Question about Kenmore Elite HE4 Electric Dryer
I have an older Kenmore gas dryer that does not heat. I have changed the thermal fuse and it started to heat again then it stopped heating after a while.
  • therainman Dec 22, 2008
    No solution as yet and looking for some answers with direct in getting the problem resolve on kenmore elite dryer
I have a kenmore elite dryer and the heat does not work in any settings... Mdel 110 c60952990.. .Checked main breaker fuse and open dryer cleaned all the unwanted lint and still no heat
Posted on Dec 22, 2008
  • 179 Answers
Clean your dryer vent and check the thermal fuse
Posted on Dec 20, 2008
My kenmore elite electric dryer inconsistantly starts to heat and
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jul 27, 2010 | Kenmore 63942 Dryer
Kenmore series 80 dryer, ryns with no heat. i
that is ur glow bar or igniotror that is common,, check ur ignitor, thermal fuse, or secondary gas coils, those are what are usually wrong with no heat on gas dryers
Feb 03, 2010 | Kenmore 62802 Electric Dryer
Gas dryer not heating.
Commontly thermal fuse is damage need check and change if necessary.
Oct 02, 2009 | Dryers
Kenmore Elite 110.7208201 won't heat up.
Hi
Please check the things that could stop a electric dryer from heating:
- House fuse or breaker (needs two of them), heating element, burnt wire, thermostat(s), thermal fuse (not all models), motor heat switch, timer, selector switch, burnt power cord/plug.
And also check the things that could stop a gas dryer from heating if you have a gas dryer:
- Glow bar igniter, thermal fuse (not all models), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 29, 2009 | Kenmore Dryers
Kenmore gas dryer 110.74632300 timer stopped working and no heat any ideas?
changed the thermal fuse heats for little while but stops blowing heat
Jul 12, 2009 | Kenmore Dryers
Not heating
Hi
Things that could stop a electric dryer from heating:
  • house fuse or breaker ( needs two of them )
  • heating element, burnt wire
  • thermostat(s), thermal fuse ( not all models ),
  • motor heat switch, timer, selector switch,
  • burnt power cord/plug.
You can check these things using an ohmmeter/multimeter from here.
Things that could stop a gas dryer from heating:
  • glow bar igniter,
  • thermal fuse ( not all models ),
  • coils on the gas valve, gas valve, thermostats,
  • motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 20, 2009 | Kenmore 62802 Electric Dryer
Older kenmore dryer works fine but stopped heating
Most likely causes are:
- one of several thermal fuses/thermostat
- broken heating element
May 02, 2009 | Kenmore 64742 Electric Dryer
Dryer want heat up
Hi
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
Please do rate the solution as "FixYa" and revert for further assistance.
Thanks
Rylee
Apr 19, 2009 | Kenmore Dryers
Dryer does not heat
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
Mar 07, 2009 | Kenmore Dryers
Dryer doesnt work but i hear the timer working
Change your cycling thermostat. When your cycling thermostat fails, then the reponsibility of your heating element to shut down goes to the high-limit thermal shut off (closest to heat element) and the thermal fuse. Your cycling thermostat should shut down heat element when it detects about 140* air in the blower housing. Yours can't detect that anymore so it lets your dryer heat up and up till you blow the thermal. new cycling thermostat and thermal
Jan 18, 2009 | Kenmore 60172 Electric Commercial Dryer
Kenmore Elite HE4 Electric Dryer Logo
405 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
