Question about Acer Aspire 3000 Notebook
Case removal need to replace battery plug in on motherboard----mine seems to be broken some how.........seems to be a common problem ??????
    Novelist:
    Scholar:
  • 50 Answers
Here is some great source to solve any kinds of laptop's problem.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
Here is some another Great source to download any kinds of laptop Drivers.
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
>20
Posted on Dec 25, 2008
Where is the cmos battery? need to reset bios
You will have to open the case to computer to get to the motherboard. On the motherboard (This is the big circuit board that your CPU, Hard Drive and everything else is plugged into.) you will see a flat wafer battery that looks like a watch battery. CR2032 is the most common type of battery used with motherboards. Once you find the battery simply do the following.
1. Unplug your computer.
2. Remove the CMOS battery.
3. Discharge all power in the computer by pressing the ON switch with it unplugged
4. Replace the CMOS battery.
5. Plug in the computer again and continue onward.
Here is another walk through to replace the battery: http://www.computerhope.com/issues/ch000239.htm
Oct 16, 2013 | ASUS Eee Box EB1035-B010M Nettop Computer...
My hp compaq tc4200 wont turn on.if i plug power cable it shows charging after few seconds it wont charge i removed battery but the problem still
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test your compaq tc4200 power supply with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Jan 08, 2013 | HP Computers & Internet
My acer aspire 4730Z is not turning ON....battery is down....when am connecting dh charger pin to dh lap, dh green indicator of dh charger goes on blinking. Lap top is like completely dead dat even dh...
Possible causes:
1. Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
Replacement Acer Aspire 4730 AC Adapter 65Watt 19V 3.42A
Intocircuit Acer Aspire 4730 AC Adapter 65Watt 19V 3.42A
Nov 19, 2012 | Acer Computers & Internet
Charger is plugged but in not charging
I see that when the Adapter is plugged-in on the Laptop it does not charge, Have you tried a different AC Adapter to see if this is an Adapter issue or if this will be a hardware issue.
This concern can be an Adapter issue try a known good AC Adapter to see if the laptop will Charge or not if still it does not remove the battery and try the Known good AC Adapter to see if the Laptop will power ON using the known good adapter if it does then the issue can be the Battery or the Charger Board in the laptop now use the Old AC Adapter and see if the Laptop will as well turn ON with out the Battery if it does then the issue is either the Battery on the laptop or the charger board on the Laptop.
I hope this helps.
Oct 22, 2012 | Computers & Internet
I can't turn it on. it turns on for a second then off
Seems like the baterry is dead If the battery light blinks orange plug the ac battery adapter into the computer and into a outlet.
Dec 04, 2009 | HP Pavilion tx1000z Notebook
The little green light on charger goes off when i plug it into Dell Inspiron 6400, the charger works fine
Unplug the battery from the laptop and then plug the AC adaptor into the laptop. If the green light still goes off then your motherboard is shorting out the adaptor and the motherboard needs to be replaced.
May 17, 2009 | Dell Inspiron 6400 Notebook
Dell D510-won't come on
First try starting without the battery, just AC. Still nothing, then try removing the memory and placing one or the other chip in and starting, then change out chips. Both the battery and memory are common causes of a no start with Dell machines. If neither of these work, then it's a problem with the motherboard. Take it in for diagnosis, they will be able to tell you exactly where the problem is and if it's a replaceable component.
Jul 16, 2008 | Dell Latitude D510 Notebook
Power system problem
If the computer is running then I would guess the female plug is broken on the motherboard. You can get a new one and install it yourself if you know how. Its just a matter of openning the case and removing the bad plug and installing the new one. Reinstall the case and you should have the problem looked after.
Apr 18, 2008 | Dell Latitude C610 Notebook
Gateway MX8711 no power, battery.....what?
1steflik:
To disassemble:
1) remove the four screws on the rear of the two top hinges
2) fold the screen all the way back and unsnap the small bezel above the keyboard. Remove
3) remove three top screws holding keyboard, unplug, and remove
4) remove the center motherboard screw which was under the keyboard
5) Now you're ready for the main action: Remove battery, HDD, memory cover, memory
6) unplug WiFi antenna wires on bottom (under memory cover) and thread back through hole
7) unplug display and display backlight
8) remove all bottom case screws and top case screws
9) gently work around the top bezel, unsnapping it as you go around, and remove.
Apr 11, 2008 | Gateway MX8711 Notebook
Plastic part broke off my super nintendo where you plug the power cord in the back.
This is a common problem with the original version of the SNES console.
Unfortunately the fix is not an easy one. I fix these in my shop but I have done dozens of them. It requires soldering. There are two ways to fix it. You can replace the broken part which is soldered to the motherboard or you can solder on wires for a new receptacle.
To get the replacement part you would need to buy a broken SNES off eBay or somewhere and disassemble it to remove the needed part. If you find a busted SNES with a working motherboard you MIGHT be able to just swap it. I say might because I have found at least three versions of motherboards in these things and the mounting points inside the case are different for each of them.
To bypass the plug altogether you would need to find a new plug at Radio Shack and wire it up to the motherboard and attach it to the case so that the plug can be hooked up. You could also cut the plug off of the AC adapter and solder the adapter wires directly to the motherboard.
Like I said it is not an easy fix. It also has a high probability of not working if you do not know what you are doing. It might be best to just buy a working console from a reputable seller and sell yours as broken.
Good Luck.
Mar 02, 2008 | Nintendo Super NES Console
Acer Aspire 3000 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
