What is this and how can i fix it
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
NOTE: If the error remains on the display, call for service.
Check the filter at the pump first cleanit out then go from there,my washer was showing f11 suds and other f codes i took off the front panal clean out the filter that was full works ok now
SOURCE: My Kenmore Elite he5t steam washer gets F35 error code
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$%
SOURCE: Whirlpool duet front load washer flashes F35 shortly after start
Sud= The unit has sensed there is too many suds in the unit it will
flush and pump out for 5 min and restart on its own..This is caused by
too much soap use..
From the book :
SUD Code=
If too much detergent was used:
—Run the unit through a Rinse/Spin cycle.
—Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
SOURCE: I get F35 error code on my duet washer
Both of these fault codes point to a pressure switch issue. If you remove the top panel, three screws in the back, you will have access to the pressure switch. With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions. If the fault codes return after diong this, you will likely need to replace the pressure switch.
SOURCE: Kenmore Elite HE5t Error Code F35
Very easy to replace the sensor...hard to swallow that the $.05 of plastic that cost over $100 plus shipping. I did google sears parts discount code and found a free one that knocked $10 off the total. I also complained @ CPSC's Hotline at (800) 638-2772. It is nothing in my operation that made this part malfunction, the fact that Sears Parts had it backordered and no official parts dealers within 100 miles had the part on hand ought to tell them that this should be recalled! We are 4 loads in and praying that it keeps working, after spending over $100 at the laundry mat for our family of 6 I am still fuming that I stayed with Kenmore (last washer lasted over a decade) and they suckered me into a $2,000 investment in their washer/dryer system. I did take the front bottom panel off and clean the filter, pretty nasty but easy to do as well. Thanks for the help, I was determined not to pay Sears anymore than I had to.
SOURCE: model: wfw9500tw01 f35 error
I started the washer this morning and got a Suds message.....it had not even begun filling....when turned on it locked, unlocked and relocked again. Then the message....then it sounded like it was trying to discharge water...then the F-35 code came up. I unplugged for 2-3 minutes...then retried to run on a different cycle....same drill. I called the hotline and the person who answered the call said she didn't even have an F-35 code...and it's not in the book either. So....she scheduled A&E to come service but not 'til Friday (today is Tudsday)....I"ll let you know what happens
Please tell me what your repair person discovered?? We have the exact problem with our Duet Steamwasher...'suds' has been displayed off & on for the last several weeks, and now, F35. We tried to xcel & restart twice, same deal. A&E is supposed to come on Wednesday but I have a 3-month old & 3-year old and today is only Monday. Any tips on what we could try to do would be greatly appreciated...
How to fix the washer machine when you get the F35 error code
