Question about Epson Stylus Photo R220 InkJet Printer
Dear sir , i have a epsonstylus r230 photo printer,i am getting blank prints from my r230,pleas solve my problem,printhead was new insttaled
  • gooo14n Feb 05, 2009
    yes i have same problem after change new headprint. printing paper blank please help thank you
  • ANKITA665 Feb 16, 2009
    dear sir , i have a epsonstylus r230 photo printer,i am getting blank prints from my r230, i try to
    ssc and replace in the printer menbord,power supplyer,contect steeps and head by other printer.but i am getting blank prints from my r230.please solve this problem.
    Problem Solver:
Dear sir , i have a epsonstylus r230 photo printer,i am getting blank prints from my r230, i try to
ssc and replace in the printer menbord,power supplyer,contect steeps and head in other printer.but i am getting blank prints from my r230.please solve this problem.
Posted on Feb 16, 2009
    New Friend:
  • 3 Answers
In case anyone else runs across this, the problem is caused by a blown fuse on the main board. It is labeled F1 and it is near the 3 tall blue capacitors. If you have a meter you can check across it,if it reads anything more than a couple of ohms it is bad. This is a fast acting 2.5A fuse. You can get a fuse and fuse holder at on line or at your local Radio Shack or similar store. I know the 230 is the European/Asian version so I don't know if you have something like a Radio Shack. The R220 is the US version and it is identical.
You can jump it out but this is not recommended. If the fuse is not there, you could cause more expensive problems later.
Posted on Jan 21, 2014
Dear sirs , i have a epson stylus r230 photo printer,i am getting blank prints from my r230, its has new replaced print head, new data cables and i even tested labeled F1 and it is near the 3 tall blue...
take all cartridges out shut off then turn on make surethere is no obstructions where cartridges go replace them one at a time i found a piece of tape on mine would not print black and white removed it now it is fine
Jan 23, 2015 | Epson STYLUS R230 InkJet Photo Printer
How do i solve the misfeeding of my epson r230?
epson r230 print double edges printing result very bad please give me how o solve this problem.
thanks.
ashok kumar
Jun 14, 2010 | Epson STYLUS R230 InkJet Photo Printer
My new epson r230x printer is printing text and images blur
pls download the latest drivers software version of the printer that you use... then after that reinstall the old drivers software that you install previously.
Mar 02, 2010 | Epson STYLUS R230 InkJet Photo Printer
Epson photo stylus R230 prints blank
I think you are in a hardware problem. In this situation you may try to set up a seringe in to a pipe that are in the back side of the printer.to find the pipe follow the mentioned procedure
1. (in off line position)open the scrue that are situated back side of a printer
2. push the cover and
3.find the plastic pipe into the blank space
4.Then set a sering in to the pipe and try to out ink by presure. 5/6 time.
if your printer stil not print, the mother bord of the printer should damage . change the mother bord and it will work fine.
Dec 13, 2009 | Epson STYLUS R230 InkJet Photo Printer
My printer Epson Stylus PHOTO R230 does not print
The printer does not print only dragging a paper without printing.
3 option to solve
make sure your
1. heads are working
2. flex cable connecting the heads
3. main board
Most common that i found is to replaced the main board. or replace parts of other main board if you have some extra. hope it can help.
Jun 29, 2009 | Epson STYLUS R230 InkJet Photo Printer
Printhead error
Print out empty? Normal run? replace print head? If no mistake installed print head, the problem at board, or may be just lost electricity.
Jun 07, 2009 | Epson STYLUS R230 InkJet Photo Printer
Blank paper print in R230
try checking the pump assembly of the unit. if it is clogged, the printhead wont clean and theres a possiblility that you will not get a printout. also check the head cable to see if there are no cut traces.
Feb 18, 2009 | Epson Stylus Photo R220 InkJet Printer
My Epson Photo R230.....did not print anything ...I already clean it for more than 10 times.....what should i do.....? please help
HI
Chances are the nozzles are clog and printhead needs replacement, you can have this service, but i'm suggesting that you get a new one instead. you can call epson and they will offer you a discount on a new printer.
Hope this helps
Nov 29, 2008 | Epson Stylus Photo R300 InkJet Printer
Service required for EPSON STYLUS R230
http://www.efillink.com/Support/HowToWasteInkDrainR200.html
Sep 25, 2008 | Epson Stylus Photo RX700 All-In-One InkJet...
Epson Stylus Photo R220 InkJet Printer Logo
343 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
