By Ryan - usenet poster
Why is MD capacity always the same (74:59 exactly) regardless of how much redundancy there is in the recorded music?
Solution #1
posted on Aug 08, 2005
maartenw - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
On a frame by frame (11.6 ms) basis, ATRAC is always trying to give as much resolution as it can to each spectral component that it deems important. However it is continually short of bits, and except for the case of zero input, or a very simple signal (e.g. a few pure tones), ATRAC is using all the bits per second it has available. If it had more bits per second available it could use them, and record the signal with better sound quality.
In Sony's AES paper on ATRAC they talk about the bit allocation algorithm, and how it in general allocates more bits than are available, so they have a method for subtracting an offset from the allocations in order fit within their bit budget for a sound frame.
In the zero or simple input case, there can be unused bits in some frames, but since there is an unvarying (i.e. fixed) relationship between 11.6 ms of audio and a 424 byte "sound group" on the disc, the system is not flexible enough to actually take up less disc space when it doesn't need it.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Onkyo MD-P30 Personal MiniDisc Player
Email this problem
Email this problem
This Problem Also Relates To:
Panasonic SJ-MJ70 Personal MiniDisc Player
Panasonic SJ-MJ75 Personal MiniDisc Player
Panasonic SJ-MR100 Personal MiniDisc Player
Panasonic SJ-MR200 Personal MiniDisc Player
Panasonic SJ-MR220 Personal MiniDisc Player
Kenwood DMC-J3 Personal MiniDisc Player
Sony Walkman MDS-JB920 Personal MiniDisc Player
Can you Help with these Personal Audio Mini Disc Player problems?
stereo system problem
i have a jvc compact component... Answer This...
mini disc player technics...
hi there i noticed your... Answer This...
Sony 3 cd Player.After a power...
This Hi Fi is approx. 4 years... Answer This...
Repair Service
Find Personal Audio Min. Repairman Near You:
