Question about Sharp Aquos LC-37GD6U 37 in. LCD HDTV
TV Flat Screen does not come on.
I have a 32 inch flat screen tv by Polaroid that when you turn it on by the remote or the tv button, the blue light come on but the tv doesn't. So what I did is un-plug the tv leave off for a few minute, plug back and the tv would come on but the sound loud and a lot of garbage sounds off.
That would last for about 10 min. and it would go away and the tv would be fine as long as I leave it on. This happen about (3) days in a row, now the tv does not come on at all.
Can this be fix? We have had the tv for (3) years this year.
Hope you can help me.
Thank youl,
Catherine L. Evans
maconwin2002@yahoo.com
510-467-3876
  • maconwin2002 Dec 19, 2008
    Any idea when I will hear from someone>
    Thank you,
    Catherine L. Evans
Have new out of the box sharp aquos 52 inch tv only get blinking green light.
Posted on Mar 18, 2011
It can be fixed. I had this problem almost a year ago. I did an extensive search online and found a solution. Apparently there's a couple of caps that need to be replaced. The tv is manufactured in Southeast Asia where they use cheap parts. They know the tv will go bad in about a year or so but i'm sure they could care less.
I went to Radio Shack and purschased two caps and a soldering kit for $13. That's all it took to fix it. Keep trying to find it on the web again with no luck. It had step by step instructions. If you just unscrew the back you'll be able to find the bad caps, desolder, and replace with the new caps.
Posted on Sep 05, 2009
Polaroid TV screen will not always come on.
Are you talking monitor rather than tv? I have an LG 22 inch monitor and the on off button is on the bottom, If I don't hit it right or just tap it, it won't turn off but flashes. Where do you have it plugged in? Is it with some other electronics, or right to the wall outlet? I'm really at a loss as to what your problem really is. Are you using the remote? One quick fix might be the battery's in the remote. If they don't have enough power, short or no signal will be sent to tv or not being able to decipher it.
Feb 05, 2015 | Polaroid 4011-TLXB LCD TV
I have a polaroid 15.4" LCD TV. The blue light
i think this can repaired, change the lcd tv screen it will work, your lcd was broken at all
Jan 22, 2011 | Polaroid TDA-03211C 32 in. LCD HDTV
I have a Polaroid flat screen TV 32 inch lcd W Red Light Plz HELP
blown cap in the power supply it will be domed on the top where it vented
Sep 16, 2009 | Televison & Video
Looking to buy a Polaroid TDA-03211C the needs repair
I have a 3 year old TV with the same problem as shema_ross.
Aug 16, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
I have a Polariod FLM 3232 hdtv 32 inch tv The
Most universal remotes don't have the screen mode button. So, your better off with the orginal remote for the TV.
The cheapest place I can find one for you is NewRemoteControl.com
It's going for $49.95
It's a little pricey, but it will have all the option buttons for the TV.
I hope I answered your question. Please rate me. :)
Mar 05, 2009 | Polaroid FLM-3232 Television
42' polaroid tv wont show screen still
well if the light stays blue , that means its still on ...what you may need to do is go to your menue and select the setup selection and then go to tuning band.....i belive it will be on page 32 of you manual, under customising the setup settings....in order for the tv to start working it needs to be able to scan for channels.....if you are useing a cable company like comcast or direct tv...depending on how you pluged it into the tv ,(like using the input 1 or 2 , s-vidio, cable , ectra,)...you need to push the input button thats on the lower right side of your remote and select the propper input area as to how you hooked up your cable box
Dec 14, 2008 | Televison & Video
Polaroid Flat Panel TV FLM 373B
I had the same problem with mine, and figured out how to repair the control box. If you would like to have me perform a service on your set go to www.mikecampagna.com/Polaroid
Apr 13, 2008 | Televison & Video
No Signal
You will have changed the video/audio input, on your tv, it should be an input button on remote. The signal will either be on AV1, AV2, AV3 Component or HDMI.
Jan 24, 2007 | Polaroid FLM-3225 32 in. LCD Television
Sharp Aquos LC-37GD6U 37 in. LCD HDTV Logo
291 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
