works fine.
Aug 01, 2007 | Panasonic SC-DT100 System
132 people viewed this question
 Grubhead
Grubhead
