Question about Zenith C27A24T 27" TV
Picture is cut off on top and bottom
We found a Zenith TV and everything works fine except the picture. It is filling the screen too much so you cant se the top of the picture or the bottom. We are trying to change the osd settings. HELP
  • Anonymous Aug 14, 2008
    my zenith system 3 tv the picture is cutt off on the sides!! Help me please
    President:
  • 3,130 Answers
Thats is not going to fix your problem. You have a bad vertical output IC and or a bad capacitor in the vertical drive or output circuit. Good Luck
Posted on Mar 31, 2007
My lg plasma tv is cutting off the edges of the shows we are watching. I cant find a setting that will take care of it. Can you help
hmm normally these settings are found in the picture settings of the set top box or just a setting in the tv's picture settings now there might be an option to say fill screen that may work best for some or leave the tv in 16:9 some broadcasts may only be in 4:3 at times this is normal broadcasting and not much can be done unless the setting on the picture option is set to fill screen
Jan 08, 2017 | LG Televison & Video
VERTICAL LINES ON OLDER ZENITH FLOOR MODEL TV
this was adjusted by the fine tune on the selector It is the picture not being held in place by being out of tune Same as if the picture goes sideways On the real old units there were 2 knobs to make these adjustments.
Jun 10, 2013 | Televison & Video
Picture Size
Keep in mind that not all programs and show are in widescreen format. When set to normal, you will get those black bars on the sides because the program is sized for the older TV's. Some TV's will have a zoom option, but that will cut off some of the top and the bottom of your picture.
Until everything goes widescreen, you are stuck in normal with those black bars or widescreen with the fat people.
I hate distortion in my TV image, so I am perfectly fine with my TV on normal.
Good luck.
Jul 14, 2010 | Philips Magnavox 42MF521D/37 Television
Screen cuts off top of heads
Check the menu settings for the picture. You may be expanding the image to fill the sides, in the process, cutting the top and bottom.
Mar 10, 2010 | Samsung LN-S4051D 40 in. LCD Television
My Zenith C32V28 television does not display the top and bottom of the picture. I phoned Zenith tech support who told me that it was the satellite signal. I called the satellite provider who advised me it...
This is applicable to Bell Television Services (Canada)
I solved the problem myself after two calls to both Zenith and Bell Television satellite service. On the bottom left of the Bell remote control there is a * (STAR BUTTON). Press this * button and within two seconds you must press the channel change button up or down. This will do two things. One; it changes the channel; and also changes the ratio of the satellite signal. There are three satellite signal ratio settings. Try this when you are tuned to a TV channel such as BNN (Canada) (Business News) or The American channel which has a stock ticker usually displayed along the bottom of the TV screen. Select the ratio (setting) that allows the stock ticker to be displayed......hope this helps.........Jim McP
Nov 10, 2009 | Zenith C32V28 32" TV
Picture Problems!!! TOSHIBA TP55D80 REAR PROJECTION TV.
Look up your user manual, it sounds like your zoom feature has been activated to the max. I have a Zenith backlit LCD TV and it has a zoom feature you control from your remote. You could open up your on screen menu and find the place to reset the TV to factory settings that should clear up the problem.
Sep 28, 2009 | Toshiba Televison & Video
Top and bottom of the picture is cut off.
look for a button on the remote control that says, "pic size"," zoom","aspect" and scroll through until you get to 16x9, full , fill screen . i can't remember what this model states on the screen.
Feb 19, 2009 | LG 42PC3D 42 in. Plasma Television
PICTUR IS TO TALL FOR SCREEN CUTS OFF TOP AND BOTTOM OF PICTURE
Depending on the model and manufacturer, look for a "format" or an "aspect button on the remote control. This will change the screen size from 4:3, full, zoom, etc.
Dec 06, 2008 | Televison & Video
Picture jumps
you might have bad caps or the vertical output integrated circuit, try to locate the vertical ic and check the surrounding areas for bad capacitors.
good luck
caypianan@yahoo.com
Oct 23, 2008 | Hitachi 53SWX10B 53" Rear Projection...
I have a Mitsubishi VS-60.. With a Picture
Vertical IC outputs , vertical Capacitors are most like the culprit on your deflection panel. good luck
Aug 16, 2007 | Mitsubishi VS-50501 50" Rear Projection...
Zenith C27A24T 27" TV Logo
135 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
