Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
My stackable washer will not put aby water out
  • 833 Answers
Generally, the problem is that the solenoid valve which either directs the water to the spray arms or to the drain is stuck.  Often, there is food debris in the valve.  You'll find it near the motor and connected to the waste line  Often, these valves can be disassembled and cleaned.  If not, the valve may need to be changed out if you can't get whatever is in there out.
Posted on Dec 19, 2008
I have lse7806ace (stackable) and problem with water leak. I live in condo and this washer/dryer stackable in small closet. I can't reach locking tabs. This stackable is also on the pan (bottom). 'BTW,...
Remove the 2 screws which hold the lower front washer panel , lift out from the bottom and remove the panel.You can now run the machine and use a flashlight to see where the leak maybe. Usually the top tub seal under the plastic tub cover will leak. The other possibility is the main tub bearing and seal on the main tub where the transmission goes up through tub. Hope this helps.
Feb 11, 2011 | Maytag LSE7806A Top Load Stacked...
Kenmore stackable washer wont work on Cold cycle only hot water
Here are a couple of tips that I wrote to help people that are having problems with the washing machine not filling...
Washing Machine2_bing.gif Problems No Water
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
Washing Machine Fix Washing Machine No Water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
heatman101
May 07, 2010 | Kenmore 98702 Stacked Washer/Dryer
Water under stackable washer dryer
The front panel comes off and you will be able to trace the water source. These combo units spin immediatly and if the drain is slow the water will spin up over the edge of the tub during drain.
Eric
Dec 24, 2009 | Kenmore 98702 Stacked Washer/Dryer
Neptune stackable -water left below the drum after cycle complete
Some water yes. a lot of water no.As long as the water stays below the wash tub you should be OK.
You might want to pull your water pump off and check for a restriction.
Mar 23, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Stackable kenmore model 41794702300
We have had that happen too. You will need to take out what ever has blocked the valve on the drain. Ours was a bobby pin! My model is a bit different but if you follow the drain hose underneath you can find it. Remember you are dealing with lots of water. I think I scooped out the water first and have some towels ready. Or hire somebody to do it for you. I hope that helps.
Sep 03, 2008 | Kenmore 98702 Stacked Washer/Dryer
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
79 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
