Question about SanDisk Sansa Clip MP3 Player
I can not get it to charge or power on.
When trying to charge the screen repeats connected. It did start out by saying writing then repeated connected.
  • 1 more comment
  • JaimePiedra Dec 19, 2008
    plugging the clip into my computer powers it up and "connected" flashes across the screen, and occasionally "writing" but charging doesn't occur? what gives?
  • Britany Ball Dec 20, 2008
    My sansa clip wont charge or turn on.... It was working fine for a month then all of a sudden it wouldnt work!!!!!
    WHAT DO I DO??????
    S.O.S.
    SAVE - OUR - SANSA
  • Anonymous Dec 21, 2008
    its driving me nuts
I bought a third party charger (Belkin) for $10 and my Sansa Clip now it gets charged just fine... I still can't figure out why it doesn't charge off the computer, but this is actually way more convenient anyway.....
Posted on Jan 02, 2009
  • 8,596 Answers
Colon and Jaime - that is normal behavior for the Sansa
inuy:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jan 01, 2009
Proscan tablet won't turn on
Try this. Plug your charger in. Then press the power button repeatedly until the screen comes up with a charge icon showing.
Hold the power button down until the blue screen comes up. Then if it boots up just leave the tablet alone and give it some time. You should see an android come up and then a scan of the android words start . This takes time. Don't be impatient . It may boot into a factory reset mode. Just start again with the factory screen.
You can try repeating the process if it doesn't work the first time.
Mar 22, 2014 | Proscan 10.1-Inch Internet Tablet,...
I would like yoknow what format do i need to download a video to my vl-567
Supports MP3 / AMV / WMA / WAV / JPG / TXT
----------------------------------------------------------------------------------------------------------------------------------------Model: VL-567k / VL577k
  • Built-in Memory: 4GB Flash Memory
  • Supported Formats: MP3, AMV, WMA, WAV, JPG, TXT
  • FM Tuner: Built In, Radio/Auto Scan/Store/Erase
  • Lyrics: Yes. Supports .lrc format.
  • Data Retention: 10 Years
  • Voice Recorder: 200 Hours with recording rate of 8khz
  • Voice Mode: Selected content repeat function (A-B mode)
  • Weight: 1.3 oz.
  • Dimensions: 3.6in x 1.6in x .34in
  • LCD: 1.8" Anti-Scratch True Color 65,000 color.
  • Equalizer: Natural, Rock, Pop, Classical, Soft, Jazz, DBB
  • Repeat Mode: Normal, Repeat Once, Repeat All, Repeat Folder, Random, Intro
  • Battery: Rechargeable battery, ~3-5 hours playing time when fully charged, ~10 hours charging time through USB port
  • File Transfer Speed: Reading (700 kb/s), Writing (400 kb/s)
  • SNR: 85db
  • Output Power: 5mW+5mW
  • Output Range of Frequency: 20Hz-20KHz
  • PC Interface: USB 2.0
  • System Requirements:
    • Windows 98SE/ME/2000/XP
    • 166 mhz cpu or faster
    • 32mb of RAM
    • 20mb available disk space
    • Available powered USB port
Dec 26, 2010 | Visual Land VL-567K Digital Media Player
I try to turn on my laptop, and it won't turn on. When it originally happened I was on it, without the charger plugged in, online. It was working fine, and then all of a sudden it shut off, and will no...
Your battery is probably completely discharged. This can prevent the laptop from starting even WITH the power plugged in. You might try removing the battery, then plug in the AC power adapter. Push the power button and HOLD IT down for 30 seconds (your laptop may or may not start up. If it starts, then shut it down normally.)
Replace the battery. With the AC still plugged in, repeat the start proceedure above. Leave the laptop on until the battery is fully charged. If this doesn't work, then your battery may be bad (this can happen all at once) or worse, your charging system isn't working (less likely.) Your power adapter could also be bad - is the green light on when it's plugged in?
You may have to repeat the proceedure a few times before it works as the battery needs to show a little charge before it will start.
Once started, press F2 while on the dell logo to go to the setup screen. Select the power options. and you should see if the battery is detected. If battery is detected, it should say "charging".
If none of this works, call Dell technical support 800 822-8965 for further assistance
Nov 29, 2010 | Dell Inspiron M5030 Laptop
What do i do when i my ipod touch says ipod touch says ipod is disabled
Try restoring it...here's how...
  1. Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
  2. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
  3. Press and hold the Home button while reconnecting the USB cable to iPhone. When you reconnect the USB to iPhone, the device should then power on.
    Note: If you see the message "Charging... Please Wait" , let the device charge for at least 10 minutes to ensure the battery has some charge and then start with step 2 again.
  4. Continue holding the Home button while iPhone starts up. While starting up, you will see the Apple logo.
  5. When you see "Connect to iTunes" on the screen, you can release the Home button andiTuneswill display the recovery mode message:
    If you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPhone and repeat steps 3-6.
Sep 07, 2009 | Apple iPod touch
My ipod is so screwed up PLEASE HELP
you can reset its password....but you'll lose all your data. Here's how...
  1. Verify you have iTunes 7.5 or later. Apple recommends using the latest version of iTunes.
  2. Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
  3. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
  4. Press and hold the Home button while reconnecting the USB cable to iPhone. When you reconnect the USB to iPhone, the device should then power on.
    Note: If you see the message "Charging... Please Wait" or you see the screen pictured below, let the device charge for at least 10 minutes to ensure the battery has some charge and then start with step 2 again.
  5. Continue holding the Home button while iPhone starts up. While starting up, you will see the Apple logo.
  6. When you see "Connect to iTunes" on the screen, you can release the Home button and iTunes will display the recovery mode message:
Sep 03, 2009 | Apple iPod touch
How can i fix and ipod touch that says ipod is
You'll hv to restore the ipod..here's how...
    Note: If you see the message "Charging... Please Wait" or you see the screen pictured below, let the device charge for at least 10 minutes to ensure the battery has some charge and then start with step 2 again.ht1808_01.jpg
    ht1808_02.jpgIf you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPhone and repeat steps 3-6
Aug 26, 2009 | Apple iPod touch
My IPOD touch is locked and my daughter forgot the passcode. We don't have access to the computer with the original itunes. The IPOD says to connect to itunes. itunes says it cant connect because there...
all you hv to do is go thru the earlier posts with the same problem....anyways here's the solution again...
    ht1808_02.jpgIf you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPhone and repeat steps 3-6.
Aug 15, 2009 | Audio Players & Recorders
How do i fix an disabled ipod touch ? it say try again in 4,746,824 minutes and i cant unlock it eather
you can reset its password....but you'll lose all your data here's how...
Aug 14, 2009 | Apple iPod touch
How do i remove write-protection from MemoryStickPRODuo from psp?
1. Remove memory stick from psp
2. Plug in usb cable and start usb connection
3. Insert memory stick and now you should be good
For some reason you might have to repeat these 3 steps everytime you want to access your memory stick
Hope this Helps
Apr 18, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
My laptop can't find the SSID
HI all, A couple months have passed since I posted this problem. I found my own answer after weeks of asking for help. The hawking Reg 1 repeater. Here's the answer. THE REG1 REPEATER ONLY WORKS WORKS WITH ROUTERS THAT OPERATE IN WDS MODE. Not all routers can. Check to seeif the router you are extending is capable of this mode. I tried 2 differnet routers, neither worked. Finally when I got one that spoke WDS. It worked like a dream. Why did the directions not say that!!!!!
Kayellynn
May 10, 2008 | Hawking HWREG1 Repeater
SanDisk Sansa Clip MP3 Player Logo
52 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
