I have a 4 months old sony ericson 580i, the scrolling wheel acts as select meaning that i can't scroll thru my menus or my contacts anymore!!!!need help
SOURCE: I can't scroll up or down and sometimes the phone
dear,
open the casing of your phone and clean the key pad specially the left/right, up/down keys.....and then check it...
Dont use any contact cleaner or other liquid without removing LCD please... the spray will damage the screen...
regards,
SOURCE: sidekick 2008 trackball doesn't scroll down or left anymore
More than likely, the trackball on your Sidekick 2008 is really dirty. Overtime, dirt and grime gets in between the ball and the sensors.
It is really easy to clean it, you will need q-tips and IPA alcohol. No dis assembly is usually needed!
Check out the Video at the following link to see how the trackball cleaning on the Sidekick 2008 is done
Sidekick 2008 Trackball Cleaning Guide
SOURCE: the tracking ball has seized
best thing to do, other than taking it apart is to get a hard flat surface and a sheet of a4 paper, take any cases etc off the phone hold it flat down to the surface and then roll it around, i normally find in a circular motion works best, this frees mine up perfectly. failing that you will need to take it apart which isnt that hard and clean the pressure pad below the roller ball but this is a bit fiddly!
One of the major warnings Apple includes with all of its iPods is the permanent hearing damage that could occur if you have the volume on your iPod turned up too high.
To help combat the problem, the iPod comes with a feature that allows you to set a maximum volume level that your iPod can be played at that level is controlled by a combination that can keep others namely children from turning the volume up to dangerous levels.
The good news is, if that combination falls into the wrong hands, it can be reset.
Use your iPod's click wheel to scroll down to "Settings."
Press the center button located in the middle of the click wheel to select the settings menu.
Scroll down to "Playback" and press the center button to select it.
Scroll to "Volume Limit" and press the center button to select it.
Use the click wheel to scroll to the first number of the old combination and press the center button to select it.
Repeat this process for all four numbers of the old combination.
Use the click wheel to scroll to where you want the maximum volume to be set and press the center button.
Use the click wheel to scroll to "Lock" and press the center button.
Use the click wheel to enter the first number of the new combination when the message "Enter New Combination" appears on the screen repeat the process for the three remaining numbers.
Once the four numbers have been entered, your iPod's maximum volume will be set and your password will be changed.
hope this helps
hope this helps
