Question about NetGear WGR614 Wireless Router
HAVE A PROBLEM
HOW TO INSTALL NETGEAR?
  • 1 more comment
  • alejandra_pi Dec 19, 2008
    I NEDD HELP
  • juliemilburn Dec 19, 2008
    I had to disconnect the router from my modem because I suspected it was messing up my internet. Now I need it functional again and can't work out how to connect it. I don't seem to have receiveced any instrucctions with the router and the cable doesn't seem to have the connection I'd expect it to.
    Can anyone help?
    Thanks
  • erhodes6 Dec 28, 2008
    when i connect cable from broadband comcast i cannot get main desktop to connect to internet but will access new laptop in other part of home.
  • 854 Answers
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Posted on Apr 29, 2009
How to Install Netgear Router Using the Wireless Device
hi john.
To install your NETGEAR wireless router using your wireless device:
  1. Get the preset wireless settings of your NETGEAR router. It is written on the back or at the bottom of your device.
  2. On your wireless device, open the WiFi connection manager and find the SSID or WiFi network name of your NETGEAR router.
How do I install my NETGEAR router using a wireless device ...
https://kb.netgear.com/.../How-do-I-install-my-NETGEAR-router-using-a-wireless-devic...
How to Install Netgear Router Using the Wireless Device Google Search
Nov 06, 2017 | NetGear Computers & Internet
How can i install netgear genie n300 if i lost installation disk, i need to install netgear genie n300 wierless usb adapter to my windows 7 pc
This page: WNR2000v3 has Genie user manual, Installation guide, and the setup guide. It's the support page for Netgear.
Jun 20, 2014 | Computers & Internet
Netgear WPN111
please follow steps to fix your issue
1.install from CD
2.download latest driver for adapter and install in computer
link for latest driver for adapter
http://kb.netgear.com/app/answers/detail/a_id/12520
regards
prakash
Jan 17, 2010 | NetGear RangeMax WPN111 802.11g/b Wireless...
I have a netgear wireless USB 2.0 and i am trying to get it connected. When I try to install the software for it, it says my computer is not compatable with the software? How do I fix this? I am running...
My advice is install this netgear software in Windows XP Operating System . so you try to convert your PC to win XP, then install this software. You will able to access the wireless connection
Thanks
Aug 13, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
How do I install a netgear adsl modem router dg834gt
no you can't use the belkin usb 10/100 ethernet adapter CD to install the netgear adsl modem.
click here to download the installation manual for the netgear device
Sep 09, 2008 | NetGear DG834G Router
Netgear installation
have a look at this site it will help you http://www.lycoming.edu/acad/Netgear%20Wireless%20Router%20Setup.htm
Sep 17, 2007 | NetGear WGT624 Wireless Router
NetGear WGR614 Wireless Router Logo
88 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
