Question about Singer CE-100 Futura Computerized Sewing Machine
"START" ON MACHINE FUTURA CE-100
I'm trying to use my machine to embroider for the first time. After transmitting to machine it says to push "Start" on the machine. Where's the start button? I've tried pushing every button, nothing works. My manual doesn't show it either.
  • 8,197 Answers
The start switch is the Led indicator buton. You will see it on page 12 of your manual. It is on the right of the needle bottom button.
Good Luck
Please Rate FixYa!
Posted on Dec 19, 2008
My futura ce 200 quantum embroidery machine is all set up to embroider and the green light is on when I push to start nothing happens. When I push the back stich it goes back to the orginal position and...
Change the fuse in the plug failing that it could be the inline fuse inside the machine normally near where you plug the lead in, if youcan get to that it is a matter of changing it, and the Hoop must be detachedwhen powering on! Otherwise it will not start. Hope this will help you. Good Luck.
Jul 20, 2011 | Singer CE-200 Quantum Futura Computerized...
Singer futura ce-100 wont start
Do you still have the embroidery arm attached? If you do, the sewing function of the machine won't work.
Mar 24, 2010 | Singer CE-100 Futura Computerized Sewing...
I have the futura ce-100. When embroidering it
This annoys the heck out of me, cause it happens a lot more than it should. There can be some valid reasons as to why it happens, though.
Your top thread could be broken or about to break; your bobbin thread could be broken, about to break or empty/about to become empty and is loose around the bobbin; you could have a birds' nest (a mass of thread just under the fabric/presser foot and/or within the feed dog and bobbin) forming and causing a jam; or it could be your Futura having a little bit of a hissy fit. Obviously, if you've checked for broken thread you need to move on. Check for a birds' nest by removing the fabric and clip your threads. If you find one, clear it, rethread your bobbin and begin sewing again. If there's no birds' nest, then place the fabric back in and try sewing/embroidering again. If the machine acts up again, I recommend removing the fabric/hoop, rethreading your top and bobbin threads, replacing fabric/hoop and resuming where you left off. If the machine still gives you trouble, try hitting the start button for a couple of times and seeing if the problem doesn't simply resolve itself. When you're embroidering areas that have a few small, short stitches only, the machine seems to act up a little and then behaves fine once you bypass the area. Be sure to take all of the other steps first, though, because a birds' nest will RUIN a beautiful seam or embroidery.
Mar 22, 2010 | Singer CE-100 Futura Computerized Sewing...
Design is ready, when green light is pressed nothing happens
I have had good luck contacting the Singer peoplee themselves. Sometimes it takes a couple of days for them to respond. But, if that doesn't help try this.
Can you go forward a few stitches annd then start?
If not, try condensing your design by 1-2%. This was recommended to me by Singer when I had part of a design that wouldn't stitch out. It did the same as your whole design. I tend to think it is the digitizer, not the machine in my instance. Have you tried another design by a different digitizer?
Hope this helps.
Jul 19, 2009 | Singer CE-100 Futura Computerized Sewing...
Futura 100 Embroidery machine...Need to cancel previous transmit
Had the same problem. Singer rep. solved this mystery in just min. after talking to her.
You can call singer company at 1-800-4SINGER. It will take a long time to get through, but they can talk you thru to resolve this matter. Or just visit singerco.com and go to F&Q section, #7 question.
Or you can email talktous@singerco.com (that's talk to us @ ...)
They answered my email the same day!
Hope this helps!
Jun 19, 2009 | Singer CE-100 Futura Computerized Sewing...
Futura ce-100 embroidering in the wrong place
I decided to simply start from the beginning and start all over. I turned off the machine, detached the embroidery unit and blew into the sensor (where the machine and embroidery unit connect). I'm not sure what the problem was, but it was fine after that! Just goes to show that no matter how frustrating things can be, it pays to just take a moment and start over!!
Feb 18, 2009 | Singer CE-100 Futura Computerized Sewing...
A brand new Singer Quantum Futura CE 200 Sewing/Embroidery machine, have not been able to embroider or sew a single stich, all I have been able to do is wind the bobbin. When I'm going to start...
Dear Magarita, The safety device is activated when thread gets entangled around the bobbin case. First check by removing the plastic see-through plate. If necessary remove the 2 scews on the metal needle plate and remove the bobbin case completely. Put it back and test by turning the handwheel. It should turn freely.
Hope this solves your problem.
Dec 08, 2008 | Singer CE-200 Quantum Futura Computerized...
Can't seem to embroider
brothers frame is much smaller I think 4 x 4. I have futura 200. found this to happen at first but now now. Make sure when threading that you floss the thread through the top part, it has plastic over it. The thread must fit properly in this part. (flossing means to run back and forth a couple of times holding thread tightly). Also, hold the 2 thread ends when you first start to embroider. Hope this helps
Apr 12, 2008 | Singer CE-200 Quantum Futura Computerized...
Singer futura ce-100 embroidery machine
Under the embroidery attachement (on the front side) is a lever to engage or disengage the "feed dog control." When embroidering, you need to move the lever to the level to disengage. The feed dog control should only be at the righe side position, or raised when you are not using the embroidery attatchment.
Jan 31, 2007 | Singer CE-100 Futura Computerized Sewing...
Will not sew
Try turning off the machine and turning it on again. Sometimes this will reset it so it will work. Also, make sure the embroidery foot is in the down position; the machine will pause and "beep" if you haven't lowered it. Hope this helps!
Nov 10, 2006 | Singer CE-100 Futura Computerized Sewing...
Singer CE-100 Futura Computerized Sewing Machine Logo
77 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
