Question about Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range
Grimy, Smeared look to my NEW Jenn Air Appliances
I have the oven, fridge and dishwasher all by Jenn Air and have tried every Stainless Steel cleaner available and all the appliances still look streaky, dull and grimy. I've seen many similar complaints posted and i would like a solution to this problem as soon as possible.
  • 906 Answers
Good day,
hope this link below will solve your problem.
kitchen appliances
Posted on Jul 31, 2010
Letters wearing off stainless steel
depending on the appliance and series you could replace the logo or of its etched on and came off ET al designer series, you would have to replace top for cooktop or door for fridge or door panel for oven or range . Model serial helps pin the answer more specific . Hope this helps
Dec 06, 2012 | Dishwashers
The door is getting rusty. I believed that stainless steal didn't rust. Is there a way I can remove the spots?
Normally these appliances use brushed steel which gives a stainless steel look.
Get a magnet and run it on the sheet. If it sticks then it definitely is not stainless steel.
However, with wear and tear stainless steel surface does break down causing rust to start.
To remove rust go to this site.
Mar 22, 2011 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
I have a stainless steel hood vent over my cooktop. It is looking dull in spots and blotchy. Tried stainless steel cleaner with no results. What can I do???
call the store where you purchased and they can tell yout the best cleaner for stainless steele products also search the web/.
Feb 24, 2010 | Jenn-Air 24 in. JDB1100AWS Built-in...
Rust on stainless steel
1) Take rust off with Bar Keeper's Friend and a damp sponge.
2) Rinse and dry
3) Wipe with mineral oil.
Will be good as new
Sep 24, 2009 | Whirlpool GC5THEXNS Stainless Steel Side...
How to clean stainless steel
You say your new oven...and DW have stains...I will assume (if that's OK) that you have a stainless steel oven...and are washing stainless steel in the DW...but you are having streaks and or white...spots or deposits...Sounds like hard water...you may try a localized..(just for the DW and kitchen sink area) filtration system...to reduce hardness of water...(is this well water)..if so you definitely need filtration...if you don't already have it.
Here are some issues and or cleaning techniques for stainless steel.
stainless steel is known for its ability to be a clean surface that resists corrosion and rust. Dirt, dust and grime, however, put stainless steel at risk for corrosion and rust. Luckily, stainless steel responds well to cleaning, never wearing out from excessive cleaning, as long as certain rules are followed. 1. Water and a cloth.
Routine cleaning can be accomplished by using warm water and a cloth. This is the least risky option For cleaning stainless steel. Dry with a towel or cloth to prevent water spots. Wipe in the directions of the polish lines.
2. Mild detergent, (dish washing liquid) and cloth.
For cleaning that needs more power, mild detergent and warm water can do a great job without damaging the stainless steel. Make sure you rinse the surface thoroughly to prevent staining and spotting. Towel dry to prevent water spots which can be caused by minerals in water.
3. Glass cleaner for fingerprints.
Fingerprints are one of the biggest complaints about stainless steel, but can be taken care by using glass cleaner or household ammonia. Rinse thoroughly and towel dry. There are some newer types of finishes for stainless steel that resist fingerprints, a must if your pint-sized helpers leave their mark on your stainless steel appliances.
4. stainless steel Cleaner.
If you’ve had staining or scratching, or need to polish your stainless steel, a stainless steel cleaner may be a good option. Some of these cleaners and polishes can help minimize scratching and remove stains. They also can polish stainless steel surfaces nicely. Read the directions on the stainless steel cleaner and test in an inconspicuous spot. Be sure to rinse thoroughly and towel dry.
If this does not help please clarify...with specific model #'s and walk me through (step by step) what the specific problem is and how you address it....Thank you and I hope this helps.............
Good Luck...........The Fang.
Mar 06, 2009 | GE Nautilus 24" Built-in Dishwasher
Cleaning front doors
stainless steel cleaner should shine out the metal for you, (always clean with the grain of the metal as not to scratch)and the glass is reg glass, so windex should clean that up
Dec 02, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Stainless steel appliances ie. refrig, dishwasher & oven
a quality s/s cleaner and a clean cloth sould do the trick for most stains, WD-40 also works to remove the stains, works really well, also leaves afilm on the metal to prevent stains from adhering, just dont use paper towells, the tend to leave fibers behind. and also look closely at the s/s there is a GRAIN pattern in the metal just like wood would have a grain!! be sure to wipe in the direction with the grain not against.
Mar 19, 2008 | Refrigerators
Stainless steel is rusty/blotchy
Jenn Air makes great products, don't blame them. Your type of stainless steel is a consumer grade that has less nickel-chromium in the mix making it affordable to the consumer. The surface needs to be "pacified", DeBruce Polish will REMOVE THE RUST and PACIFY the surface. We get Debruce Polish at debrucepolish.com.
Jan 02, 2008 | Jenn-Air 24 in. JDB1100AWS Built-in...
Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range Logo
141 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
