Question about Endurance TF6iHRC Treadmill
Changing motors I need to change the motor on the endurance T6iHRc. This model has a spring attached to the frame of the motor and the front frame of the treadmill. I do not know how to ease the tension on the spring so I can remove the old motor and replace with the new one.
There is no method to ease the tension of the spring. I just used vice grips to grab the end of the spring and pull it out of the ringlet. I used the same method to connect the spring on the new motor.
Posted on Dec 20, 2008
How do I change the motor drive belt on a Bernina 1030?
Adjustment: The stepped pulley support/frame has two 5mm fixing screws on the lower end of the frame and a plastic screw on the upper frame end. Early models had a third screw on the upper side of the frame. By loosening the screws slightly, push the stepped pulley and frame frame toward the loosened side and then let go,...tighten the screws. The frame tension spring is generally sufficient to adjust the belt tension. However, you may want to add a little tension but do not load too tight as you can cause stress on the motor or damage the front motor shaft bearing.
If a belt is needed, you can find them from local companies dealing in bearings, pulleys and drive components, i.e. Kaman Industrial etc. If memory serves me correctly the belt type is MXL, 250mm length, 5mm wide. The outer side of the belt has information to tell you the type. If you want to find one online go to www.sdp-si.com.
http://www.sewtechnical.com/
Apr 05, 2015 | Bernina Sewing Machines
Lg tumble dryer motor assembly to frame
I need a model number waiting to help you
Feb 01, 2014 | Dryers
The motor cant run
Step 1:
see the video and fix it. God bless you
Step 2:
if the problem persist
a)test the input voltage motor, if there ARE voltage the motor need repair, see my personal TIPS for motor help.
b) adjust the output voltage board , for input voltage motor, if there ARE not , the board is faulty, need replace. see the diagram attached.
Jan 09, 2013 | Endurance T3 Treadmill
I have a model T-10 endurance treadmill when it starts to run about 10 seconds it will stop and code E-1
Unplug unit and remove motor shroud ,check upper & lower wire for solid connections , check condition of magnet on front roller to see if missing or still in place if not replace the roller. Next to the front roller, their is a speed sensor ( reed switch ) unplug the leads going to the the lower board use a multi meter to check continuity of the switch by inserting the leads into the connector and manually rotating the front roller back and forth opening and closing the reed switch if not operating properly then replace the switch.
If the above procedure did not resolve problem and still ERROR 1 then check the Motor Control Board LEDs 6 & 7 If LED 6 isn't on, change a new upper console if on then motor control board needs to be replaced if LED 7 is not on ( that a mouth full )
If LED 7 on - current overload circuit meaning too much friction between belt and deck you will need to apply good quality silicon lubricant that may be purchase @ gympart.com part# TM001
If then if the overload problem, still exists and lubrication did not the help then the belt and deck are worn and need to be replaced. Very seldom do we need to replace the Drive Motor problem is around 8% failure rate. You will get plenty warning if the motor goes out.
May 12, 2010 | Endurance T10HRC Light Treadmill
How to change the belt for a whirlpool washing machine
Hi, Whirlpool washers have a coupler instead of a belt. If you are sure yours has a belt, please send me a model # so I can look this up.
If you tip the washer against the wall and look at the motor from underneath, The pump is attached to the motor right behind the front panel and then the motor attatched to the transmission with the coupler that is 2 white plastic pieces and a black piece.
Here are the instructions on changing the coupler:
Removing the cabinet. UNPLUG the washer. There are two screws holding the control panel to the cabinet. Most models the screw are in front but, some models have the screws in back. They are on each end. Now raise the control panel up and let it rest on the hinges. Unplug the lid switch harness and locate the clips on each side (bronze in color) and release them.
Now the cabinet will lift off the frame and you can set it aside.
How to replace a coupler:
Now that the cabinet is out of the way, remove the pump from the motor and set the pump off to the side. Remove the two screws holding the clips on the motor and remove the clips. Unplug the motor harness and on some models you wil need to unplug the capacitor.
