Apple Ipod Classic 7th Generation Silver 160 Gb latest Model Grade B Logo
Tom Ketchum Posted on Aug 18, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Deleting songs from i pod 7th generation - Apple Ipod Classic 7th Generation Silver 160 Gb latest Model Grade B
Anonymous
Level 3:
Top Expert:
  • Master 4,961 Answers
  • Posted on Aug 19, 2012
Anonymous
Master
Level 3:
Top Expert:
Answers
4961
Questions
0
Helped
1186389
Points
16069
1helpful
Ipod will not advance to next song. It just keeps playing the same song over and over.
Check the playback settings. Present setting may be to repeat single song.
2answers
Delete songs from i pod touch 2nd generation
You must connect to the computer with iTunes. There you can select the music you want t delete.
For that wait till the iPod is backed up by iTunes, then on the left side click on the line with the name of your iPod. Then on top click on Music and then you see what music you can synchronise.
If you already did remove the original backups from the music on the iPad, there is a chance iTunes all remove all these numbers.
Apple has lots of info about every part you want to know about your iPod and iTunes.
3answers
How do i delete duplicated photos on ipod Nano 7th gen.?
To remove duplicates songs from iPhone/iPad/iPod, you get 2 methods. The first one is to make use of iTunes, while the 2nd one is making use of 3rd-party duplicate remover tool. Below guide explains how to delete song duplicates from iPhone/iPad/iPod with a powerful 3rd-party program easily. There recommend Leawo Tunes Cleaner. Leawo Tunes Cleaner is a Windows-based professional iTunes cleanup program that could help you fix your iTunes music library and other music folders by adding song tags and removing duplicate songs. It could act as iPhone duplicate remover, iPad duplicate remover, iPod duplicate remover and iTunes duplicate remover to help you easily find and delete duplicate songs for iPad, iPhone, iPod and iTunes in clicks. First, download Leawo Tunes Cleaner ' Leawo Tunes Cleaner for Mac and install it.
Step 1: Launch Leawo Tunes Cleaner
Download, install and open Leawo Tunes Cleaner. Choose the "Clean-up Duplicates" option on the main interface.
Step 2: Set scanning mode
Select a duplicate scanning mode to detect duplicate songs in your iTunes from Quick Scan and Deep Scan. Quick Scan mode is based on song tags including name, artist, album, file size and time, while the Deep Scan mode adopts Acoustic Fingerprint tech for deeper scanning. Choose the desired one.
Step 3...
For more information: 2 Best Ways to Delete Duplicate Songs on iPhone/iPad/iPod
3helpful
7th generation ipod nano has no sound
Hi Katherine
Try this solution to your problem...
Turn on Ipod, on the left hand side there is a volume
control switch. While you are on a song, hold the top of the
volume control switch to increase the volume.
If that does not work then go to "Settings". then
"music" and make sure your "Volume Limit" is
set to "Off", if it is not then touch "Volume Limit" and set it
to "Off"
Please do not forget to rate me
Bud
2answers
How do I delete songs from my ipod from a usb port on a computer?
First plug your i-pod 1st generation into my usb port on your computer.
Then download and install Sharepod. when the it appears right click the selected song and delete it, in the main menu
1helpful
3answers
How do i delete songs from my ipod nano
To remove songs from a playlist on the iPod nano, you typically have to have it docked and connected to your computer.
To remove a song, video, or other item from iPod nano:
  1. In iTunes, select iPod nano in the source list.
  2. Select a song or other item on iPod nano and press the Delete or Backspace key on your keyboard.
Computer says songs are there iPod says there not
your ipod will not function properly with windows media player. it may play the music but it won;t get functionality from the ipod.
You have to use iTunes to get your ipod straightened out. Once you mount it on iTunes you will see the music and be able to add music and delete music.
20GB IPOD
maybe...perhaps try changing your itunes setting
to
"manually update ipod" if it is set to autosync then all tunes in the library which are registered as being on the pod will automatically update. each time you connect the pod the itunes sw will update the pod from the library.
when the pod is connected and auto sync is active if you delete a tune from the lib it will update the pod and delete the same tune.
Downloading music
make sure u have the latest i-tune soft ware and connect the the i-pod to teh pc>and automatically the soft ware decet teh i-pod and u will see the i-tune page and click on auto fill tab u can see on the bottom of the screed>and its automatically upload all the songs from pc rate me solved if its fixed even in teh screen u can upload songs under add files and folders its in teh left side top
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
