Question about Furuno 2.2kw 18" Radome
18'' radome ?
Will a Furuno 18'' radome hook up to a furuno gp-31 or a lowrance 104c?
    New Friend:
  • 132 Answers
No way no way no way sorry
Posted on Jan 16, 2010
Have a furuno fr240 mark 2 and rafar image return only when changing range. also when given time image slowly returns but later radar dies. what problem can it be?
Of course this could be many things, but it sounds like your auto clutter < labeled by Furuno as AC Sea Auto, is on and out of adjustment. Try turning off auto sea clutter and manually declutter the screen, should help, otherwise, 847-746-0100 will definately help you.
John
Jun 11, 2014 | Furuno 2.2kw 18" Radome
How do I repair a cracked Furuno Radome? The top white part is cracked from a tree branch
No, a quarter sized blank area around boat on lowest 1/8 mile range is normal. The dome cover is available for just over $100., so why risk a leak?
John 847-746-0100
May 01, 2014 | Furuno 2.2kw 18" Radome
Furuno GP-1800 GPS/Plotter switches on, display has only lights otherwise blank.
Try pressing the Brill or Tone key. Use the up arrow to increase Brill and the right arrow to increase Tone. Otherwise, you have an internal board failure and it will require service by tech.
Jan 27, 2014 | Furuno 2.2kw 18" Radome
Radar furuno 1721 mark-2
Must have RSB number and FCC ID number
Nov 09, 2013 | Furuno 2.2kw 18" Radome
I have bought a ICOM VHF m601 and I want to connect the furuno gps 31 to the VHF. Is this possible ?
Using the nmea output from your GP-31 to the nmea input on the VHF. Enable the GLL Sentence and make sure the port is set for nmea0183. Remember hooking nmea up it's positive to positive and neg to neg. Once that is done and you have a fix you should have lat and long on your vhf.
Mar 09, 2010 | Furuno GP31 GPS Receiver
Manual
http://www.mapsunique.com/ev/special-inst/furuno-30.htm
Here is a site that knows something about it. and to find where to buy one google it.
Sep 07, 2009 | Furuno GP31 GPS Receiver
Furuno radar antenna not rotating
yes, this is a common failure after hours and hours of use
Apr 06, 2009 | Furuno 2.2kw 18" Radome
The belt on the radome drive sprocket jumps off of
The belt pully on the motor has a set screw that tends to get loose causing the pully to change position on the shaft. Position the pully on the shaft (move up or down) for better alignment with the pully on the rotating array pully and tighten the set screw..
Feb 23, 2009 | Furuno 2.2kw 18" Radome
I've just bought a boat with a furuno gp 31 , no user manual .is there somewhere I can download one thanks.
Hello!
You can download one here:
http://www.furunousa.com/Furuno/Doc/0/5OS1KKAL2OP434ND790LNUEPEB/GP31-GP36%20Operator%27s%20Manual%20%20k.pdf
Copy the entire link into your browser and you should have it.  It is in PDF format, so if you need a PDF reader, go to www.adobe.com and get one for free.
Hope this helps,
Ken
Dec 06, 2008 | Furuno GP31 GPS Receiver
Furuno 2.2kw 18" Radome Logo
94 people viewed this question
Top Furuno Boating Experts
Daniel Dollive
Daniel Dollive
David Burbee
David Burbee
Shehu Pro
Shehu Pro
Are you a Furuno Boating Expert? Answer questions, earn points and help others
