Question about VIA C3, 1 GHz (5na00m11q-bwt6a) Processor
Rebooting i am using via p6vemd 1gzh processor with 128mb of ram . my perating system is windows xp professional. my system reboot at any time while im doing anything. especially when i insert an cd into the cd-rw.
  • 624 Answers
Random rebooting, without know the history of your PC all I can do is give you a list of things to try and look for. The first thing I would do is check the basics, if that turns up nothing then the only option left is to removing variables one at a time. Obvious things to look for: - Physically remove and clean the processor heat sink. Make sure the area directly underneath the CPU fan is clean of dust; you have to remove it usually to make sure. When you reattach the heatsink take the opportunity to clean off the old and reapply new thermal grease. Use sparingly to ensure excess material doesn?t get on the CPU pins or the motherboard. - If you have a video card with its own heatsink and/or fan make sure it is free of dust. Make sure the fan runs freely and forcefully. It usually takes a can of compressed air to clean the dust underneath the fan, in some cases it requires disassembly. - Make sure all connectors are snugly plugged into their sockets. - Make sure all cooling fans, especially the power supply are running smoothly and forcefully. - Vacuum out case air vents and blow out dust from all secondary heatsinks and around the memory modules. - If your computer is plugged into a power strip or UPS try plugging it directly into a tested wall socket. - With the computer running try wiggling where the power cord plugs into the PC and the wall socket. If nothing turns up the next step is to make this computer as basic as possible. Disconnect any secondary drives, all USB devices, hubs, ports, printers anything you can remove and still have the PC boot. Don?t assume something couldn?t possibly cause this, making assumptions works against you. Run the machine in the basic mode and see if the problem persists. If it doesn?t don?t assume its one of the things you removed, replace the items one by one remembering it could be a power problem that only manifests itself when lots of stuff is plugged in. If the problem persists try these one at a time: - Typically your system BIOS will have a safe or factory reset mode, set it to that making note of the setting you had originally. - Try removing the hard drive and boot via a CD (Windows install or a diagnostic disk will do). - If you have a plug in video card try using the motherboards built-in video or another know good video card. - Test or preferably replace your power supply with a known good supply. - Try new memory. - At this point we?re probably left with just the processor and motherboard which means unless you have spares around you?ll need to start considering if its time to upgrade to a new motherboard and/or processor. Also if you haven?t done so already you should immediately backup (and test) your important files stored on your computer. The random shut downs are dramatically increasing the chance your hard drive will suffer damage or data corruption. I hope this helps but let us know if you have any other questions and please don?t forget to rate this post.
Posted on Mar 31, 2007
Windows Exsplorer has stopped working
Try control-alt-delete and use the task manager to end task for windows explorer, then use the search box bottom left to run explorer.exe to reboot windows explorer, worked for me when a computer full reboot wouldn't
Jan 19, 2016 | Microsoft Windows 7 Professional Upgrade 1...
What is the best motherboard and system configuration for adobe premiere 6.5 and pinnacle pro on rtdv ? I need the configuration in details please..... Please, thanks, Mack
TECH SPECS for ADOBE PREMIERE 6.5
Minimum System Requirements
Windows
  • Windows 98SE, Me, 2000 (SP2), or XP
  • Intel PIII 500MHz
  • 128MB RAM (256MB or more recommended)
  • 600MB HDD space for installation
  • CD-ROM drive
  • QuickTime 5.0 recommended
  • Microsoft DirectX certified FireWire
  • dedicated large-capacity 7200RPM HDD
  • For Real-Time Preview:
    Pentium III 800MHz processor (Pentium 4 dual processors recommended)
    Macintosh
  • Mac OS 9.2.2 or Mac OS X v.10.1.3
  • PowerPC G3 (G4 or G4 dual recommended)
  • 64MB RAM (128MB or more recommended)
  • CD-ROM drive
  • QuickTime 5.0.2
  • QuickTime compatible FireWire
  • large-capacity HDD capable of sustaining 5MB/sec
  • For third-party capture cards:
    Adobe Premiere certified capture card
  • For Real-Time Preview: G4 processor (G4 dual recommended)
  • Jun 27, 2011 | Pinnacle Pro-ONE RTDV Video Capture
    Is 512mb run only in windows xp?
    XP, when it first came along, needed 128MB of RAM. That was Microsoft's recommended minimum, and XP always worked better with more. But it would run with only 128MB, and that's all many systems were sold with. Memory was still pretty expensive.
    So, yes, XP will run in 512MB.
