Question about Electrolux Cooktops
Wrong type cooktop securing bracket for tiled cabinet
The securing brackets that came with the cooktop are for an all wood cabinet. Our cabinet has top layer of tile, 1 inch of mortar, then wood. I need some kind of adjustable securing bracket to hold cooktop. Where to I find brackets?
    Scholar:
  • 111 Answers
If it were me, I would go to Home Depot or Lowe's and get a small roll of metal strap with holes every 1/2". Should be an easy find and easy installation
Posted on Dec 19, 2008
What if there are no hold down brackets on the cooktop and you still cant get it loose
Sounds like someone glued it down. You're going to have a fight on your hands. Maybe this can help:
How to Remove Countertop That Has Been Glued to the Cabinets eHow
Dec 02, 2014 | Cooktops
How do I lift out built-in KitchenAid glass cooktop KECT 365 when mounting brackets wern't used
You are either:
A) missing the mounting screws and brackets that hold the unit in place
B) it is stuck and will require brute force to remove
C) both
Dec 30, 2013 | KitchenAid Cooktops
How to modify the tile to fit the cooktop
Can you be a little more specific?
The tile usually sits on a substrate and then the substrate sits on the counter.
Does the new cooktop fit into the current cabinet or does that also need to be modified?
How much more space do you need?
How far past the new cut line will the cooktop cover?
Short answer would be a grinder with a masonry cutting blade.
...and a vacuum.
Nov 29, 2012 | Jenn-Air 30 in. CVE3401 Electric Cooktop
Im trying to install this cooktop maytag mgc7430ws, there are two brackets in it and there is absolutely nothing in the instructions about how to attach it to the cabinet
I just put one of these in. You're right, there is nothing in the instructions about this, I had to figure it out for myself.
Your kit includes two brackety-shaped steel brackets and two long screws. Look on the bottom of your cooktop, halfway between the front and back on the left and right edges and you'll see a hole on each side. They are the only holes on the bottom.
Manipulate the brackets until you see that the hole in the bracket matches the hole in the bottom AND the bracket fits upward along the side of the cooktop. The flange on the top end of the bracket goes against the bottom of the countertop.
It's useful to have another person lift each end of the cooktop while you insert the bracket from below.
Once the brackets are in lace, center the cooktop so it's straight on the countertop, then screw the brackets to the bottom of the cooktop. They will tighten against the countertop and make the cooktop stop wiggling.
May 31, 2011 | Maytag MGC7430WS Stainless Steel Gas...
Remove embedded/inset smooth electric cooktop
HI they just sit on the top with brackets holding from the underside or screwed in from under the top sounds like this was put in the tiled after they arestuck downfwith double sided tape as well some times , if nothing works you could go through the top it breaks like a car windscreen hope this helps
Jan 25, 2010 | Cooktops
Kitchen aid KECC507GBL3 electric 36in cooktop. Burner switch is out - cannot get glass top off. Have removed all screws from plate mountings on the sides. Is there a trick to this?
If it’s a range, there is usually a couple of screws that hold the front of the top down, remove the screws, lift the front of the top and pull it out from the back hinges. Install the new top, make sure there are no loose wiring.
If it’s a cook top then make sure that the power to the cook top has been turned off, open the cabinet and look up. There should be a couple of brackets that secure the cook top. Remove the brackets, carefully lift the top and set it on the counter top (put a towel on the counter top first). replace the glass top (make sure there is no loose or exposed wiring), set the cook top back in the counter, secure it with brackets as was before, and double check your work.
Thanks for contacting fixya.com
Jan 14, 2010 | KitchenAid Cooktops
Purchased 30 inch induction cooktop stove to
its ok to cut the laminate using the wood saw to fix the new one.be careful to cut the laminate.
Sep 09, 2009 | Cooktops
Installing cooktop into granite countertop
Put a bead of clear sylicone caulking around the cutout , then set the cooktop in place .
Aug 07, 2009 | Jenn-Air 30 in. CVE3401 Electric Cooktop
Supporting a ceramic cooktop
Yes. It is. i always feel weary when i see it to however the top is not glass its ceramic so it is a little stronger.if you are in fear wrap tape all the way around the top and tight. if the top is tempered then wrapping the tape around it would make it almost indestructable.
Nov 21, 2008 | Cooktops
Jenn air jed 8430 electric cooktop control switch for rear burner
The cook top is attached to the wood frame by brackets, just remove the screws and the electric connection, make sure the power is off from the main box, it's a 220 volt wiring and then just lift the top off. to remove the glass, look around the edges and you should see some small screws, just remove them and the glass should lift off.
Eddie Rentas
Tupper Lake NY
Jul 07, 2008 | Jenn-Air JED8430 Electric Cooktop
Cooktops Logo
158 people viewed this question
Top Electrolux Cooktops Experts
Paul Carew
gbob59
rugby prop
Are you an Electrolux Cooktop Expert? Answer questions, earn points and help others
