Question about Canon PIXMA iP3000 InkJet Photo Printer
PIXMA ip3000 printer is printing yellow instead of red
Starting yesterday my printer that has had no problems previously started printing yellow ink on documents that should have been red. Both the yellow and red ink cartridges have been replaced and it is still happening. Is there a way to fix this?
  • riddell652 Dec 23, 2008
    Help! It only prints yellow now! All cartridges are full. My computer is an iBook. AAAARGH!
I began having this problem several weeks ago. My "red roses" were yellow when I printed them. I cleaned all of the nozzles, rollers, etc as suggested by my users guide. I even replaced some of the colors. However, I decided to check the print head. I released the print holder, pulled out the magenta ink and cleaned the print head with a q-tip soaked in alcohol. Then I decided to clean the other print heads. Now my red is as it should be.
I am a novice at this, so you have probably done this already. I did not want to go to the expense of buying new print heads.
Good luck! Flo
Posted on Feb 11, 2009
  • 23 Answers
Clean the ink cartridge contacts with a moist tissue or glass/LCD cleaner clothe. Do the same on the printer cartridge holders. Do this gently and carefully avoiding further damages to your printer and it's cartridges.
Declog print heads using denatured alcohol for an hour or two or head cleaning agents available at any ink refilling stations. You can use a suction device included in the refill kit.
Try using another cartridge of the same type by borrowing from a friend, relative or member of the family and see if the problem still occurs.
Try removing the printer driver, restart computer then reinstall driver so that the default settings will be restored. If it still exist, you can google for iptool software and try resetting it's EPROM.
If the problem still exists, you need to go to the nearest service center.
Posted on Dec 24, 2008
Canon inkjet PIXMA ip3000 wont print and has 5 blinking yellow lights
Canceled the jobs on PC and verify the inks.If you use the refill inks perform the head cleaning in the mantenance mode.
Feb 13, 2013 | Canon PIXMA iP3000 InkJet Photo Printer
Color on photos suddenly has a blue - purple wash with no greens
Your yellow cartridge is probably not working as your photos suggest. Remove and reinsert the yellow cartridge. Try printing only yellow color.
Your printer has a separate head for printing; the nozzle for yellow ink might be clogged. Try running a head cleaning routine from your printer software.
Sep 15, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Can't switch up my Canon iP3000 printer
Problem solved - I bought a new printer. On a long run it is cheaper.   Thanks    Mila
Apr 10, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Ink not working properly on ip3000
clean the printer so the ink will come out. Don't worry i had the same problem trust me this works!!
Hope it helps
Jul 25, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
My canon pixma /ip3000 printer isn't using the yellow ink, I have installed new ink tanks and ran clean and deep clean printer head and manually adjusted the color setting to max, did not correct problem....
Repeated deep cleaning (about 12 times) has started to get the ink flowing again, I am printing something every day and hope the problem clears up totaly.
May 08, 2008 | Office Equipment & Supplies
Canon pixma ip3000
do nozzel clean in software utilty and cheak
Feb 03, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Problem with the color - Canon Pixma ip 3000 Ink Jet printer
go 2 printing preferances and make shore all your setting are on normal or higher and try again
Nov 28, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Printer uses too much yellow
This is the normal behaviour, since Yellow is the most common color in normal printing.
Aug 07, 2006 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
256 people viewed this question
old marine
old marine
mukhtar21 shaikh
mukhtar21 shaikh
