Question about Umax Astra 1220U Flatbed Scanner
I have a replacement universal AC/DC adapter for my scanner ...
..and i need to know thge configuration of the ring tip & sleeve...
..is the tip of the adapter plug set at positive or negative?....
this adapter will be used for my 6400 Umax scanner...thanks
    Master:
  • 461 Answers
This should be shown right next to the jack on the unit as well as the voltage. If not it should be in the user manual.
Posted on Dec 19, 2008
There seems to be no power to our shredder.
Beverly, the power supply for shredder is probably bad. If it has a external power supply, take old power supply with you to a electronics shop and have them match it up for you, with a universal power supply.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
universal power supply Google Search
http://www.walmart.com/c/kp/universal-ac-dc-adapters
Results for Universal AC Power Adapter
SS103 Universal Power AC DC Adapter 500mA
Mar 11, 2016 | Office Equipment & Supplies
I know I need a 5 volt dc power adapter but I don't know the size of the end piece that connects to the speaker can you help me thank you.
Jean, take the speaker with you to the source or electronics shop and they will match you up with proper universal adapter.
power adapters
Amazon com Universal 5V 1 2A AC Power Supply Electronics
5V Power Adapter eBay
Feb 27, 2016 | Audio Players & Recorders
Where can I source an new a.c. adapter for my craftwell e bosser
Search for a Travel Laptop Adapter or Universal Laptop Adapter. Targus makes one with several different tips. Targus Laptop AC DC Travel Charger with USB Fast Charging Port USB...
Aug 27, 2014 | Computers & Internet
Hi.why my zoom g1x has no power.im using a universal adator...i am in phillpines.power volts here..220 volts.how is the setting of my adaptor then?
I have a ZOOM GX1XN and it doesn't like universal adapters much. Using one with the wrong voltage or polarity may permanently damage your pedal. Try to obtain a proper ZOOM AC adapter (part number AD-0006 or AD-16) if possible. These are dual voltage and will work equally well with both 220 and 110 volts. Failing that you need an adapter that will give a DC (direct current) output of 9 volts at 0.5amps - maximum 4.5 watts. The outer contact (sleeve) of the adapter needs to be positive (+ve) and the inside contact negative (-ve). Lots of universal adapters are the other way around with the sleeve being negative - but some have a multi-connector on the end with both positive and negative sleeves.
Jan 08, 2011 | Zoom G1x Guitar Multi Effects Pedal with...
AC/DC Adaptor
Greetings jack71471, there are a couple options to obtain a replacement AC adapter for your Durabrand DVD player. One option is to purchase a universal adapter from a store such as Radio Shack. The other option is to buy a dedicated 9 volt AC replacement adapter from a couple sources on eBay. Just do a search for "PDV-709 adapter" and you will find some AC adapters and 12 volt car adapters as well. If you choose the universal replacement option, make sure you bring the player and adapter with you so the salesperson can configure the settings and polarity to match the original adapter. That is unless you are confident enough to set it yourself, in which case you can purchase a universal adapter most anywhere as long as the current rating ( rated in milliamps or "ma") is equal to or greater than the original. Best of luck to you.
Oct 25, 2008 | Durabrand PDV-709
Cpqusbfw usb hub
i have one of those hubs the ac adapter is output +5V, and current 0.2 - 2.5A, inside of connector is pos(+), outside is neg(-), input: 100 - 120 Vac and 0.45A Max
Aug 30, 2008 | Micro Innovations Compaq CPQ24USB
Modified power conector polarity.
I know what you're trying to do, and I don't recommend it. I've done some splicing, and had a few that burned up the machine, so I recommend buying a new power supply. Check Ebay, you can generally find one at a reasonable price. Here check this link to Ebay, they have your adapter for $16 and change. You can't beat that. So why take the chance of ruining the machine.
http://search.ebay.com/search/search.dll?from=R40&_trksid=m37&satitle=ECS+A535++ac+adapter&category0=
Aug 21, 2008 | EliteGroup ECS A535 Notebook
AC/DC adapter
Make sure the voltage and amperage is the same and the tip fits.
I use I-GO universal from Radio shack
Apr 19, 2008 | Toshiba Satellite L25-S119 Notebook
Microtek ScanMaker power AC/DC adapter
OK WELL I HAVE A MICROTEK SLIMSCAN C3 AND I HAVE THE CABLE FOR THE POWER AND FOR USB......BUT MY PROBLEM IS THAT I DON'T HAVE THE CD TO INSTALL THIS.
IS THERE ANY ONTHER WAY TO INSTALL THIS IN MY COMPUTER WITH OUT THE CD??????
PLEASE EMAIL ME TO gemalabonita92@hotmail.com IF U HAVE THE ANSWER TO MY QUESTION!
THANK YOU!
Oct 18, 2007 | Microtek SCANMAKER 4850 Flatbed Scanner
Umax Astra 1220U Flatbed Scanner Logo
99 people viewed this question
Top Umax Office Equipment & Supplies Experts
Alun Cox
Are you an Umax Office Equipment and Supply Expert? Answer questions, earn points and help others
