Question about Toshiba 32AF43 32" TV
Volume is very low
Hi I have a Toshiba 32AF43 I purchased 4 years ago and the volume is very low. I tried adjusting the volume both by playing with the audio icon on the main and on the tv without success. What can I do? Is this worth fixing?
  • 1 more comment
  • ncruz10194 Dec 19, 2008
    I mean I tried adjusting the volume on the tv and on the remote control. Also, I have a satellite receiver (Direct TV). Thanks.
  • ncruz10194 Dec 22, 2008
    The problem has yet to be fixed.
  • May 11, 2010
    Just a few questions: What do you mean "on the main and on the TV?" Is this hooked up to a surround sound system? Are you using a cable box or satellite receiver? Are you having this problem with all input sources or just on TV channels?
    President:
  • 2,992 Answers
Use the satellite receiver remote control to adjust the volume first. The receiver itself offers volume control and you probably have that turned down. Then you are trying to raise it with the volume control on the TV. This is raising the TV volume, but there isn't much sound there in the first place. Use the receiver remote, and you will probably see a volume bar. At some point it might say something like "best stereo" or a star might appear. If that happens leave the volume set there, otherwise just raise it all the way. Then control the volume with the TV remote, or program the DirecTV remote for your brand of TV, and the volume button should control the TV then.
Posted on Dec 19, 2008
My toshiba tv will play the picture but no volume
First make sure that the tv is not muted.Internally the sound is separated from the video after the IF circuitry and passes thru filters and audio amplifiers before getting to the speakers.If you are not familiar with circuitry you would need a tv tech to troubleshoot the circuitry.
Mar 23, 2013 | Toshiba 32AF43 32" TV
I have a toshiba 26LV610U that has low volume. Most of the time I keep the volume at 40 - 50, but some DVD's are impossible to hear at max. Is there an internal volume adjustment that will amp up the...
Tries tv menu Sound Setting adjustment.Tries all the setting to the max like treble,bass,balance and surround sound is on.This should help make the audio louder.
Jun 10, 2011 | Toshiba MD19N1 19 in. TV/DVD Combo
Why does the audio out is so low???
check whether the volume is low...
double click on the speaker icon on the system tray and then check if all the options has the volume set to max..
Mar 14, 2011 | Toshiba Computers & Internet
There is a loud hum when volume is on low to high
go to control panel
sound and audio devices
voice
under voice recording clk volume and mute the mic phone...........
or
some how your mic is conflicting with speakers. Keep your mic away from your speakers..
Do reply if this woks
Oct 03, 2009 | Bose Companion II Computer Speakers
White screen only on E260 4 GB-cannot get to the menu or anything
Adjust the volume while playing by "turning" the thumbwheel. Go clockwise to increase, counterclockwise to decrease.
Jan 05, 2009 | SanDisk Sansa e260 MP3 Player
My laptop volume is so low,
Are the dvds copies or proper ones that you buy from a shop
Dec 08, 2008 | Computers & Internet
Volume loss after VCR recording
Try adjusting tracking to detent Sounds like audio heads are miss aligned . Does your unit have audio levels if so turn them up when recording. Try adjusting tracking or try patching recording unit to the tv .If it has L/R video inputs use the same deck you recorded on for playback. .
Oct 24, 2017 | Toshiba 24 24 in. TV/VCR/DVD Combo
Toshiba (Model : 36A43) - volume goes down automatically
I am having same problem on 32 inch same problem. After playing with board with no results,I tried front buttons and found that if I held the power button in ever so slighItly as not to turn it off, it fixed problem which is the micro on/off switch, I removed the switch and used the remote and everything is back to normal, I am about to insall a used micro switch after I finish typing this but I am sure this will clear up volume problen and menu going crazy problem if not I will just leave micro switch out and use the remote, and I will get back to this board only if that micro switch still causes the problem, so if I don't post in next hour the problem is fixed and I'm more than glad to help.
Jun 18, 2008 | Toshiba 32AF43 32" TV
Volume is too low on my old Sony Trinitron KV-27S45
Volume is too low on my old Sony Trinitron KV-27S45 Can i fix it with out parts? no as it requires tech help as tv is high voltage device. would it be less expensive to just purchase a new tv? it would be less expensive. no need to purchase new tv. please get check 1 speaker paper cone might be hard or defective 2 loose contact in sound section 3 supply to sound might be absent. 4 connector loose. 5 any capscitor defective in sound section. 6 ic might be defective in sound section hope this will help.
Sep 25, 2007 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Disappearing sound, Low sound, no sound
Unplug the system from the wall and plug in again...It worked for me...hope it works for you too.
Aug 18, 2007 | Bose 3 2 1 GSX System
Toshiba 32AF43 32" TV Logo
1,714 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
