Question about Whirlpool 11.8 cu. ft. / 334 liter Upright Freezer EV120FXKQ
Whirlpool upright freezer turning itself off
The freezer turns itself off. When working cannot set a temperature and needs to be on fast freeze constantly, otherwise keeps making a clicking sound.
Hi,my name is sourine,i have a probrem with my freezer not cool at all,it's about20 year old.
BRAND WHIRLPOOL
model EV150N A O
14.6 c.f
Posted on Apr 14, 2009
Hi I lost my manual to my westpoint tropical chest freezer, and wanted to find out how the fast freezer switch works. Does it mean when i switch it off the freezer goes off? or is it just a switch to help...
Hi
Normally a fast freeze button is just that, it turns the compressor on permanently to freeze things down quickly.
I suspect that your run light is linked to the thermostat, and does not indicate that the freezer is turned off but that the temperature of the freezer is above the temperature set on the thermostat and the compressor is running to bring the temperature down. Once the temperature is at or below the thermostat temperature then the compressor will stop and the red light probably goes out, indicating the the freezer is at the right temperature.
It won't go out with the fast freeze on because to freeze food quickly the thermostat is by-passed and the compressor runs continuously.
Hope this helps.
Aug 25, 2014 | Freezers
Freezer is around 3 years old. When set at -17 degrees the freezer clicks very noisely, a relay operating I think. When the fast freeze button is pressed this clicking stops but the display reads -27...
In my opinion, since your going for the fast freeze mode, your freezer sets to its lowest operating temperature to fast tract the freezing process.
and about the noisy clicking sound it is probably a thermostat or relays depending on your system which starts and stop the compressor.
i think your freezer is just doing fine.
Dec 29, 2010 | Whirlpool Freezers
Alarm is going off how do I stop it
The best temperature is the midpoint. Typically 3 or 4. The alarm will go off once the temperature goes down to the freezing point.
May 05, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Freezer compressor runs steady & getting -30F
You probably have a defective thermostat or sensor for reading the temperature.
Mar 23, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
WHIRLPOOL UNDER WORKTOP FREEZER APPROX 11 YEARS OLD BEEPING
the temperature control is bad. when you push the fast freeze it bypasses the thermostat for 12-24 hours depending on which model you have. I am not able to find any parts information with the model number provided but you should be able to find a temperature control at any local appliance parts house or online thru any reputable supplier. Thnaks Peyton
Feb 24, 2009 | Whirlpool Freezers
Freezer drain freezes, and constant clicking noise
This clicking noise is a bad relay.
Get it serviced before you run in to a real problem
Jan 29, 2009 | Whirlpool 11.8 cu. ft. / 334 liter Upright...
Whirlpool upright freezer AFG823NF-Thermostat not working properly
JennyT just trying to help with this. I assume this is a self defrost model. If so then is there an ice build up on the back wall? If so then the unit isn't defrosting. That is why pushing the Fast Freeze button is no longer working. You can get by however. Remove all the food from the freezer, put a vacumn in the freezer and shut the door. Turn on the vacumn, this will pull the warm air thru the freezer and in 30 minutes to an hour it will be defrosted enough to work until you can get someone to replace the 1 of 3 parts that the defrost system uses. The vacumn is what I use to defrost my nonself defrosting freezer. Sorry I couldn't be of more help.
Feb 03, 2008 | Whirlpool 19.6 cu. ft. Upright Freezer...
Whirlpool 11.8 cu. ft. / 334 liter Upright Freezer EV120FXKQ Logo
510 people viewed this question
Top Whirlpool Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Justin Duby
Justin Duby
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