    Jun 20, 2011 | Microsoft Windows XP Professional
    My PC has D101 GGC INTEL motherboard, and 2.66GHz Intel P4 processor and DDR SDRAM 1GB. My system starts but hangs very frequently and is extremely slow. Sometimes it doesnt boot and usually takes very...
    when booting long press the delete button to enter bios, when your in, select the boot section and disable quick boot, then save and reboot, bios will check the memory or ram of your desktop.
    after the test when the system reboot the same and didn't said ram fail or test fail the ram is working good.
    now I'm sure that your running out of memory or lack of memory,
    try to clean up your disk or delete unused files, or update the memory
    probably your ram is ddr 1 pc333/400
    Mar 21, 2011 | Intel D101GGC Motherboard
    I have this old laptop and its called a compaq (presario 2500) well yesterday i brought the sims3 game for it because the laptop dosent have internet. When i installed the game it says windows xp has to...
    Thanks for using fixya.
    My name is Carlo.
    Your computer might not pass the system requirements that's why it has an error. Or, you can try installing it one more time and check if it will work. Computers do mess up sometimes.
    Here's the system requirement of SIMS 3:
    Desktop PC (Windows XP + SP2):
    CPU: 2ghz Pentium4 Processor or Amd Athlon 2000+ Processor
    RAM: 1 GB of RAM
    GPU: 128mb Video Card (GeForce FX 5900 or Radeon 9500)
    Desktop PC (Windows Vista + SP1):
    CPU: 2ghz Pentium4 Processor or Amd Athlon 2400+ Processor
    RAM: 1.5 GB of RAM
    Laptop (Windows XP + SP2):
    RAM: 1.5 GB of RAM
    GPU: 128mb Video Card (GeForce Go 6200 or Radeon 9600)
    Laptop (Windows Vista + SP1):
    RAM: 2 GB of RAM
    Read more: http://pc.ign.com/articles/939/939410p1.html#ixzz10TQHijZi
    IF your computer does not pass the system requirement, then you cannot play sims3 in your computer.
    I hope this helps. Thank you for using fixya
    Please leave your comment and ratings. Thanks
    CARLO
    Sep 24, 2010 | Computers & Internet
    Need to reboot my crashed computer cant get windows xp to reboot
    HI how are u, ur Windows Xp is corrupted
    Cause :
    1. Viruses
    2. Computer was not Shutdown properly
    3. Some windows File Corrupted
    Solution>>>>>>>1.
    1. Go to Safe Mode at starting mode press F8.
    2. If Computer Go to safe mode successfully>>
    3. Go to start >> Programs>> Accessories>>System tools>>System restore.
    4. Restore ur computer in privious date.
    Solution>>>>>>>2.
    1. Insert WIn xp cd in cd rom and restart it.
    2. Repair Your win Xp via a Repairing utility.
    Solution>>>>>>3
    1. VIa a formmating utility U can install a new fresh copy of windowxs.
    Thanxs
    Mukesh Kumar
    Mukesh_ibm@yahoo.com
    May 12, 2009 | Microsoft Windows XP Professional
    Unable to reboot windows xp professional, even with disc in.
    try changing your memory module. had this problem once and i changed my ram then viola its fixed
    Nov 19, 2008 | Dell Precision 530 Minitower 2.4Ghz...
    Windows aero glass
    GO TO WINDOWS 1ST FOR UPDATES, DOWNLOAD INSTRUCTIONS, REQUIRES YOU TO UNINSTALL, REBOOT, REINSTALL FROM REBOOT. PRINT DIRECTIONS FOR APPLICATION OR IF YOU HAVE ACCESS TO ANOTHER COMPUTER ITS EVEN BETTER.
    Oct 24, 2008 | Microsoft Windows Vista Ultimate Edition
    Booting problem
    RIGHT Click...
    My Computer
    From the menu choose Properties
    Click the Advanced tab
    Click Startup and Recovery
    Under the system failure area take the check OUT of the box that says Automatically Restart.
    Windows XP sucks on 128MB, get yourself more memory, go to 1 Gig.
    Your problem could also be hardware such as a power supply so re-comment if the suggestion did not work for you.
    **Please add a comment before giving a rating other than Solved
    Oct 18, 2007 | Microsoft Windows Xp Home Edition Sp2...
    VIA C3, 1 GHz (5na00m11q-bwt6a) Processor Logo
    233 people viewed this question
    Top VIA Computers & Internet Experts
    Abhinandan  Patil
    Abhinandan Patil
    XXXX
    Level 1 Expert
    mark gardner
    mark gardner
    Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
