Whirlpool water heater has smally hot water i am unable to locate anode rod to remove/replace it
  • 1,420 Answers
Your anode rod is at the top of the water heater and may be under a plastic plug. I have seen them foamed over as well. You can get a replacement rod from a good plumbing repair shop or from the internet. Pull up your model on the net to see where your rod is located.
Posted on Dec 19, 2008
Anode replacement. where is the anode rod located on a ruud g100-200 gas water heater
either in the anode port on top of water heater, or connected to hot water nipple as a combo ... or both if unit has 2 anodes
Sep 25, 2014 | Rheem ruud g100-200 water heater,gas,100...
Why is there a bad odor from my 19.9 gallon reliance electric hot water heater
Anode rod?
Replace anode rod, or remove anode rod, and clean tank with hydrogen peroxide (not bleach)
Anode will keep tank from rusting.
Cut new anode rod to correct length using hack saw.
Aug 25, 2014 | Water Heaters
I can not find the anode on my water heater
1) Copy following link:
2) Anode might be located on hot water nipple as a combo.
Insert carriage bolt when removing nipple to avoid collapsing nipple during extraction.
Regular combo anode rods are available, or buy sausage-link combo available in 12" length to fit low headroom installations.
3) Ordinary 1-1/16" hex Anode might be located under the metal cover on steel tank.
4) If unit has power vent, the anode might be under power vent.
Workaround; Install combo anode to replace hot water nipple.
Dec 06, 2012 | Whirlpool Water Heaters
GPS-75-200 anode replacement
The anode is located under the power vent.
Remove power vent to gain access.
Otherwise, remove Hot water nipple and install combo anode rod. If odor is the reason for replacement, then installing a combo without removing the old anode will not solve odor problem until old anode completely dissolves over time.
Copy following link for specific information and illustrations, including odor elimination using hydrogen peroxide.
For easy access next time, you can remove old anode and plug hole, and then install combo rod.
If longevity of tank is reason you are accessing the anode, you can add a second combo anode in addition to the original anode and give longer protection
Aug 07, 2012 | RTO W4 A.O Smith Gas Hot Water Heater...
Where is anode located mdel no. 82yp30-1
Question posted under Rheem water heater.
Model number does not describe water heater.
Model number posted in question does not appear at Rheem, and does not appear in a web search for water heaters.
Here are options:
1) Add a comment and describe water heater in detail so expert can access more information
2) Contact Rheem.
3) If this is tank-type water heater, the anode is located on top of heater.
Look for 1-1/6" hex nut located under a plastic plug.
Some anode rods are connected to the hot-water nipple.
Sometimes the top cover has to be removed to find anode hex nut.
I have used impact wrench on anode, and could not remove in some cases.
4) More resources:
Sep 17, 2011 | Rheem Water Heaters
I have a whirlpool gas hot water heater, FG1H5040T3NOV, and need to replace the anoid rod. I have soaked the top nut in penetrating oil and am using a 1/2 inch 18 inch long breaker bar, but am moving the...
Sometimes the anode rod simply will not come out.
I have used impact wrench before and been unable to budge it.
Water heater 'lining' is enamel coating on inside of metal tank, developed in the 1950's or 60's.
Lining is shiny veneer, and is not glass, and doesn't matter if anode is depleted or tank has odor from bacteria reacting with anode.
You cannot break a tank by removing anode, unless steel tank is totally rusted.
Here is a photo showing how to position 2x4 to hold water heater steady: Use a bigger cheat bar and try again.
Aug 13, 2011 | Whirlpool Kitchen Ranges
Water has a sulfa oder,when not in use. what is the solution?
Generally tank odors are bacteria reacting with anode rod.
Make sure odor is isolated to water heater, and on hot water line only so you know water heater is best suspect.
Change anode rod.
Your plumber will know all about anode rods and will have tools or impact wrench for removing old anode rod.
Apr 25, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Where is the anode rod located on the rheem 81VP20s
Anodes are located on top of water heater.
There are no hard fast rules for location, either by model number or brand.
Most times the manual is likewise vague.
1) There is hex head visible on top of tank.
2) Hex head is located under a plastic cover
3) Hex head is located under metal top, so remove screws holding top, and lift top off to view hex head
4) Anode is connected to hot water nipple.
5) With 9-12-15-and lifetime tanks, you can have 2 anode rods, and each has to be made of same material to work properly. Usually magnesium-aluminum instead of aluminum.
But if you inspect and change anodes frequently to prolong life of tank, then one is as good as the next.
Open following links shows Rheem anode rods
Tech resistor anode rod has resistor added to prolong life of anode.
You can cut rod off to fit size of tank. You want anode 5-6" from tank bottom so sediment build-up doesn't reach anode.
Anodes are standard 1-1/16" hex head.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 01, 2011 | Rheem 81VP20S/430157 Water Heater
Where is anode rod located on 100 Gallon rheem water heater natural gas
Anode rods for tank-type water heaters are located on top of tank.
This is true since anodes are about 44" long.
Top of anode is standard 1-1/16" hex nut.
Anodes can be located in 2 different places: either directly screwed into top of tank -or- attached to hot water nipple.
Most times the exploded parts diagram in manual simply shows 'anode rod' without specifing exact location. If your tank has long warranty, then it can have two anode rods, and 1 will be on top and the other probably attached to hot water nipple, or there could be two anodes screwed into top of tank.
If anode is screwed into top of tank, then it will be under a plastic cap -or- it will be concealed under the top cover of tank.
Look for plastic cap, and if none shows, then remove screws holding down metal cover and look there for 1-1/16" hex nut.
Lastly, remove hot water nipple and check for anode located there.
If you have 2 anode rods, then replace with same metal for each.
Add a comment for more free help.
Mar 22, 2011 | Rheem Water Heater Anode Rod AP12938
How do I Remove Magnesium Anode ?
The following page has instructions and a link to a video:
How to:
Rods are installed in top of tank.
Most are located under a 2" round plastic cover located on top of tank.
Some anode rods are connected to hot water nipple
Read owner's manual to see location of anode rod
See list of water heater manufacturers and brands to find product manual.
Before starting, turn off heater source: electric water heater: turn off circuit breaker; gas water heater move control knob to pilot.
Close shutoff valve on cold water side of water heater
Open bathtub faucet to relieve pressure and let air into water line.
Open drain valve near bottom of tank,, and drain 2 gallons of water.
Use 1-1/16" socket for hex head rod
Rod will be rusted in place, use generous amount WD-40
WD-40 spray is flammable and will burn so be careful around heat source.
Loosening rod: go slow and check that water does not seep up when loosening rod because hot water can spew out hole if tank is very hot ... it is important to drain enough water out of tank to avoid accidental scalding.
Install new anode rod: One source says/ use pipe compound on thread instead of teflon tape. Other sources say use teflon tape. Either way, tank metal and anode metal must meet, so rod will work.
Dec 23, 2010 | Water Heaters
Heating & Cooling Logo
231 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
