Question about Dayton (4LX41) Heater
Back draft through chimney
Live in center of ILL. strong winds shut cieling hung electronic ignition furnace down need chimney ideas
  • henk2845 Feb 02, 2009
    I have a similar problem with downdraft through the vent pipe of my water heater. I recently installed a continous flow gas water heater (replaced the standard 40 gal gas water heater). I now have a problem with down draft through the vent pipe. I never noticed it on the 40 gal heater, but the draft is so strong that it prevented the gas from firing. The gas nozzles on the new heater are directly underneath the vent pipe. I put in a damper and it helped somewhat, but I am afraid it is not venting enough, causing some carbon monoxide to get back into the utility room, where the heater is located. Also, the utility room is getting real cold in the winter and I can feel cold air coming down the vent pipe into the heater and into the room, despite the damper I installed. Someone mentioned that I should extend the vent pipe on the roof. How high should it be extended, if any?
    Thanks so much for your ideas.
    hnek2845
  • dwkcool May 11, 2010
    is the top of chimney high enough in the air
Added highth to the pipe chimney and a better cap on top to slow the wind
Posted on Dec 20, 2008
Cleaning gas furnance flue
Pull the hose off to the pressure switch, and measure the pressure while in a call for heat with a manometer... check the pressure switch rating & compare. Make sure you don't have any down drafts...a high wind cap might be needed. Also make sure the chimney termination is 2 foot above any pitch that is within 10 feet.
Dec 28, 2012 | Honeywell Furnace Air Pressure Switch...
We have a Bosch AQ125BNG gas water heater. The pilot goes out in the middle of taking a shower and has to be relit. We have had this problem for a couple of years, but it only happens during winter months...
The problem is excessive down draft or condensation. Air flow is important in combustion appliances. Too much airflow down the chimney can blow the pilot out. This is readily apparent when it gets cold and there is air rushing down the chimney in the winter. There may be an air leak in the room with the water heater. While there should be a combustion air supply that is sufficient, there should not be a place for the air coming down the cold chimney to go. That would eliminate the draft. Another thing is if a furnace is in the same room and does not have enough air to supply the burners. IF it is an older furnace without a combustion exhaust fan or has its own flue, the air being drawn into the furnace burners may be blowing the pilot out. Last but not least is the condensation issue. When cold water enters the tank it can cause water to condensate on the outside and drip down into the burner and put the pilot out.
Jan 29, 2018 | Bosch AquaStar Indoor Natural Gas Tankless...
Fl3 code. heater working fine when i closed last year. will not start this year. showing fl 3- does not ignite , does not do anything ..help please
3.
Spillage at A.Cold chimney A.Allow heater to operate 5 minutes to create draft action.
draft hood B. Vent pipe pitches down to chimney B. Reinstall vent pipe to pitch up from heater to chimney.
C. Blocked chimney C. Remove blockage.
D. Draft hood altered D. Install factory-provided draft hood.
E. Prefabricated chimney with incorrect cap E. Install a Nationally Recognized Testing Lab (NRTL) listed vent
http://www.jandy-downloads.com/pdfs/Lite2_LJ_IO_H0248900F.pdf
I tried to copy the FL3 write up from the chart but it screwed it up a little. Look at Page 35 of the manual for a clear copy
Jun 10, 2011 | Jandy Lite 2 Natural Gas Pilot Light...
Have a ruud achiever 90 plus furnace. the flame goes out after the igniter quits. any ideas
Problem: Your furnace will not ignite the gas to produce heat for your home. When a furnace has a bad ignitor what I see most of the time is the following sequence of operation:
1. Thermostat calls for heat. 2. Draft inducer motor starts. 3. Pressure switch attached by a small plastic or rubber tube senses the negative pressure produced by the draft inducer and closes. 4. Draft inducer runs for 30 seconds to a minute before you hear a gas hissing sound. The ignitor did not glow, the flame sensor (a small metal probe about 1/8" in diameter, with a white porcelain base) does not sense the flame, so after 8 to 10 seconds the hissing sounds stops with no ignition of gas to heat your home. Your furnace shuts down and goes into a lock out condition until you turn your power switch back off and on again. Then the sequence starts all over again with no ignition of the gas. Solution: You probably need to purchase and install a new ignitor. I would suggest that you inspect your ignitor closely for cracks. Make sure you do not touch the ignitor with your bare hands. If you do not visually see a crack, then you could have a furnace control board problem or a limit, rollout switch problem. The furnace's control board might not be supplying the voltage to the ignitor. If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning.
