Question about Compaq A3000 All-In-One InkJet Printer
Copies and scans with yellow streaks
I got this machine about 5-6 years and just recently began having this problem. I believe it may just need to be taken apart and cleaned as my hubby and I both smoke but am unsure how to do this. I have of course cleaned all the reachable parts.
  • Julie Stach Apr 01, 2007
    I would think if it was the print head I would have the same problem when I was printing. Prints come out fine. Also why would it cause yellow streaks when scanning documents to my computer?
  • 22 Answers
The streaks are probably caused by the yellow print head. This should be cured by doing a print head cleaning cycle in your machine menu or computer driver. If that doesn't fix it try cleaning the print head or replaceing the cartridge. The print head is located on the bottom of the cartridge. Use water and a cotton towel and gently clean the build up of ink. Just remember you may have to change the cartridge if this doesn't fix the problem. One more thing. There could be ink built up in another area causeing this also. This would require a technician. Thank you for your question, Bill
Posted on Apr 01, 2007
  • Bill Tucker
    Bill Tucker Apr 01, 2007
    Sorry, I misunderstood. If it is having lines when it scans and copies it is in scanner. There may be something stuck on the slit glass. I have an article that covers this subject. It will be easier to just give you the link.
    http://copierexpert.blogspot.com/2007/03...
Why do copies in color have multicolored streaks while black & white are fine?
There is a good chance that your color ink cartridge needs replacement. You can tray wetting a paper towel and putting in the microwave for 5 to 10 seconds then placing the cartridge on it for a few minutes. This sometimes will correct that type of problem...Be careful the paper towel will be hot (handle with care).
Aug 04, 2014 | HP Officejet Pro 8600
Konica minolta 4690mf color streaks
replace the image unit for yellow and magenta
try this site for parts as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 22, 2014 | Konica Minolta Magicolor 4690MF...
Barcode scanner won't read printed labels
1. The printhead in your printer might be scratched (evidenced by thin white streaks through your print). This is common, and the most likely cause. Printhead must be replaced.
2. Material might be stuck on your printhead (usually evidenced by wide white streak vertically through print). Printing surface of printhead can be cleaned with rubbing alcohol and cotton ball.
3. The ribbon might be wrinkling due to uneven tension, producing intermittent diagonal streaks in your print. This is somewhat common, but doesn't fit your description as well as 1 & 2 above. Mechanical adjustment and/or proper media loading solves ribbon wrinkles.
4. Poor pressure and/or printhead alignment. Evidenced by grainy, light or no print on one side or the other of the media. This is somewhat common, but doesn't fit your description as well as 1 & 2 above. Mechanical adjustment solves printhead pressure and alignment issues.
Dec 11, 2012 | Datamax E-Class E-4203 Label Printer
Copier, Printer black streaks on copy or all black page
Hello sir; Either drum cleaning blade or drum cartridge needto replace.
Aug 20, 2009 | Brother Office Equipment & Supplies
Developing mirror needs to be cleaned. Copies have streaking and fades in and out. The technician said it was due to toner on the developing mirror. How would I clean this mirror and save the $100+ for...
Hello sir; I never heard about developing mirror, only have scanning mirror, the problem you descript, I believe is developer drum and drum blade need to replace if your machine come with cartridge then you just replace whoek cartridge.
Aug 18, 2009 | Minolta EP4000/5000 CS/PRO Copier
I have a BROTHER MFC- 8860DN that makes black streaks on copies
If this is only happening with copies and not straight prints, it is possible that the problem is with the scanning unit. Use the soft cloth to clean the scanner area to the left side of the machine where pages are scanned when run through the page feeder. A spec of dust or other debris in this area will appear as a streak along the length of the page.
If it occurs on all prints, You may need to replace the drum or clean the fuser unit.
May 29, 2009 | Brother MFC-8860DN All-In-One Laser...
Canon 3220 I/R Jams, leaves blue/yellow streaks
Hi i am a canon technician that do a lot of work on these machines, i have seen many of these machines do over 1 million copies and rarely break down they usually are very reliable,
your streak colour problem sounds like it needs a ITB cleaning blade, if you open the front cover and release the waste toner bottle it sits in behind there just undo one screw and slide it out have a look and see if the blade is yellowish if so you need to replace it. Photocopiers are made to work all day they never need to rest, just rememeber these machines do have small drums but are good for 40k black at 10% coverage.
believe me get a new technician,
feed rollers in trays are good for 100.000 prints i like to change them about 60,000 copies but seen the feed rollers to 100,000 many times.
Prob the biggest problem with these machines when first realesed were low fuser volume about 80k and pretty stuffed heat rollers but they have fixed that issue now.
hope all this helps,
p.s. Ring canon direct they will give you a good local dealer to deal with
Regards canon Tech
Apr 02, 2009 | Canon imageRUNNER C3200 Copier
Bad copies on our Canon ir2200
Most likely the fixing film needs to be replaced. A few years ago Canon made the fixing films available to authorized dealers.The film itself should only cost a few dollars.The other thing might be the Drum unit itself.They are not so cheap.Independent dealers and service agents are generally cheaper than say, Ikon or Danka
Mar 26, 2009 | Office Equipment & Supplies
Yellow streak through color image scan
http://www.carlmcmillan.com/CanonScanner/Canon.htm
Feb 25, 2009 | Canon CanoScan 8400F Flatbed Scanner
Compaq A3000 All-In-One InkJet Printer Logo
Top Compaq Office Equipment & Supplies Experts
Damen Wong
Damen Wong
Computer Links
Alun Cox
Are you a Compaq Office Equipment and Supply Expert? Answer questions, earn points and help others
