Question about Sony Ericsson S710
Sony Ericsson s710a
Hi, my phone will not recognize my home or car charger.What can i do?It will not charge at all.
2 Suggested Answers
  • 995 Answers
SOURCE: my sony ericsson w995 does not charge when i try
That only means that you got battery problem of your phone. Replace the phone battery with a new one. If your old sony ericson phone battery can be fit to your w995 then you can try to use it.
Hope this could help..
Posted on Mar 28, 2010
  • 6993 Answers
SOURCE: hi i'm having trouble charging
I think you have asked this question previously.......... Same answer.
The charging port of your phone should be the cause of the problem. It's either the charger is not contacting the charging port well enough or the charging port might be defective and needs to be replaced.
Use a pin to scratch the surface of the charging port and try again. If that doesn't work, then know for sure that you will have to replace the charging port.
If you feel you can do the replacement yourself let me know when you get a charging port replacement so that I can direct you.
Good luck.
Posted on Mar 21, 2011
0 characters
1 Points
Uncharged Sony Ericsson won't charge again
An original charger might solve the problem.
Try to charge via original charger (look and ensure no pins were damaged).
Oct 17, 2013 | Sony Ericsson Cell Phones
Charging error.stop charging my sony ericsson k800i
As if your using sony ericsson K800i some mobile phones as this problem as myself also faced the same problem sony ericsson mobile shows this error if you charge your mobile using connector or unsupported charges.You visit your nearest service center of sony ericsson and ask then to give branded sony ercsson charger for your mobile.After taking that charger you will not face this problem any more..your mobile is just perfect as new.Your connector or charger is having some problem with it. Charger may cost you around 300 rs. var geo_Partner = '687b82b2-54e8-44dc-93c0-87c73f39cdb0'; var geo_isCG = true;
Jun 12, 2011 | Sony Ericsson K800i Cellular Phone
Sony ericsson w300i n stop charging solution
my sony ericsson W300i phone is not charging because when i connect charger phone not charging or any charging reaction......
my battery, charger, charging socket all are O.K. ..
pls send me urgently sollution.....for this on mail....
May 30, 2011 | Sony Ericsson W300 Cellular Phone
Hi, I am from Pakistan, i bought a k770i Sony Ericsson set the set is showing me the that erorr "k770i stop charging.stop using your phone and contact a sony Ericsson call centre" whats...
Try with another charger. If it still shows the error, try cleaning the gold contacts where the charger connects to the phone and connect the charger again.
If the error still shows, try replacing the battery.
Finally, if none of the above work, you'll have to contact Sony Ericsson to fix your phone.
Mar 05, 2011 | Sony Ericsson W380i Cellular Phone
My sony ericsson w810i phone is not charging through charger but is charging with data cable. The charging jack has been recently replaced. What is the solution for this?
sony ericsson phones have their own two-prong charger/data plug. You will need to purchase another AC charger, or you can purchase a plug that has a female USB and use that. Good luck!
Nov 06, 2010 | Sony Ericsson Walkman W810i Cellular Phone
Trying to charge my sony ericsson k800 mobile and it won't charge. Cannot get 'optimised charging' to appear. Battery now completely flat
Hi, you will need to get another charger. Charger might be faulty and will need to be replaced.
If after replacing charger and still does not charge, then the charging port where you plug in the charger is damaged and needs to be replaced.
Take care.
May 20, 2010 | Cell Phones
When i m charging.. it pops up a message saying that charging error, don charge.. wat's the problem?? my phone is w910i
Hi xue,
This problem occurs due to fault in your charger, The some problem came for me once...
  • try replacing the charger with the ORGINAL Sony charger
Note:Don't use a charger that was manufactured by anyone but Sony Ericsson
Enjoy ! Rate
Vinod Kumar Jayarajan
Jul 01, 2009 | Sony Ericsson W910 Cellular Phone
Mobile wont charge
1. clean the charger port, make it free from dust and rust then try to charge.
2. the problem may be with your phone's charging port, it may be damaged. check it.
Jan 02, 2009 | Sony Ericsson Walkman W810i Cellular Phone
Phone wot charge
I reccomend you take out the battery, and put it back in after 2 minutes. Next, if you are using a car charger, use the home charger instead. If you are using the home charger, use the car charger instead. The charger may be broken.
Nov 17, 2008 | Sony Ericsson K850i Mobile Phone
Sony Ericsson S710 Logo
18 people viewed this question
Top Sony Ericsson Cell Phones Experts
Jose Cada
Jose Cada
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
