Question about Konica Minolta DiMAGE Z10 Digital Camera
Focus i have a dimage z10 when it focus in manual mode or auto it is blurry. i believe it may be in the setting? any suggestions would be helpful.
  • 944 Answers
Here is the link to the user manual if you need it; http://support.asus.com/download/download.aspx?SLanguage=en-us Check page 24 - focus lock feature Check page 35 - focus macro mode Check page 111 - blurred photo troubleshooting Hope this helps, if you still have problems please post again :)
Posted on Mar 31, 2007
SOURCE:
It doesn't allow me to take a shot. On a lense itself, there are two settings A and M. When it it is on M it takes a blurry shot, but on A setting doesn't allow. Please, help me.
M means Manual Focus. If you set the lens to this then you need to turn the lens manually to get it into focus.
A means Auto Focus and when the lens is det to this it should focus automatically but you need to set the mode button OFF Manual. It should work on any other setting.
Jul 05, 2011 | Cameras
All the pictures are blurry the auto focus isn't working
You may have put the camera on manual focus. Two ways to do that.
1. There is a switch on the lens which allows you to select auto or manual focus. Be sure the switch is set on A or A/M. If it's on M, you are on manual focus.
2. In you menus, there might be a mode which is manual focus. Look in your manual index under Focus, manual. There might be a setting in the Focus Mode menu.
You can also try resetting your camera. This will put most things back to factory default mode, including the focus mode.
When playing around with controls, go step by step through the manual and try things out. Be sure to set the control you were playing with back to default unless you really understand that setting.
Apr 11, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
There's something wrong with the focus of my camera. Everytime I take a picture it's blurry and it won't focus unless I zoom in. Is there a way for me to fix it?
ensure finger is not covering auto focus.
ensure camera is not in macro setting. look for icon like a flower this is only for close up shots and will cause bluring if subject is too far away.
check that camera is set in auto focus and not manual focus mode if it has this.
I hope this was helpful.
Jan 24, 2011 | Canon PowerShot SX210 IS Digital Camera
I just gor my Konica Z10. I wanted it because I wanted that oldfashioned viewfinder. When I look thr it is dark, blurry and I can handrly see the secenery. Why is that. Does it need adjusting.
Page 17 of the manual explains how to send the image to the viewfinder instead of the screen. Also, you can adjust the diopter dial to suit your vision.
Dec 16, 2010 | Konica Minolta DiMAGE Z10 Digital Camera
Zoom stuck and will not focus
Check to make sure you have not inadvertently set the camera into manual focus mode. Many cameras have 2 modes: auto focus and manual focus.
Jul 18, 2009 | JVC Everio GZ-MG155 Camcorder
Built-in Battery
get new battery put it in camera and set settings again, but first try charging the battery, this might be all it needs, hope this helps.
Aug 01, 2017 | Konica Minolta DiMAGE Z10 Digital Camera
Operator Manual
For a Konica Minolta DiMAGE Z10 Digital Camera is available here.
Hope this be of some help. Post back how things turned up or should you need additional information.
Good luck and kind regards.
Nov 07, 2007 | Konica Minolta DiMAGE Z10 Digital Camera
Photoes are not sharp
Hi, I have never had focus problems with my FX7. I suggest you set the AF mode to 1-area-focusing. This mode is quicker than the 9-area-focusing. To eliminate any possibility that the blurry photos are caused by camera shake, I also suggest placing the camera on a tripod (or setting it down on a flat surface) and using the self-timer to release the shutter. At this point you can also turn off the image stabiliser. A well lit outdoor subject is probably preferable for this test, as low contrast scenes sometimes cause the auto focus problems. If the photos under these conditions are still blurry, then you probably have a defective autofocus. Otherwise...
Sep 04, 2005 | Panasonic Lumix DMC-FX7 Digital Camera
Konica Minolta DiMAGE Z10 Digital Camera Logo
158 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Damen Wong
Damen Wong
 Larry
Larry
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
