Question about Canon PIXMA MP960 Printer
What kind of "major virus" was on your computer? Some of those can re-write the firmware in printers!
Posted on Apr 24, 2017
SOURCE: iP4300 only recognizes magenta OR cyan
1. Get compressed air
2. Run Printhead under HOT water, do not worry about contacts getting slightly wet.
3. Blow compressed air with straw attachment into screens where the cartridge nozzle sits on printhead. then let it sit and dry.
4. reinstall print test page
5. if this fails open paint/photoshop and print a page of the color that is not printing correctly. rinse and repeat until colors flow freely.
I have several ip4300s and I have yet to give up the ghost on a printer with a clog ujsing this method.
Posted on Jan 21, 2009
SOURCE: I have an older Pixma iP4000 and a new PC with
Are you running Vista if so you may need to update the driver if they have one.
Posted on Nov 13, 2009
SOURCE: Hi, When printing photos, my
Epsons are notorious for this sort of problem, especially in used infrequently as ink residue dries on the print head; try using a cleaning cartridge, or swab around relevant print head with cotton bud and ethanol/isopropyl alcohol. Here are examples of cleaning carts, there are others http://www.internet-ink.co.uk/epson-cleaning-cartridges/ http://www.icompinkcartridges.co.uk/epson-r200-r300-r220-r320-r340-cleaning-kit.html
Posted on Jan 03, 2011
SOURCE: nozzle test does not show pattern for either BLACK
CANON MP780 BLACK DOES NOT PRINT This is what works for me. Try at your own risk. I cleaned both areas. CLEAN PRINTHEAD: Perform a nozzle check using the Canon software under "maintenance." If the nozzle check prints successfully, the problem is most likely not with the printhead. Otherwise, 1) Lift up the lever above the ink cartridges. Take the ink cartridges out. Put them in a plastic zip lock bag. 2) The container in which the ink cartridges sit is removable. The container is inside the moving mechanism. The container is the printhead. Tilt it slightly and pull up. This should come out easily. 3) There are round pads under which the ink cartridges sit in the printhead you removed. The large one is black. On the underside of the printhead are small slits. The **** separated from the others is black. Fill a syringe with Windex. a. Run warm water over the printhead until no more ink comes out. b. Fill the areas where the round pads are with Windex. c. Set the printhead on some paper towels. The liquid will soak through and come out the underside along with the ink. Repeat steps a-c until no more ink comes out, but at least 10 times. 4) Let the print head sit and dry for two hours. Put everything back in the printer. Unplug the printer. Plug in the printer. Turn the printer off. Turn the printer on. Do a clean cycle. CLEAN PURGE MECHANISM: You will need a light. 1) Unplug the printer and move the printhead all the way to the left. On the far right are two rectangular basins. The smaller one is black. Take your fingernail or a tweezers and lift out the sponge pad (do not drop it). Soak the sponge pad in Windex until it turns white. Plug in the printer. 2) Fill a syringe with Windex. a. Fill the basin with liquid. b. Let it soak for 5 minutes. c. Turn the printer off. d. Turn the printer on. Repeat steps a-d until you see a small hole in the basin. e. Put the syringe over the hole and fill the basin, pushing the liquid into the hole. f. Let it soak for 5 minutes. g. Turn the printer off. h. Turn the printer on. Repeat steps e-h 5 to 10 times. 3) Put the sponge pad back in using your fingers (do not drop it). Unplug the printer. Plug in the printer. Turn the printer off. Turn the printer on. Do a clean cycle.
Posted on Jan 04, 2011
Testimonial: "you hit the nail right on the head !! excellent!!! will be submitting question on another printer-hope you do as well. "
Jul 13, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Feb 06, 2011 | Canon PIXMA iP3500 Printer
Oct 26, 2010 | Canon Office Equipment & Supplies
Mar 19, 2010 | Canon Office Equipment & Supplies
Dec 04, 2009 | Canon PIXMA iP90 Mobile Printer
Nov 17, 2009 | Canon PIXMA MP960 Printer
Jul 09, 2009 | Canon i860 InkJet Photo Printer
Mar 04, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Feb 10, 2009 | Canon PIXMA iP90 InkJet Printer
Jun 05, 2017 | Canon PIXMA MP960 Printer
Dec 26, 2013 | Canon PIXMA MP960 Printer
Sep 08, 2013 | Canon PIXMA MP960 Printer
141 people viewed this question
