Question about Hoover F7431-900 SteamVac Vacuum
The brushes stopped turning - Hoover F7431-900 SteamVac Vacuum
Just repaired mine today same problem.
Turbine drive shaft which drives two sets of plastic gears and which in turn make the scrub brushes rotate has sealed ball bearings and I guess from an evidently poor design moisture some how entered plastic gear casing and the sealed bearings froze up which evidently aren't sealed all that well. Anyway (turbine drive after easy removal from unit 8 screws on bottom one on top can be disassembled by removing 4 screws around gear casing allowing access to the plastic drive gears and the bearings) You can make a decision from there of whether or not a new replacement turbine is a better way to go.
The entire turbine unit can be purchased online for a very reasonable price if you look around the Web.
Posted on Dec 20, 2008
Hoover steamvac 50 stopped spinning
Hi! The brushes can stop spinning if something is obstructing them such as carpet fibers, hair, dirt or debris. Remove the brushes from the cleaner by grasping the plastic outer housing and pulling firmly away from the cleaner. Remove any debris and run it under running water to clean. On the back of the brush-block assembly there's a plastic drive pin that rotates all the brushes when turned. Turn the drive pin and ensure that all brushes are making a complete 360° degree turn. If the brushes are getting stuck or if a brush falls out then the brush-block will need to be replaced. Follow the link here to order a replacement brush-block for the Steamvac Search Results. Below is a list of models this brush will fit.
F5912-900, F5914-900F5915-100, F5915-900, F5915-905, F5917-900, F5918-900, FH50041, FH50042, FH50043, FH50044, FH50045, FH50046, FH50047, FH50048CA
Hope this helps!
Jun 20, 2014 | Hoover Vacuums
Eureka 4870 brush won't stop turning in upright position
there will be a linkage that as come loose and not operating the limit switch to turn it off, try looking at 23. Idler Clamp Assembly on the link below.
http://www.vacpartswarehouse.com/Eureka-4870-Ultra-Smart-Vac-s/1928.htm
Jan 27, 2013 | Eureka Smartvac 4870 Bagged Upright Vacuum
The rotator brush stopped turning. it turns fine
The brush roll will only spin when your handle is not in the locked upright position, once the handle goes upright - the brushroll de-activates
Dec 22, 2009 | Kenmore Progressive Bagless Upright with...
Irobot roomba brush only spins on hardwood/tile. brush stops when it hits carpet. motor prob's? fix?
Remove and clean the yellow bearing on each brush, then reinstall them. Run the Roomba and ensure that the brushes do turn on hardwood, then test it again on carpet. If the brushes still stop turning on the rug, call customer support at 1-877-855-8593. They'll be able to determine your warranty status and discuss your options.
Aug 05, 2009 | iRobot Roomba 4300 Robotic Vacuum
While using the vacuum, the brushes stopped turning.
check the drum. Hair will rap around the axxel and stop the brush from turning. Cut this hair with a razor and place a small drop of oil on the end of the axel.
May 08, 2009 | Kenmore 23313 Whispertone Bagged Canister...
The brush bar on my Dyson DC17 stopped turning.
If this model has a brush control - i.e a roller at the side of the model which controls brush to spin or not, then its a protected brush model - therefore even if the drive belt is intact the Dyson would have to be repaired by a service personnel or professional. The brush protection isn't able to be taken apart and sounds like it may well have slipped off due to tension.
Mar 31, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Premalite vac brush stopped turning
Not familiar with thi sbrand, but a reset is for when the brushes get jammed pr stalled, it will trip the reset. Make sure that the brsuh roll turns easily, also for a broken belt and/or bad brush roll. Some resets are for when the vac motor over heats, it will trip saving the motor. Usually this is for a jammed brush roll or a clog.
Apr 23, 2008 | LG Electronics Premalite Vacuum Bagless...
Beater bar brush stopped working...
Does the power head motor stop, or does the brush roll stop. If it is the brush roll stopping, replace the belt and/or the brush roll. If it is the motor, you may need to clean out around the motor, it may not be getting enough air to cool causing it to overheat and stopping. That the brush roll plate off, take out the screw, and the top will come off, then you can check to see if cleaning is the answer, if not, the motor may be bad.
Jan 12, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Vacuums Logo
223 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
