Question about Malber P21 Front Load Washer
How do you fix a seized up bearing?
If the reason my WD1000 is not spinning the cloths out is because the bearing in the back has seized up - how do you fix that?
  • 566 Answers
Hi are you sure bearing is the problem ?? if your machine is working ok ie running /completing the wash cycle and also draining the used water/rinsing cycle ? but when on spin cycle the clothes are still wet ? if this is the case ? may i suggest that you inspect/check the actual motor brushes ?? as if the brushes x 2 are worne very low they will drive the wash cycle for a time but when spin cycle activates the revs req'd of the motor are lost ie worn brushes will not provide extra power now to change brushes is easy diy and here in uk a pack of 2 new brushes cost approx £5 and if you remove rear cover of machine you will see what looks like auto alternator//this is the motor which is held and adjustable to drive belt in the same way as alternator on a car the elec connection is a master plug so no problem to remove? hope this helps and inspires you ? come back if you get stuck ? or req more info best wishes for a merry xmas
Posted on Dec 19, 2008
Maytag Performa clothes washer. Model LAT2500AAE. Made screeching sounds during spin cycle also burned rubber smell. Turned off. Removed and replaced belts. One belt was shot. Ran a test run and still...
Check to see if your water pump is spinning. It could be seized up and the burning smell could be the belt spinning on the seized pulley. Good luck Friend.
Oct 10, 2017 | Maytag Washing Machines
I have a GE washing machine that will only go into the spin cycle with no cloths in the tube, but still agitates for washing cloths. Before it got to this point I would hear a grinding sound when in spin...
these machines use the belt as a clutch and a cam to release the break the growling noise was probably the bearing going at the bottom of the trans and is now seized you may also find a water leak at the tub seal this is the most common reason for these failures you will probably end up replacing thee trans and seal kit.
Mar 08, 2011 | GE Washing Machines
Front load machine will not spin all the water out of the cloths and it is making a noise during the spining cycle.
Hello Friend,
The problem you described suggests that the spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle, as said by you. This would require to call a qualified appliance repair technician.
Check this and do get back to us for any further assistance.
Thanks for using FixYa....!!!!
Mar 05, 2010 | Frigidaire Washing Machines
Mav7000 spins but does not extract well. Clothes remain wet
wet as in standing water left in tub, or wet as in extra drippy???
standing water would be bad or pluged pump, drippy would be bad belt, pulley or tensioner assembly..
also if pump turns hard or has seized, the seal/bearing may have seized, causing a slowdown in spin speed besides burning the belt, leaking, and making a mess..
best of luck,
ttfn
Oct 25, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Clothes dryer will not start
sounds as if your motor has tightened-up or seized from heat and age bearing failure which it would cause excessive current draw at start-up if you can access the motor unplug unit then remove belt and spin motor pulley is should turn freely and coast to a stop if it seems tight the bearings are dried out
Jul 12, 2009 | Whirlpool Dryers
Wont spin with clothes
Common problem with this model I own it. Sounds like the roller clutch bearings in your machine are seized/rusted up. Do you want to try to DIY the repair? Read thru this post for the details of what is involved. Post back with any questions. Rich
May 03, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Helpp
If you have removed the drive belt from the rear pulley and the inner spin basket does not spin freely, you either have a drum bearing seized up on you, or something binding between the spin basket (stainless steel tub) and the outer tub shell. First, you need to reach inside the wash tub with the washer empty. Place the palm of your hand at the 12 o'clock position and push straight up. There shouldn't be any play in the spin basket. If you can feel the basket wobble up and down, you have either a bearing problem, or a spin basket support (spider arm) broken on the back of the spin basket. If there is no play at all, you probably have something caught. Small articles of clothing can sometimes get pulled between the tubs and usually ends up around the support shaft in the rear. This will obstruct the basket from spinning freely and could eventually cause damage to the drive motor, spin basket and/or tub bearings. You can use the instructions for replacing a rear tub bearing that I have posted under my Tip and Tricks for instructions on how to disassemble and inspect the tub. The bearing may not be bad, but you still need to check to see if anything is binding the spin basket against the tub shell and inspect the spin basket supports. Unfortunately, you have to disassemble the washer to be able to inspect any of these items I mention. I hope this helps you.
Jul 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Model MAV3855AWW revision 26 loud knocking sound during agitation, weak spin clothes are soaked after spin cycle belt replaced
The problem is 2 fold. The "knocking" noise is indicative of brake rub. The fix is to replace the rotor & stator. The reason that your clothing are coming out wet is because the brake is dragging along a polished stator when in spin and cannot get up to its proper speed as a result. The 2nd item that should be replaced is the thrust bearing assy. This is what enables the transmission to transition from agitation to spin... Hope this helps... Bill
Apr 30, 2008 | Washing Machines
Drum will not rotate
im confused as to why you think no drum rotation would be caused by bearings. typically worn bearings would cause noisy spin. only if bearings were completely seized would that cause no drum rotation. can you rotate drum by hand? if so bearings are not seized. can you hear motor rotate when you select spin? if not, then likely cause is motor brushes. do these simple tests and get back to me if you want. and bearings are quite difficult to replace on this machine
Apr 26, 2007 | Zanussi F1045W Front Load Washer
Malber P21 Front Load Washer Logo
396 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
