Question about Kenmore 30169 Electric Single Oven
F5 error on a Kenmore Gas Oven
My Kenmore 24" gas built-in oven shows aa F5 warning when it reaches the set temperature. I can turn it off and let it cool for a while, but when I start it again it does the same thing when it hits the set temp. The unit is old and I really don't want to pay for a costly service and repair charge. Is this something that I can repair on my own and is it expensive to buy the part? Thanks, John
  • john zink Apr 01, 2007
    Thanks for the reply repmanthe.
    I don't know way the door would need to lock if I am only heating it to 350 degrees, though.
    I am experiencing the problem under normal baking, and not during self cleaning.
    I will look to see if I can see any visible problem with the locking mechanism.
    Thanks again,
    John
We have a 24 inch propane gas oven by kenmore. All of a sudden the oven is not turning on when you press the start and bake or broil buttons. It seems it is not getting the gas to ignite or the signal to let the gas in. Code is F5. Model number is 91130168.
Please help as it is just too costly to call service people to a small town from the city.
Thank you!
Posted on Jul 08, 2008
  • 3 Answers
F5 is a door lock code there is a problem with your door latch. its should lock the door at a crtain temperature and its not.
Posted on Apr 01, 2007
Maytag 24 " wall oven gas trouble code F5
Hi ngwhite,
The trouble code F5 is a Watchdog and hardware conflict. You need to replace the clock (ERC).
Hope it helps.
Thank you for using FixYa.
Aug 02, 2010 | Maytag 24" Built-In Single Gas Wall Oven -...
Error code F3 and F5
Hello there:
Here is the code for these 2 codes hope they are very helpful for you
F3
Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC)
Feb 04, 2010 | Maytag CWG3100A Gas Single Oven
When i turn on bake i first smell gas then the burner goes on and off eratically and takes a long time to reach the temp model#fgb557cesd
Part #37 on diagram #3 will show the temperature probe that needs replacing.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=111385&diagram_id=232775#d232775
Jan 01, 2010 | Frigidaire 24" Built-In Single Gas Wall...
Getting F4 error
I dislike new electronically contolled ovens so much. Electronics are never meant to be near temperatures reaching more then 200 degress.
F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor
Aug 01, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
We have a gas maytag gas wall oven that is getting f3 and f5 error codes
F3
Shorted or open oven temperature sensor (RTD)
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
F5
Replace clock (ERC).
Jul 17, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
Maytag gas oven wont restart after pre heat
you have a bad oven sensor /faulty connection or bad control board.look for probe coming thru inside rear wall.should read 11k ohms cold.go bad a lot part number Hope this helps ,please rate my response :)
12001655
Jun 25, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
When cooking will get an occasional f2 or f5 error code
HI, This seems to be another ERC issue. the temperature sensory circuit is malfunctioning. the oven will not operate while this condition exist within the ERC. This malfunction will allow your oven to over heat and may cause a fire. The second issue will be that the relay drive circuit is malfunctioning as well. If you cant cancel the error code and continue with normal usage, you will have to replace the ERC once more.
Please rate and god bless:)
Apr 05, 2009 | GE 24" Built-In Single Gas Wall Oven
F3 and f5 error codes on maytag gas wall oven
(((F-3)))
This is a Shorted or open oven temperature sensor (RTD). Check the following.
(((F-5)))
This is a Watchdog and hardware conflict.
This is not repairable. you will need to replace the control board or (erc)-(clock)
Feb 24, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
Kenmore 30169 Electric Single Oven Logo
504 people viewed this question
Top Kenmore Ovens Experts
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
