Unfortunately Without the cable box you will have to screw the coax cable into the coax input on the tv or You can screw the coax cable into a vcr and then plug the Audio / Video RCA plugs from VCR out to TV RCA input (You will have to control the channels from the VCR and the volume from the TV remote)
you will need:
rf modulator.
coax cable.
video cables.
run audio cables from yourmusic source to the reciever that should work but if your music source is away from the reciever then get an rf modulator and put your music source by your reciever and the put thevideo cable from your music source to the rf modulator and tthenrun a coax cable to the tv and then run the audio cables from the music source to the input on the reciever. for example i have my direct tv box sound running through my reciever and speakers, and to have musicfrom the direct tv box going through my speakers i put the audio cables from my direct tv box into the audio input on the reciever and then the video cable into the rf modulator and then from the rf modulator i ran a coax cable to my tv then i had my sound from the direct tv box going through my reciever and the video on the tv.
plz tell me if this works :)\
Good: Connect the antenna to the converter box where it says antenna/in. Connect the coax cable to where it says to tv/out on the converter box. Connect this cable to the coax/rf input on the television. Plug in and turn on the converter box and the television. Make sure the television is on channel 3 and follow the setup process that pops up on the screen.
Better: Connect RCA cables to the converter box where the yellow red and white holes are. Connect them to an RCA input on your television. If you don't have a red hole on the television that's ok, just connect yellow and white and leave the red plug dangling. Connect the antenna to the converter box where it says antenna/in. Plug in everything and turn everything on. Press the video/input/source button until you have located the setup screen for the converter box and follow the directions on the screen.
Sounds like you may have plugged the cables in the wrong way. We have direct tv and none of ours have the three cables. it uses either a coax or an HDMI cable.
Your cable system is probably QAM (digital cable). The tuners built into the TV are analog and digital OTA tuners (ATSC and NTSC). If you connect the Cablevision box to the component video input (and connect the audio out of the box to the appropriate audio in) on the TV and an appropriate antenna to the coax (antenna) input, you will be able to swap use the tuners in the TV. (See tvfool.com for antenna types and direction or antennaweb.org for directions of the most likely stations to be received at your location. antennaweb assumes an external antenna and is conservative in the list it provides.)
I hope this helps.
Cindy Wells (please note, you probably need to get the component video cables. These have 3 RCA plugs on each end (red, green and blue). To carry the audio you need a cable with 2 RCA plugs on each end (red and white). Match the colors as you connect them.)
NO. An RF modulator and your digital-to-analog (DAC) TV converter are 2 different devices. The DAC will convert over-the-air (OTA) digital television signals from your antenna to analog NTSC format so your older analog TV can receive OTA broadcasts. The RF modulator converts base-band video (composite cable/RCA connector, or S-Video cable connector) to channel 3 or 4, so you can watch video/audio on your set. To use both the RF mod. and the DAC converter to the same TV, use an A/B switch for F-connector coax, or follow the directions for the RF modulator to make the correct connections.
There are usually two types of cables that connect to your tv-- coax and RCA. Cable usually uses the coax style, but some modern tvs don't have a coaxial input, which means they probably have RCA jacks. Therefore, you will probably have to find an RF modulator or the like that has a coax cable "Cable" input and RCA (yellow, white, and red plugs) output. These should be able to connect your tv to cable.
I hope this helps, and good luck!
Sincerely,
Der Strom
I should be channel 3 or 4. This assumes that this coax cable is coming out as a TV R.F. connection of a Dish Network Box (Satellite Receiver) intended for direct connection to an old fashioned NTSC (channels 2-13, 14-83, possibly even has cable channels depending on how old?) TV.
If this coax is the output of a coax going directly to the Satellite Dish or through what might might look to you like some kind of fancy splitter (called a Multi-Switch) the you WOULD NOT want to hook that to your old NTSC tv. The frequency is too high ... etc. etc... you would need Dish Box (as you call it) a.k.a. a Satellite receiver - with a good and active satellite card from your provider.
Had repair man come. The coax connection going to TV from receiver had went bad in the receiver. The other connectors in box worked but not the coax anymore that is why the box worked on other TV since using video and sound cables. Got new box for signing up for another 18 months with Direct TV. Didn't have to have splitter to just get Satalite so that wasn't the problem at all. Any of the splitters I had would have worked.
