Question about Skull Candy (NNTN5751) Headset
Cracked green piece that holds earpiece on skullcandy headpones
My son dropped his skullcandy headphones and broke the green piece that holds the ear piece... anyway to replace this?
  • 15 Answers
This you can warranty. they will give you 1/2 off on a new pair but at least you can get that.
Posted on Aug 10, 2009
How to open earpiece of UrbanEars Medis earbud
I have a pair of marshall minor headphones. They are essentially the same headphones, very similar design if not identical. I had a short occur just where the cable enters into the ear piece, i was devastated when this happened. they are a good pair of headphones and i didn't want to have to shell out on another pair.
To open the earpiece, i first removed the silicone ear-click thingy. if you look in the recessed space where this fits, you will notice a clear join between the two pieces of plastic. I inserted a razor blade into this join and after very little effort i managed to separate the two halves. In doing so i actually poked the back plate off as well, i did actually try to get this off but didn't trust myself enough with the razor blade to continue.
there is another layer of plastic covering the circuit board in the ear piece, which again i would attempt to remove via the recess where the silicone ear-click piece goes. i only had a short in the cable so i didn't go as far as getting to the circuit board.
the whole earpiece consists of at least four main pieces of plastic which are held together by a series of plastic pins. with a little Araldite/ strong superglue you would never know i had opened the earpiece.
i can't believe there is nothing online about fixing these headphones. it's a shame, they are good headphones which have now been saved from the bin.
Nov 14, 2012 | Urbanears Medis Earphones
After soldering, my left ear piece sounds lower than the right piece
More likely the heat from the soldering iron has damaged the earpiece speaker. The cone is plastic film.
Oct 03, 2017 | JVC Air-Cushion Headphones HA-FX66W
Whatdo i do if my skullcandy headphones dont charge?
Are these amplifing headphones or ? Most headphones use the devices power source to make the headphones work, they use very low voltage and various ohlms to make the earpieces vibrate and make sound. If they are not working try pushing the connection in all the way, or try another set of headphones to see if the problem is with the device. Sometimes we get defective headphones right out of the box, Skull Candy is usually very reliable and quality checked before shipping, but it can happen with all manufactures. Gool Luck.
Mar 15, 2011 | Audio Players & Recorders
My gi skull candy was cracked because I accidentally drop it... The two ear piece are loose already.. But the quality of the sounds is still ok... Pls help me I'm here at Singapore now
Try pressing the brackets that hold the earpiece in place, back together. This is the best I can tell you. I don't know where the crack is located at on the headphones. If you want to go this far, you can try to glue or tape the crack in place, but this is only if you want to try this. I say, if you are still getting quality sound from the headphones, then the headphones are still doing its job,
Oct 17, 2010 | Skull Candy Radio Communications
Wiring diagram for skullcandy headphones
The cat chewed my skullcandy headphone wire in two, how do I splice them. Thank you, Robin
May 17, 2010 | Audio Players & Recorders
My skullcandy earphones are busted
could be caused by the way you wrap them up the cords should never be wound tightly it causes a short and it just so happens that earphones are made of light weight wiring to make them seem to disapear when wearing them so what to do is instead of winding them when your done simply fold them loosely so to speak
Feb 25, 2010 | Skull Candy Ink'd Stereo Ear Bud...
Snapped Earpiece Off Skullcandy Hesh
Skullcandy does not sell replacement parts. but you can warranty those. they will either replace them or send you a 50% off code to use on there website.
Jun 02, 2009 | Skull Candy Hesh Stereo DJ Headphones -...
My son dropped his skullcandy headphones and cracked the green piece that holds the ear piece... anyway to replace that?
I dont think that they have replacement parts but they will give you 50% off you next pair if you warranty them. http://www.skullcandy.com/warranty-information.html
Dec 19, 2008 | Skull Candy (NNTN5751) Headset
Skull Candy (NNTN5751) Headset Logo
113 people viewed this question
Top Skull Candy Radio Communications Experts
 Grubhead
Grubhead
woodzowl307
Michael Harrier
Are you a Skull Candy Radio Communication Expert? Answer questions, earn points and help others