Now you will need to replace all three parts to the coupler. I use a ½” socket and a small hammer to force the coupler onto the motor and transmission shafts. Put the rubber part onto the coupler half on the transmission and then line up the post on the motor shaft with the holes on the rubber part and it should go on ok. Put the clips that hold the motor in place and plug in the harnesses.
Put the pump back on and the clips to hold it in place. Set the cabinet back on the frame. Make sure the lip on the front cabinet is under the front rail of the frame. Ease the cabinet on the frame making sure the two rear sides of the cabinet set down on the tabs of the frame.
Put the two clips back on that hold the cabinet and plug the lid switch back in. Fasten the control panel down and you are all set.
please let me know if I can assist you further.
Thanks
Vic
Jul 14, 2009 | Washing Machines
Replacing motor coupling
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 01, 2009 | Washing Machines
Kenmore 110.20722990 Sub-frame leans
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 28, 2009 | Washing Machines
Spin on whirlpool LSR5132PQ washer
Bases on a generic whirlpool top load...
There is a coupler between the motor and the transmission.When it starts to wear it will exhibit an intermittent spin and ultimately will stop altogether.
First unplug your machine.
Behind the top control panel near where it meets the top of the machine there is a philips (cross) screw on either side near the edge. Loosen this screw on either side and the control panel will slide slightly forward the flip up and back.
Under the control panel on either side is a large gold or silver spring clip. Insert a large screwdriver on the downward hook end on the lid side of the clip and lever the screwdriver backwards. this will unhook the spring clip and it can be removed. there will also be a 3 prong power connection under the control panel on the top panel that needs to be disconnected. Some machines have a large wiring coupler that should also be disconnected.
With both clips removed you will need to stand in front of the machine. If you grip just inside of the opening in the top, the whole cabinet will tilt forward to about a 45 degree angle and pulled completely away from the machine.
With the cover off you can see the white (or off white) pump in the middle at front lower portion of the machine. There are 2 spring clips which attach the pump to the motor (do not disconnect the hoses). These clips spring out of the way with a gentle levering of a screwdriver. Pull the pump slightly forward then tuck it off to the side.
You will now see the motor. There will be 2 spring clips that hold this motor to the frame. There may be 2 screws securing the clips onto the motor, remove these and gently lever the spring clips off. The motor should fall away from the frame.
The motor coupler consists of 3 parts One part attaches to the motor shaft and is white in colour there will be a rubber disk and another white part attached to the transmission shaft. This entire coupler assembly will have to be replaced(all 3 parts). The white parts can be pried off with a screwdriver.
Reassembly is the reverse of the disassembly.
Jul 29, 2008 | Whirlpool LSR5132PQ Top Load Washer
Sometimes it spins out,but not well,cloths too wet. Top load,beltless,about seven years old.
Jul 29, 2008 | Whirlpool Washing Machines
Frigidair modle fwt647ghs0 will not spin.
MOST FRONT LOADERS HAVE A SCHEMATIC DIAGRAM AND TROUBLESHOOTING GUIDE IN AN ENVELOPE ATTACHED TO THE SIDE WALL OF THE INTERIOR OF THE CABINET. REMOVE THE TOE PLATE OR BACK PANEL TO GAIN ACCESS.
IF THE MOTOR SHORTED OUT, THAT IS WHAT CAUSED THE CONTROLLER TO FAIL. BOTH PARTS WOULD HAVE TO BE REPLACED. COULD BE AN EXPENSIVE REPAIR.
Apr 04, 2008 | Frigidaire GSTF1670A Front Load Washer
Endurance TF6iHRC Treadmill Logo
77 people viewed this question
Top Endurance Exercise & Fitness Experts
Howard
Howard
Tom Chichester
Techmotionusa.com
Techmotionusa.com
Are you an Endurance Exercise and Fitnes Expert? Answer questions, earn points and help others
