Question about Uniden Cordless Phone
One line cordless phone
When I pick up a call on the base phone then ask someone to pick up on a remote phone it will not connect
    Problem Solver:
  • 7 Answers
Does your base have have a transfer button on it? If so try to transfer that call to the other phone.
Posted on Dec 19, 2008
What does Out of Range or No Power at Base mean?
Hello, Gwen -
If you are asking about a cordless land line phone. . .
"Out of Range" means the handset has lost its connection with the base station. Cordless phones are actually forms of radios. They need to be in radio wave connection with the phone base.
"No Power at Base" means that the electric power cord for the phone base is not plugged in or loose in the electrical outlet or that the batteries in the cordless handset need replacing.
Read information here:
http://bt.custhelp.com/app/answers/detail/a_id/10835/~/why-does-my-cordless-phone-keep-showing-searching%2C-base-or-range-out%3F
Sep 01, 2018 | Lands Phones
Connecting to base
read the user manual as the handsets have to be registered by the base unit to be connected
the main base is the operational unit
the other bases are just cradles to hold the phone while it is being charged
May 03, 2017 | GE / Rca Visys 25424re1 4- Line Corded...
Turn ringer on
Go to Settings > SOUND > Silent mode (No sounds except media and alarms).
If this is ticked (on), it means umts smartphone alarm will sound even if you make the phone silent.
Regarding the loud sound even after reducing ringer volume, no idea for this.
Dec 03, 2011 | Panasonic KX-TG2383 Corded Phone
I have a Uniden cordless unit hooked in 4 lines. Incoming calls ring briefly for about 1 second and go out! You can talk if you pick up but not sure why no normal rings. There is no problem calling out....
When someone calls you and your phone behaves this way, does the caller get disconnected? The phone may be causing this, but it may also be due to trouble in the telephone line itself. The trouble is caused by defective wiring, a partial short circuit. When you pick up your phone to call out, the voltage on the phone line is low and it works normally. When you get an incoming call, a high voltage is sent to ring the phone. Because of the partial short, the phone company's equipment thinks you've answered the call as soon as the ringing starts. But you haven't picked up the phone, so the phone company's equipment thinks you've hung up and disconnects the call. The result is that short burst of ringing.
Disconnect the cordless phone base unit from the line and try another phone. If you still have the trouble this confirms the line is at fault. You'll need to contact your phone service provider for service. If it's in the outside wiring, they're responsible for repair. If the problem is in your home wiring, you may need to pay them unless you have a wiring maintenance plan.
If the problem goes away when the cordless base is disconnected, then it's time for a new phone.
Jul 16, 2011 | Uniden Cordless Phone
Had a bad electrical storm. The next day my cordless AT & T phones ( 1 base with answering machine and 1 remote phone) had no dial tone. They both ring on incoming calls but unable to connect. They...
The damage is not to the phone line it is to the phones. Unfortunately this is very common with powered phones as they are almost never kept on surge protectors and are very fragile. You will need to purchase a new base station to use with existing phones.
Apr 29, 2011 | AT&T 650530003417 Cordless Phone
Panasonic cordless phone KXTG2431 discharge too fast
Hi,i'm hamed from IRAN
I have a panasonic phone model:KX-TC1282JXB and it has a problem: Discharge very soon the battery and recharge hardly or phone can't recharge it !?
<< My dicovery solution worcking 100% >>
Steps:
1-remove battery from remote-handel.
2-create two wires.
3-the jumper of battery must have two wires(red & black).
4-contact you're created wires to jumper of battery.
5-be careful! now you must connect two wires to base of phone where the remote-handel settle there at below be exist two slots "phase+" and "null-".
note: when you connect correct,the green lamp must be shining.
Recommend: (near slot by base keyboard connect black wire) and (other slot connect red wire).
6-connected battery must be take between 45min - 75min.
note: the battery to be warm don't worry, just control to pass time.
7-then release base and battery form two wires.
8-connect the battery to remote-handel,you can see it has charged for minimum amount (one-unit)
9-finally connect remote-handel to the base for give full charge,it take between 8h - 12h.
you can ask me you're question(s) : hamedsbt@yahoo.com
bye :-)
Jan 24, 2009 | Panasonic KX-TG2431 Cordless Phone
Working one set of Vtech 6041 cordless phone set with another?
I have the vtech dect6.0 with one answering system and two remote docking systems.I can phone out from the remotes but cannot receive incoming calls from the remote.When I pick up the remote to receive the phone immediately shuts off.
Aug 19, 2008 | Vtech Cordless 6041 Phone
I need to reactivate my uniden cordless phone with remote extra handset. It was on a second phone line in my home, and that phoneline has been cancelled. Now, both units are charged, but and plugged into...
This should get the job done for you!
To re-register DXA14588-2 handsets:
  1. Pick up the handset from the base. Press and hold [find handset] on the base.
  2. While holding [find handset], place the handset in the base. The charge/in use LED on the base begins to flash, indicating the base is registering the handset. Wait for at least five seconds.
  3. Pick up the handset from the base and press [talk/flash]. If the display shows TALK, the handset is registered. If not, place the handset in the base to try again.
  4. Press [end].
  5. Place the next handset in the base and wait for at least five seconds. No need to hold [find handset] this time.
  6. Repeat steps 3 - with any other handsets you have.
Please let me know if you have any further questions.
Good Luck!
Aug 11, 2008 | Lands Phones
RCA ViSYS 25450 cordless handset
Quickly, return this Phone is you still have a chance, my small business used this phone for EXACLY 2 years, and now all lines are DEAD, NOT A SINGLE ONE WORKING. LINE ONE AND THREE HAVE NO DIAL TONE EXCEPT EXTREMELY LOUD STATICS. AND LINE 2 AND 4 ARE TOTALLY MUTED.
A lot of my customers are complaining about not being able to reach me in my office.
Apr 10, 2008 | RCA 25450 4-Line Extended Range Multi...
Line will be busy with static
you need to replace the phone with a new one .
Feb 26, 2018 | Panasonic KX-TG6702B Twin Cordless Phone
Uniden Cordless Phone Logo
29 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
