Had the TV on the other day and went to the mailbox, when I returned a few minutes later the TV was off and the button that turns the TV off and on was blinking (red). I Unplugged it several timie but keeps blinking. The TV is 5 years old and been in the shop 5 times to fix various problems. Im ready to give up unless this is a simple fix.
I beleave you have bad convergence ics . when thay shorted thay probly took out 2 chemical fuse parts 2 stk392-110 2 5 amp chemical fuse
Very common problems with this TV set. Toshiba even has a technical bulliten on this and several other models of tV set. The negitve terminal of C809 and C810 need to be soldered, as there are no eyeletes in the printed circuit board. This problem could also take out the fuse, F860. Replace if necassary. Good Luck
