Question about MSI 865PE Neo2-S Motherboard
I am having problems installing xp on MSI865PE Neo2-S, I am now at BIOS, how do I get my computer to boot from the boot disk?
    Scholar:
  • 174 Answers
You have to select the boot order anf the first boot device should be floopy drive then save and exit from bios
Posted on Dec 19, 2008
Can't install windows on FSB 800 motherboard its showing no hard disk installed in your computer but showing in the bios kindly help
If you are installing XP on a SATA hard drive then -
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Mar 18, 2013 | Computers & Internet
Tip
INSTALLING WINDOWS XP ON A SATA HARD DRIVE
SATA HARD DRIVE ? XP INSTALLATION
The FIX.
If enabling the SATA in the BIOS does not allow the computer to boot up with SATA hard drive then change the BIOS back to what it was previously.
on Mar 14, 2010 | Computers & Internet
XP will not install "Setup
That is because it was designed for Vista not the obsolete XP. There are no hard drive drivers suitable in XP.
Re install Vista or install Win7.
Hope that helps.
Jan 22, 2011 | Computers & Internet
When switcthing on my Advent netbook it comes up with the error message Windows Boot Manager Windows Falied to Start. A recent hardware or software change might be the cause. To fix the problem: 1....
Hi sioban_bros,
Based on your situation. I suggest trying the following steps:
1. restart the computer and keep pressing F8; Use Last Known Good Configuration.
2.If the issue still occurs after that, I suggest testing if we can boot from a Windows XP disk. If so, please install Windows XP on another partition and access your important data.
3. After backing up those data, you can use Windows XP disk to format the drive and reinstall your preferred operating system.
4. However, if we cannot boot from a Windows XP disk, the issue can be caused by incorrect BIOS settings or damaged hardware. I recommend contacting your computer manufacturer to check BIOS and hardware.
To access the data on the drive, you can try to install the hard drive on another computer.
Hope it helps.
Please rate this solution if found useful.
Best regards,
Reyjoshua07
Jan 17, 2011 | Advent Netbook
Ethernet LAN not detect
Hello download the lan driver from here:
http://www.msi.com/product/mb/865PE-Neo2-P-Platinum-Edition.html#/?div=Driver&os=XP%2032
Try to renew the driver and install the new one.
And check your bios settings for the lan.
Good luck
Jun 02, 2009 | MSI 865PE Neo2-PFS Motherboard
Reboot
To Reboot a computer is to turn it off, wait at least 20 seconds, then turn it back on.
A.If you're thinking of Reboot, as to reinstall the Operating System, you use a Restoration Disk, (sometimes listed as Recovery Disk), insert it in your CD/DVD drive, and restart your computer.
(Just press the CTRL, ALT and Delete keys AT THE SAME TIME.
Not shouting. Windows XP and Windows Vista are examples of an Operating System)
B.If you're trying to install an Operating System, from a CD disk that you bought, I suggest you go into BIOS Setup, and in Boot Order, change the first boot device to CDROM. Insert the CD disk in your CD/DVD drive, and restart the computer.
If you buy a Full Installation CD disk, as listed above, you have to change the Boot Order.
For example:
1.You have Windows XP on your computer now. It has problems, and doesn't work correctly. Instead of getting the Restoration Disk from your computer manufacturer, you decided to just buy a genuine copy of Windows XP, and install it. (This is a Full Installation Disk)
The Windows XP you have installed now, will not let the one you bought install over it, by just putting the disk in the drive. Change the first boot device, in Boot Order to CDROM, and it will. The Windows XP you have now, will 'see' the Windows XP you're trying to install, as just the same version. You have to install a better version of Windows, in order for it to write over what is installed.
Such as Windows Vista.
2.You have Windows Vista on your computer, and are not happy with it. You would like to put Windows XP on instead. Windows XP is considered a lesser version, and Vista won't let it write over it.
Go to BIOS Setup, change the first boot device in Boot Order, to CDROM, and it will.
May 10, 2009 | Compaq Presario R3000 Notebook
Motherboard stop recognize SATA HDD after BIOS reset (default)
You'll likely need either a driver disk for your SATA drive to be recognized by Windows XP during installation or Windows XP with Service Pack 2 built in to install without a driver disk.
Creating a Windows XP installation CD with Service Pack 2 or "SP2" built in is fairly straight forward. This is called "slip streaming". Step - by - step directions can be found in the following links:
http://www.google.com/search?q=slipstream+sp2+windows+xp&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a
Mar 27, 2009 | MSI 865PE Neo2-V Motherboard
Installing windows without DVD
The hard disk is not recognized from USB because of SATA drivers not present on XP setup disk.
That happens because the BIOS uses a SATA controller that is not included in Windows XP install disk.
Usually you can solve the problem going to BIOS settings and changing SATA/RAID settings.Check your BIOS settings, and disable SATA RAID mode.This is done in different ways depending on the BIOS.
On HP/Compaq computers for example you press F2 on startup to enter BIOS, then disable SATA mode on bios settings.
On other makes the procedure can be slightly different.
Another way to fix the problem, is by creating your own XP setup disk with SATA drivers included, see:
Resolving "Setup did not find any hard disk drives" during Windows .
Mar 17, 2008 | Toshiba Portege M205-S810 Tablet PC
MSI 865PE Neo2-S Motherboard Logo
82 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
