Question about Samsung TXJ1366 13" TV
Late turn on
Hi i have a Samsung Hitron black TV and i have a problem turning it on.When i switch the power button on my, TV doesn't turns on immediately.I have to wait up to 40-50 minutes until it turns on. Thanks.
  • nebojsa milosevik Apr 02, 2007
    Thanks a lot for the tip, but i have one more question. My TV seems to loose the intensity of some of the colors( blue for example - it turns darker).
  • 68 Answers
Seems like you are having some problems in the power section of the tv. they are either one capacitor gone bad or some of them gone bad. do you know how to check capacitor? if not just take it to a repair man. good luck
Posted on Apr 02, 2007
I have a Samsung TV that will not turn on.
You have diagnosed the fault yourself. The main board of your TV is defective and needs to be replaced.
Good Luck.
Oct 02, 2017 | Samsung Televison & Video
I have a Samsung Plasma PN63A650 that has worked 4 8 years, until today. I turned it on, stays on for 14 seconds, then turns off for 8 seconds. Would not respond to remote commands either
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. ....Samsung E6030 led tv hv blinkin red light issue ... capacitors are looking good ...
Help PLEASE! Samsung Plasma Turning On/Off Repeatedly.
michiganstate.247sports.com > Topics
247Sports.comMy Samsung Plasma HDTV (approx 3.5years old) has some issues as of late. When Iturn the tv on, invariably, it starts to turn off and back on repeatedly.
Samsung Smart TV turning off - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have a Samsung plasma 60 inch model number PN60E6500EFXZA TV. It began to turn itself off every 5 minutes, for the past few days. I was able to factory ... Samsung TV Keeps turning off and on.
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
Samsung Plasma TV turns off by itself
Jun 22, 2011
My Samsung 50 in PN50B650 turns off by itself then on again ...
Apr 30, 2010
More results from www.cnet.com
Jan 13, 2016 | Samsung Televison & Video
How to switch to av without a remote samsung hitron
hi ya
possible ways - they may be a button on the tv, sometime marked source - or a o with arrow through it
or
best bet is to purchase a one for all remote, for tv as you have a large brand these should work fine,
even try a pound shop one, as it a big brand
samsungs direct link is http://www.samsung.com/us/support/owners/product/HL-P5663W
they may be able to sell you an original remote
hope it helps a little best wishes davetech
Dec 08, 2014 | Samsung DLP HL-P5663W 56" TV
Samsung tv hitron
test this steps and fix it. God bless you
  1. Make sure all power cords are connected.
  2. Try pressing the enter/play key.
  3. Make sure the TV is turned on and the input is set properly.
  4. Make sure the TV source is set properly on the TV (This is probably done on the screen; Check your TV manual).
Jul 22, 2013 | Televison & Video
How can I go to av mode without remote control in samsung hitron tv
Yes, you change your channel to '00' or go up to '101' and then press up button on tv then it will automatically comes to '00'
Nov 08, 2012 | Samsung Televison & Video
Ah59-02342a doesn't control tv anymore
Hi I had exactly the same problem with mine it worked the DVD player fine but not the TV even though previously it had worked both .......... Manual Guide In the manual guide I managed to dig out it says to do the following to set up the remote to work the TV
Press the TV button on the remote
Then whilst holding down the power button you need to enter in the samsung TV codes until your TV turns off (I only got to the first and it did it)
The numbers are 00, 15, 16, 17, 40, 43, 46, 47, 48, 49, 59, 60, 98
Hope this helps
Feb 24, 2012 | Samsung TV Remote Control
The LED in my motherboard is on, but if i turn on the switch, their is no response. the power connection is correct. but it doesn't work
Try swapping the power button connection with the reset button connection. Then to turn on your computer you will need to press the reset button. If that works you have a faulty power button. Otherwise try using a different PSU. One that you know works. If that doesn't help the motherboard will have to be replaced.
Jun 18, 2011 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
How do I get the code for my samsung TV remote control?
Please check the bellow link related to your issue:-
http://ars.samsung.com/customer/usa/jsp/faqs/faqs_view_us.jsp?PG_ID=-1&AT_ID=5716&PROD_SUB_ID=0&PROD_ID=41
However these are the Remote Control Codes for different Samsung Models:
With the TV in standby, press the
{DISPLAY} {P.STD} {MUTE} {POWER} on the remote.
  • With the TV in standby, press the
    {P.STD} {HELP} {SLEEP} {POWER} buttons on the remote.
    or
    {P.STD} {MENU} {SLEEP} {POWER} buttons on the remote.
    {SLEEP} {P.STD} {MUTE} {POWER} on the remote.
To exit, simply Power Off the TV.
Well i tried these codes on my SAMSUNG HITRON 21" CRT TV but did not worked. however at last i tried :
{DISPLAY}{MENU}{MUTE}{POWER}
Please get back to us if you have any further query or else accept the solution.
Thanks for contacting fixya.com
Nov 01, 2010 | Samsung TV Remote Control
Samsung hitron Remote
If Samsung 00026B remote is compatible with 0026b remote, any one tell me
Feb 24, 2009 | Samsung TV Remote Control
Samsung TXJ1366 13" TV Logo
179 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
