Question about Onkyo HT510 Receiver
Won't Work My Standby light keeps turning On and Off, and my receiver wont turn on
  • brunk Dec 03, 2007
    when i turn on my receiver it shuts back off in about 3 seconds and then the standby light flashes i disconected all the wires and it still happens is this somthing worth fixing or do i just get a new one. i could not find the model i have this is what it has on the frount HT-R520 and its 1000 wats
    thanx jason
  • Anonymous Jun 05, 2008
    ditto, subwoofer light is red also.
petraman7
  • 1175 Answers
SOURCE: blinking standby button
Hi...1st off ...make sure all the speakers are connected at both ends.
2nd..buy a new cat..one that doesnt drool.
If it's still stays in Stdby after checking speakers, It might have blown an internal fuse cause thats where those darn stereo people put them now.
Posted on Jan 14, 2009
  • 4234 Answers
SOURCE: receiver keeps turning on and off also the standby mode blinks
The receiver is going into "protect" mode. This means that a problem has been detected and the unit shut down to prevent further damage. Without seeing the unit and taking some internal measurements, it is difficult to provide a complete solution. Typically, the output transistors fail which can cause this. There are other possibilities too. I would suggest that you get a detailed repair estimate from a local shop. With that information, we may be able to walk you through the actual repair.
Dan
Posted on Oct 15, 2009
smarthome2
  • 1114 Answers
SOURCE: Hello, My receiver wont come out of
If you push the power button and you hear it "click" that means it's getting power. Now, that being said... Couple things to check: first: disconnect all speaker wires at the receiver and attempt to power up, if it does, that's a good sign that your receiver is ok and your problem lies in the speakers or in the speaker wire. If you still can't get it to power up, pop the top of the unit. Most receiver's have 6 or 7 #1 phillips head screws on the sides and rear of the receiver. Pull these off. Look directly at the area where the power cord plugs into the unit (make sure the unit is unpluggged) There is usually a fuse right nearby. If it's a white fuse or gray fuse you may need to do a quick continuity check with a meter to test. If your familliar with meter's, just switch it to continuity/tone. If the fuse is good, you will hear a tone from the meter. If not, there's your problem. If your not sure how to test with a meter, either take it to Radio Shack or similar store, ACE hardware etc. they can test it for you and will generally have replacements in stock. If the fuse is good, your speakers are disconnected and you still have no turn on, your receiver needs to be serviced. If that's the case, whether you service or replace the receiver, get a good "Theater" line conditioning surge!!! like Panamax, Monster, APC, or Furman. A good unit will start around 250. Small price to pay for saving expensive electronics! Hope this helps. If you need further help, just post a comment and I will be glad to help.
Posted on Dec 05, 2009
  • 137 Answers
SOURCE: Is it odd that my TX-SR606 Onkyo Receiver wont go
try reset. push and hold vcr1 and then press power button while unit is on this will reset back to factory default
Posted on Apr 24, 2010
dunnbiker
  • 8546 Answers
SOURCE: i have an onkyo HT-R560
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the
speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Posted on May 07, 2011
Mum pressed some buttons on amp now the amp wont respond to the original remote or the universal remote. buttons wont work, batteries good and lights up. is there a button that blocks ir signal?
Looking at the user guide it appears that the amp has a standby mode.
See not below on turning standby on. Question can you see the standby light flashing.
I would also suggest using function on the amp to remove any possible issues with the remote.
One would expect the system to return to normal operation by pressing the power button again. If not what do you see on the display.
Note:
Press 1 to turn on the receiver.You can also turn on the receiver using 1 on the remote control. When you turn off the receiver, press 1 again. "STANDBY" flashes on the display panel. Do not disconnect the AC power cord (mains lead) while "STANDBY" is flashing. This may cause a malfunction.
Jul 08, 2017 | Sony Audio Players & Recorders
The power for my bush tv model number led26982hdt
My bush television wont turn on from standby? - Ask Me Fast
www.askmefast.com > Consumer Electronics > PlayStation > Wont
Hi my bush tele wont turn on it just keeps flashing at me standby light i ve changed the fuse .... Bush 22 inch tv dvd combi keeps restarting remote doesnt work.
22" bush tv wont turn on - The Student Room
www.thestudentroom.co.uk > ... > Sound and vision
The Student Room
Mar 12, 2012 - 12 posts - ‎7 authors
i got a new tv in january from argos and not had a problem with it until now. The problem is that it just stays on standby and wont turn on. the ...
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
Hello my bush 22 inch tv is messed up Say if i go on it one day it..... it wont turn on from the power botton on the back not from the control ...
Jan 10, 2016 | Bush Televison & Video
I have a Kenwood krx-89 standby light on please help
Krx-89 stand by light wont turn off - Fixya
www.fixya.com/support/t14712608-krx_89_stand_light_wont_turn_off
Oct 20, 2012 - krx-89 stand by light wont turn off Stero doenst play is it because thestand by light is on? How do i turn off - Kenwood Audio & Video Receivers ...
How do you turn off standby on a kenwood krx-89 stereo ...
www.fixya.com/.../t15447523-turn_off_standby_kenwood_krx_89_ster...
Dec 20, 2012 - Hi, is the red light that says power On? If not, it could just be the fuse since I had the same problem. If you take the lid off, it should be in the left ...
Read - Document Download
Dec 14, 2015 | Kenwood Audio Players & Recorders
I have an RCA STA 3900 stereo reciever that wont turn on. Standby light is on. Tried resetting it from the back but didnt work. Please advise
A standby condition can mean a fault in the receiver. voltages in the system are off. This can either be a bad diode or power transistor.
Aug 24, 2014 | RCA Sta-3900 Stereo Receiver
Button standby
The receiver is in protect mode, most likely due to a damaged amplifier. This protect mode, keeps the unit from turning on and causing further damage to itself and/or your speaker system. For more information, please visit my website at audioserviceclinic.com. Thank you.
Jul 27, 2013 | LG Lsb316 Sound Bar With Wireless...
TEAC AG-V1200 receiver won't auto turn on when
No. It won't automatically turn on when power is present.
Aug 08, 2011 | Teac Audio Players & Recorders
I've got a vsx-920-k Pioneer receiver with s-11 Pioneer speakers and a s-21w Pioneer subwoofer. All of a sudden my sub stopped working and it seems like it's stuck in standby mode (blue light...
The manual is here...
http://www.pioneerprodj.eu/eur/products/42/99/S-21W/media.html
Flashing Blue is not defined in the manual.
Have you tried changing the Auto Standby switch to ON?
You can prove if the sub amp will respond to a known good input by TURNING ITS VOLUME DOWN tp start and just feeding it ANY RCA output from the receiver while playing, say, FM (to keep it simple). That way you would known in which direction the problem actually lies (internal or external).
Jul 05, 2011 | Pioneer VSX-C300 Receiver
Pioneer media receiver won t turn on
If the light on the media reciever doesn't come on then the power supply in that needs to be replaced by a service tech. If you disconnect the 2 cables from the media reciever and the panel and then try to turn on the panel it should light with red and green squares for a few seconds but will turn off as it needs the media reciever to be connected.
Mar 29, 2009 | Pioneer PureVision PDP-4340HD 43 in....
Blinking standby button
Jan 09, 2009 | Onkyo TX-SR605 Receiver
Onkyo HT510 Receiver Logo
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
