Question about Kenmore Elite 45986 Front Load Washer
Kenmore front load washer won't drain
I have a Kenmore front load washer that won't drain... I washed a comforter today and it appears the washer got 'stuck' after the wash cycle. There's probably a good 2 inches of water in the machine. I read somewhere that it may be the water pump but I can't find where the water pump would be...nor can I find the manuel... any suggestions would be helpful
Thanks
  • TV2mora Dec 20, 2008
    I HAVE A HE 2 PLUS FRONT  LOADER,I AM HAVING THE SAME PROBLEM. THE WASHER WILL NOT DRAIN,
Fixed itself
Posted on Dec 20, 2008
Water will not drain out of the washing machine and won't complete cycle.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 10, 2011 | Kenmore Washing Machines
I have a Kenmore Elite washer, model 44092. The machine won't spin and the error code is E20. What is wrong with it?
The machine, based on the error code, is made by Frigidaire for Kenmore. Error code E20 pertains to a slow or no drain problem which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code.
Error Code E20 on Frigidaire and Frigidaire-made (including Kenmore) Front Load Washing Machines
Aug 20, 2011 | Washing Machines
Machine won't spin, therefore water cannont be emptied. The agitator works. I have a top open Kenmore 90 series machine.
heatman101
Aug 14, 2011 | Kenmore Washing Machines
Washer will wash but won't spin or drain
heatman101
Aug 11, 2011 | Kenmore 22422 Top Load Washer
My washer won't spin and drain. what should I do?
heatman101
Aug 09, 2011 | Kenmore Washing Machines
My Kenmore washer 20432990 will fill and agitate but won't drain or spin. When I push down on the lid switch I hear nothing but when I let it go I hear a faint click.
heatman101
Jun 15, 2011 | Kenmore Washing Machines
Front loader won't spin and is filled up with water. Won't drain.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
May 15, 2011 | Kenmore Energy Star 44092 Front Load...
I have a 4 year old Kemore HE2 that isn't spinning the water out of the clothes. I encountered this issue about a month ago and found a fix for cleaning out the hidden pump trap. After removing a large...
heatman101
Sep 07, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore front loader not draining.
Hi, UNPLUG the washer and shut off the water. Remove the lower front panel and you can access the water pump. You will need a wet/dry vaccuum to **** up the water as you open the sump cap on the pump. Spmetimes you can lower the drain hose into a bucket and get water out. Once the water is removed, open the cap and see if the filter is plugged as well as the pump inlet/outlet ports. This is common. If there are no obstructions, check voltage to the pump. it should get 120V.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 04, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore HE front load washer
seems to be a fault design in the doorlocks, fit new lock
Nov 16, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
215 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
