Question about Gateway M250 Notebook
ADD'L INFO NEEDED FOR CLARIFICATION
WINDOW CANNOT LOAD THE DEVICE DRIVER FOR THIS HARDWARE. THE DRIVER MAY BE CORRUPTED OR MISSING(CODE 39)
  • kembert May 11, 2010
    with the online chat $19.99, you can either guide me thru this or do you log onto my computer and all for $19.99 with no extra fee? what are your hours especially thru the holidays
    thanks
  • odiegh
    odiegh May 11, 2010
    what is the device manufacturer and model you are trying to load? It appears you just need different drivers.
The drivers to the dvd rom on my HP notebook is ether corrupted or missing, where can i get them for free?
Go to hp.com. There will be all drivers for your machine. Code 39 usually means drivers not loaded due to hardware failure.
May 04, 2014 | HP Computers & Internet
Code 39
hi,
error code 39 stand for (Windows cannot load the device driver for this hardware. The driver may be corrupted or missing.)
Reason
There are several causes of Code 39 errors:
  • A required device driver is missing.
  • A required binary file is corrupted.
  • There is a problem with the file I/O process.
  • A driver that is referencing an entry point in another binary file is unable to load.
Recommended resolution
Reinstall the drivers for this device.
Uninstall and reinstall the driver
Uninstall the driver from Device Manager, and then scan for new hardware to install the driver again.
You may be prompted to provide the path of the driver. Windows may have the driver built-in, or may still have the driver files installed from the last time that you set up the device. However, sometimes, it will open the New Hardware Wizard which may ask for the driver. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor’s Web site.
  1. On the device Properties dialog box, click the Driver tab, and then click Uninstall. Follow the instructions.
  2. Restart your computer.
  3. Open Device Manager, click Action, and then click Scan for hardware changes. Follow the instructions.
Sep 26, 2009 | Computers & Internet
Code 39 on DVD Philips SDVD8821
Download the latest driver from Acer site or phillips site.
Uninstall the device driver.
Reboot
Windows should detect new hardware and start the wizard. Point to your drver installation file and install the driver.
Reboot. this should fix the problem.
Apr 26, 2009 | Acer TravelMate 4220AWLMi Notebook
Windows xp on aspire 5735z
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
Click Troubleshoot to start the troubleshooter for this device.
Well this error usually is because you have either a bad driver installed or you haven't installed any. Bad news is aspire 5735z is built for Windows Vista. Browsing the Acer website din't earn any results. Try calling in for the phone support they might have a link to where you can download compatible drivers for Windows XP.
Jan 26, 2009 | Computers & Internet
Dvd does not work
maybe here...you'll need to dig down deep into the driver options
click here to find out
Mar 09, 2008 | Acer Aspire 5100 Notebook
Pioneer dvd-rw dvr-k17a
Hi, the error code that you have on the CD/DVD drive is a known issue from Microsoft. The error code means "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (code 39)".
Since you are using a Toshiba laptop; you can click on this link http://tinyurl.com/toshibadvd and click on the repair tool on the resolution. This is applicable on both Windows Xp and Vista and will delete the upper/lowerfilters on the registry.
In case that the error code still exist you need to manually delete the upper/lowerfilters under the registry by clicking on this link http://support.microsoft.com/kb/929461/en-us . You need to go the "Run" screen then type in "regedit" and click OK or hit the enter key.
This will surely fix the error code that you have on the CD/DVD drive.
Thanks
Nov 13, 2007 | Toshiba Satellite A100-S8111TD Notebook
Gateway M250 Notebook Logo
140 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Steve Allison
Steve Allison
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
