Question about Sharp UX B700 Plain Paper Inkjet Fax
Sharp UX105
I recently changed my services to vonage and added a fax line with new number and I thought I cleaned up all the original phone numbers on the fax and now my problem is I think I could send a fax out but when someone is sending me a fax all that happens is the fax phone just keeps on ringing and I preset the fax to 2 rings and I am totally confused ,has anyone have any suggestions on how I can cure this problem. I also went to Vonage to the help section and was no help at all. Thanks Ray
  • 1 more comment
  • Anonymous Feb 14, 2008
    I can send faxes, but can't recieve, help?
    precious_angel_777@hotmail.com
  • Anonymous May 09, 2008
    Go to the your account on Vonage.com and lower your den/receive rate to 9600 to send and receive FAXes.
  • SHARPUX105UX May 11, 2010
    I can't make copies with my SHARP UX-105.
I lost the manual of the SHARP UX-105 and can't make copies. I pressed copy when the page to copy was in but no copy was made.
Posted on Mar 16, 2008
  • 22 Answers
I just have one thought. You may have accidentaly turned off the auto recieve function. This is normally a program function on the display panel. Make sure it is set for auto recieve. Thats all I can think of.
Posted on Mar 31, 2007
SOURCE:
Transmission
This is a strange problem you have here my friend. I found the manual if you need it. it is located here: http://www.brother-usa.com/Data/Documentation/Fax/User/UM_FAX575.pdf If you cannot sort it out with the manual, I suggest that you contact Brother USA and see if they can assist you. their telephone number should be on page 1 I think Good Luck
Jun 12, 2007 | Brother FAX-575 Plain Paper Thermal
Toshiba estudio16s need to change fax# inside machine
You have to change your OWN ID (fax) number through the menus.
Aug 03, 2009 | Office Equipment & Supplies
Unable to send/recieve with my Samsung SF 565P fax
Plug a phone in to fax port, Is there a dial tone there also? can you dial a number and make a call from the fax port? You should be able to with a regular phone. If you can't, try plugging in the fax machine to the other port where your phone is plugged in. try sending a fax.If it works there, then the Vonage device or your service itself is the problem.
Apr 22, 2009 | Samsung SF-565P All-In-One Laser Printer
Unable to complete fax transmissions
This turned out to be a Vonage issue. I was able to fax from my landline. I googled vonage and mx700 and found a number of similar issues. I also ended up setting my speed to 9600 and turning off TX error reporting. A quick call to vonage and an updated profile (not sure what they did) resolved the issue.
Jan 16, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Can't fax long distance now-
Do you have a DIGITAL phone service like Vonage?
Fax machines are ANALOG devices and will not work reliably on a DIGITAL phone line..
Dec 17, 2008 | HP Officejet 5510 All-In-One Thermal...
Can't Send or Receive Faxes from MFC-7820 N
You may not need a separate fax line from Vonage. If you don't need a dedicated fax line, you can try changing the "Bandwidth Saver" settings on your Vonage voice line from your account on the Vonage website. Perform the following:
1. Login to your Vonage account online and click the "Features" tab.
2. Scroll down to the "Bandwidth Saver" link and click on the "Configure" button.
3. You will see a scrollbar with 3 settings: 30kbps, 50kbps and 90kbps
NOTE: My "Saver" was set to 90kbps (Highest Sound Quality) by default.
4. Click on 30kbps (Normal) and click "Submit".
5. Wait about an hour before testing as it could take that long for the change to take effect.
6. Send a test fax to the HP fax test service at 1-888-hpfaxme (1-888-473-2963).
NOTE: This is a GREAT service provided by HP. If your fax goes through correctly, you will receive a return fax within five minutes.
We upgraded to Verizon FiOS and never thought the increased upload speed (4mbps) would present an issue sending faxes. WRONG. We never had fax issues with DSL, Comcast or even Broadstripe VOIP service but for some reason Vonage + FiOS = no fax. That is until we set our Vonage VOIP sound quality to "Normal". Our phone voice quality has been much more reliable since throttling back. This sentiment has also been shared by other Vonage users who have experienced echoing and noise when utilizing the higher quality settings.
Your phone coversations may not have FM quality sound but they will have AM quality and usually that is just fine.
If your fax machine has a Telephone Answering Device (TAD) setting, you can share your voice line with your fax machine and be able to receive faxes and voice messages. Hopefully this will work for you.
Dave Grannas
Nov 04, 2008 | Brother MFC-7820N Printer
My fax model is UX105 Sharp I want to buy a main board and modem for repair it please help
It will most likely be more cost effective if you just purchase a new fax machine this is not a high end model.
You can do a web serch type in "parts for sharp fax machine UX105. good luck
Jan 13, 2008 | Office Equipment & Supplies
Sending Fax
set baud rate to 9600 or slow
set resolution to standard
set error correction mode (ECM) off
if fax has overseas mode turn it on
vonage can make changes to the line that could help, if your using a voice line with call waiting use *70 prior to the number to disable call waiting for that call
Dec 31, 2007 | Lexmark X125 All-In-One InkJet Printer
Outgoing fax never goes
Do you have the same problem with different numbers that you fax to? Are you usinga voip phone service? I use Vonage and have a lot of trouble with faxing. Call the number you are faxing to with a different phone and listen for a fax tone.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 16, 2007 | Brother IntelliFAX 2800 Laser Fax
Sharp UX B700 Plain Paper Inkjet Fax Logo
295 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
