Question about LG DR787T DVD Recorder
DVD player won't record full time that is programed into it
When I program dvd recorder to record a show, it will only record a few minutes and shut off
    Sergeant:
  • 226 Answers
There are two things are likely that can cause this: media and copyright protection. If you use DVD-RW or DVD-RAM, you should be able to copy shows ONE time onto the DVD. If you use DVD+RW, or DVD+R, it may issue a copy protection message just before it stops recording.
If the media is bad, it can also cause the machine to stop recording, I believe. You could put it into a PC and try erasing the contents before re-trying to use it in the DVD recorder.
tom
Posted on Jan 10, 2009
Panasonic DVD recorder dmr-ez485v displays "cannot record" on TV screen and shows code C744 on the unit...is it broken? Was recording fine yesterday...will appreciate any advice
Depending on your location, some pay TV programs may not be recordable. First make sure you are recording a free program. If problem remains, disconnect the unit from the power (wall) outlet for a minute. Digital recorders are quirky - sometimes I have had to insert a disk 3 to 5 times before it is recognized by the recorder.
Oct 28, 2013 | Televison & Video
My smilebox slide show won't record.
My creations preview great but when I press the save to DVD nothing happens, I am not saying is a smilebox problem, but It used to work just fine. I am just wanting to know what to do because I just wasted 40 bucks if I cannot burn it
Jun 21, 2012 | smilebox.com
After a timed recording the DVD is showing blank
Try to scan the DVD data into your PC using the trial version of TMPGEnc v4.0 Xpress if this can't find structure data then the recorder must have set the leadin data to show blank.
Nov 13, 2009 | Philips DVDR3380/05 DVD Recorder
I cannot program the vcr to record i just do not know how to I can play tapes or wath the disk but cannot recore
make sure the tv is on channel 3, and the vcr also on channel 3 -if trying to record from cable or satalite. then make sure tape is rewound all the way. do a test by hitting record on vcr. let it record for a few minutes. rewind it, then just hit play. Dont change any channels until you are ready to record the program of choice. After this test. And recording is successful. Rewind the tape again. And change the channel to your choice. Hit record at time of or go into menu of your vcr and set up a time to record shows.
Jan 04, 2009 | Symphonic WV806 DVD Player/VCR
Recording problem
My solution is a simple one. I set the Record Time via "TIMER REC." on your remote for 10 minutes BEFORE and AFTER my desired program time.
Now it's a simple matter to EDIT to the program content I want.
Hope this helps you!
Oct 20, 2008 | Pioneer DVR-540HX DVD Recorder/HDD...
I have a DVD recorder model no. DMR-ES35V. I was in the middle of recording a program onto a DVD when it stopped recording. There was over 3 hours worth of time left on the DVD when it stopped. I went...
If you're lucky, just turn your recorder off by unplugging for a few minutes with the disc out, turn it on and insert disc and it might read otherwise your computer dvd-rom/burner might be able to read it with the proper ripping software.
Oct 17, 2008 | Panasonic Televison & Video
Recording to dvd from sky + box
It sounds like you are catching the Macrovisiin copy protection on certain shows. I've personally never experienced this with my Panasonic unit while trying to record from television.
It is a bit weird. Have you checked their website to see if you can upgrade the firmware (internal programming) of the player?
Feb 17, 2008 | Televison & Video
Philips DVDR3450H Recorder does not record all of timed programs
When setting the record timer make sure that PDC / VPS is switched OFF.
PDC - Programme Delivery Control / VPS - Video Programming System is designed to allow for late starting or running programmes. Not all channels support PDC/VPS, so the recorder may be waiting for a PDC/VPS signal which isn't there.
Jan 17, 2008 | Philips DVDR3450H DVD Recorder/HDD...
LG DR787T DVD Recorder Logo
96 people viewed this question
Steve Allison
Steve Allison
