Question about Tappan 24 in. Freestanding Gas Range Kitchen Range
Need a manual for a a\Tappan uston Gas stove 36 "wide.
No model number, only "Custom"as identification. It has two burners on each side, and a center heating/griddle burner. The shelf in the oven apparently cannot be removed and its height altered. There is a storage compartment on the right of the stove, Please help me obtain a manual for this or a similar Tappan range. The stove is at least 18 years old.
Thank you.
  • Tappan Master
  • 21,631 Answers
  • 183 Answers
SOURCE: Tappan Gas Range Oven Will Not Light
probable displaced burner assembly, faulty flame failure device or blocked burner or jet. Regards Engineer
Posted on Jul 28, 2007
SolutionGuy
  • 331 Answers
SOURCE: Tappan Gas stove
The pilot adjustment screw is located on the back side of the oven temperature thermostat. Lift the cook top to access it. Use a flat screwdriver to adjust... counter clockwise= bigger flame.
Posted on Aug 15, 2007
IFIXALL
  • 868 Answers
SOURCE: Oven will not lite
Older is BETTER !! Replace the igniter,even if it is glowing
REPLACE it !
note:there is a 2% chance the safety valve is the problem.And I'll bet you ,you are in the 98% side on this one.EVEN THOUGH YOU SEE IT GLOW -----IF ITS JUST GLOWING---------GLOWING--------GLOWING---------it's gone ! !
Please Rate This & Thank You ! !
Posted on Jun 12, 2008
huuum
  • 750 Answers
SOURCE: Tappan gas range burner ignition
Hello paultoledoWelcome to fixya.
I'm Huuum and happy to assist you,
You said, You got a 5-year old Tappan gas range. Two of the burners don't ignite, the other two and the oven are fine.
What do you need to do to fix the problem?
Sounds like a yes from where I'm sitting, your right on target, buying a new spark module will fix it.
That sounds like the spark modules.
I think you are correct!
Let me know if you need me!
Please remember to leave a solved rating!
Huum
Posted on Sep 24, 2008
SOURCE: THE STYAINLESS STEEL COOKTOP
I NEED TO REPLACE MY STAINLESS STEEL 5 BURNER WITH GRIDDLE COOKTOP ON MY 36 I TAPPAN RANNGE BUT DONT KNOW WHERE TO FIND ONE. I CANT SEEM TO FIND THE SRIAL NUMBER/MODEL NUMBER ON THE STOVE. HELP! DAN WILLIAMS
Posted on Oct 28, 2008
Tappan oven door seal replacement
You will have to google the parts may be very hard to find but you never know what comes up .
Mar 16, 2017 | Tappan TEF242 Electric Kitchen Range
No gas going to oven
Hi blocked oven pilot , ffd not working oven burner blocked injector blocked
Feb 02, 2010 | Tappan 24 in. Freestanding Gas Range...
I have an older Tappan gas range. There is a
If you are referring to the top of the oven cavity itself (the ceiling in the oven) you may be describing the flue gasket and flue that is mounted on the top of the oven cavity. The part numbers are 316116600 and 316204401, respectively.
If you are referring to the top panel of the stove directly under the console, and in back of the surface burners, you may be describing the oven vent opening. It is normal for this vent to have oven heat escaping it. That's what it is for. That's also why you do not leave anything on the stove top while baking. There is a vent cover that is supposed to install over the opening. The part number is 316104500.
If the model number is correct, you can refer to pcappliancerepair.com for illustrated parts listings. The flue gasket and flue are listed under the "Body" section as items 35 and 36, respectively.
The top vent cover is listed under the Top/Drawer section as item 25.
Please review the parts listings for clarification. If I have identified the wrong parts, based on your description, or if the model number is not correct, please post back and let me know. I hope this helps you.
Dec 20, 2009 | Tappan TGF320 Gas Kitchen Range
The igniters on the left side on my Tappan gas range.
may need to disconnect voltage to machine,and check for a loose wire to burner knob.may need to lift top.to access this area.
Oct 09, 2009 | Kitchen Ranges
Hello, Can't find model/serial number. Older Tappan custom gas stove. Burners work but oven does not. Told it has electric ignition that could be problem. Where to find it, how to remove, where to get...
Serial number labels are usually located in any one of a number of places -
Under the cooktop in one of the corners
Inside the oven door frame (not on the door)
Behind the bottom drawer pullout on the oven, left hand side
Oven back.
If this unit is anything less than 20 years old, there will be a label somewhere.
Reply back you findings and I can give you more information as to how to repair, and we can identify part numbers. You might also try www.repairclinic.com and see if you can drill down through parts when only knowing the manufacturer.
Jan 30, 2009 | Tappan TGF363 Gas Kitchen Range
Jun 16, 2008 | Tappan MGF500PBW Gas Kitchen Range
Oven will not lite
REPLACE it !
Feb 01, 2008 | Tappan TGF363 Gas Kitchen Range
Tappan Gas stove
Aug 14, 2007 | Tappan TGF363 Gas Kitchen Range
Tappan 24 in. Freestanding Gas Range Kitchen Range Logo
122 people viewed this question
Top Tappan Kitchen Ranges Experts
Paul Carew
Sal De
Craig Butler
Craig Butler
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