Nov 26, 2010 | Ruud UBHC Air Conditioner
Carrier 58sxc120 won't ignite and I get a fault code blinking light of short long short don't know what it means.
1. Thermostat calls for heat. 2. Draft inducer motor starts. 3. Pressure switch attached by a small plastic or rubber tube senses the negative pressure produced by the draft inducer and closes. 4. Draft inducer runs for 30 seconds to a minute before you hear a gas hissing sound. The ignitor did not glow, the flame sensor (a small metal probe about 1/8" in diameter, with a white porcelain base) does not sense the flame, so after 8 to 10 seconds the hissing sounds stops with no ignition of gas to heat your home. Your furnace shuts down and goes into a lock out condition until you turn your power switch back off and on again. Then the sequence starts all over again with no ignition of the gas. Solution: You probably need to purchase and install a new ignitor. I would suggest that you inspect your ignitor closely for cracks. Make sure you do not touch the ignitor with your bare hands. If you do not visually see a crack, then you could have a furnace control board problem or a limit, rollout switch problem. Please see "limits, rollout switches & furnace control boards" further down on this page. The furnace's control board might not be supplying the voltage to the ignitor. If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning.
Nov 24, 2010 | General Heating & Cooling
My goodman furnace keeps lighting for about 10 seconds than goes out lots of clicking sounds
Problem: Your furnace will not ignite the gas to produce heat for your home. When a furnace has a bad igniter what I see most of the time is the following sequence of operation:
Solution: You probably need to purchase and install a new igniter. I would suggest that you inspect your igniter closely for cracks. Make sure you do not touch the igniter with your bare hands. If you do not visually see a crack, then you could have a furnace control board problem or a limit, roll-out switch problem. The furnace's control board might not be supplying the voltage to the ignitor. If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning.
NATE, NCCER, PHCC,HVAC Certified Instructor
Oct 25, 2010 | Heating & Cooling
Furnace wont ignite
check all safety switches located at burners and draft hood its a little round disc with a button that can be pressed to reset it.if there is an inducer motor check to see if the pressure switch is being pulled in it might be weak or you might have a clogged chimney.
Mar 22, 2010 | Heating & Cooling
How does a draft inducer blower work
A draft inducer blower is used to create a proper draft in a chimney or exaust pipe from your water heater or furnace. In a high efficiency furnace or water heater, there is not enough heat expelled from the unit to the chimney to create a proper draft. The toxic carbon monoxide gas which is expelled through the chimney from your appliance is normally carried upward due to the rising hot air in the chimney. When appliances got more efficient (putting more heat into the water tank and less going out the chimney), manufacturers had to add this blower to help get the gases out the chimney since there wasn't enough hot air to create a draft.
Hope this helps.
Dec 10, 2009 | Fasco GSW Hot Water Heater Exhaust Draft...
Furnace shuts down, will not start up again
Yeup, sounds like a natural draft. A power vent system vents out the side of the house without a chimney, but because there is no draft of hot air rising up a chimney, a powered fan is used. Power vents have additional sensors that can cause the burner to shut down.
If the burner does fire but then shuts down it sounds like the flame sensing rod is not working. It is dirty or needs replacement. Are there any error codes when the burner shuts down, or an indicator lamp that shows when the controller detects a flame?
Jan 08, 2009 | Honeywell Power Humidifier: Furnace...
Dayton (4LX41) Heater Logo
292 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Craig Butler
Craig Butler
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
