Question about Philips 50P8341 50" Rear Projection Television
Projection tv is Blurry and offset
Believe it or not... i found a projection tv in the trash... it's a phillips magnavox, i cleaned out all the lenses; replaced the coolant in all lenses tv seems to work great. I bought a phillips universal remote that works allright. I adjusted the convergance until it seemed the best it could be the only problem i seem to be having now is... it seems a bit blurry, i can see blue green and a lil red offset from eachother at the top and bottom of the screen... its very noticeable on widescreen movies... i can actually see a green bend on top and bottom. the middle of the screen everything seems fine, also at the top and bottom the picture has a little bend to to it... if anyone could help me figure out how i could get this focused and sharp i would really appreciate it....
  • 1 more comment
  • toastedstrud Dec 20, 2008
    Where is this box located??
    ive messed with something like that in the back, but the top makes it brighter and the bottom makes it sharper, ive already adjusted those to the sharpest they can be....
  • toastedstrud Dec 22, 2008
    k i did that but i still see bends at the bottom and top, the middle looks fine color wise but the bottom the screen is showing the colors offset
  • Philips Master
  • 5,138 Answers
You have a focus and screen control box it has 3 controls on top 3on bottom these are the controls for Red-Green-Blue screen drives and for focus to each tube. IT should have Focus /Screen on it.
Posted on Dec 19, 2008
  • 1 more comment
  • ladywinn
    ladywinn Dec 20, 2008
    It should be either right above chassis in back of tv or in front behind speaker cover black square box with 3 controls ontop and 3on bootom 6 controls all together.
  • ladywinn
    Thats the focus/screen drive block for tubes.Turn color off ,in menu now adjusted all 3 tubes untill you have a black and white picture get as close as you can - Now ture color back up and see what kind of picture you have .
  • ladywinn
    ladywinn Dec 22, 2008
    Has the STKs been replaced in set they maybe what is causing alot of your problems. STK ics control alot of different circuits mostly convergence and will affect power depend on which one that is bad thats why you must replace both ics they are big black chips will say STK???-??? what are the numbers on your STKs?
Ptv835 phillips
It sounds like the lens fluid has gone sour. Take a look at this Fixya tip for more information on replacing the lens coolant. When it's real bad you won't be able to see the crosshairs sometimes. http://www.fixya.com/support/r11932741-convergence_repair_dull_video_repair
May 24, 2013 | Philips Magnavox 9P6034C 60" Rear...
I have a Phillips Magnavox HD Tv Rear Projection Television and the picture looks greenish and reddish and is blurry on the text of the screen? please help.
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 03, 2010 | Philips Magnavox 51MP392H Rear Projection...
I have a TV 48" PTV W/RemoteModel 6P4830W TV repair said that it
The problem is not in the bulb but in the display coolant... http://servicemanuals.vstore.ca/product_info.php/pName/phillips-crt-coolant-replacement-kit/cName/repair-kits...The step by step procedures and illustrations are included in the kit.
Sep 25, 2009 | Philips Magnavox 9P6034C 60" Rear...
3D blurry picture
The convergence ICs and resistors need replacement. The DPTV305-345 convergence repair kit works for most Phillips rear projection Tvs. The kit contains the two ICs 12 resistors and the CD with detailed instructions
http://www.tvrepairworld.com/
Jul 22, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Blurry pic. with no white
Thats the classisc symptom of a phillips which needs the CRT coolant replaced. You can get the Phillips CT coolant replacement kit at the following link which has the Coolant and the CD with complete instructions. Its listed under the Phillips Repair kit category.
Jul 13, 2009 | Philips Magnavox 9P6034C 60" Rear...
Blurry picture
You need to clean the projector lens on the optical engine using a soft cotton or, better yet, a chamois cloth. Also clean the mirror mounted inside the rear cabinet and also the front and rear of the screen itself.
If picture is still blurred then your the optical engine is most probably defective.
Dec 10, 2008 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Phillips Magnavox projection TV
you will need to change the convergence ICs both of them STK-392-120 they will cost about 15.00 each if you can solder you can do this repair yourself in a hour. A shop usually gets around 450 to do this repair. Let me know if you need further info.
Mar 11, 2008 | Philips Magnavox 9P6034C 60" Rear...
Projection tv philips magnavox 9p5031c101
power supply problem .the cherps are the power supply ossiclating and trying to produce . soon you won't even hear that
Aug 06, 2007 | Philips Magnavox 9P6034C 60" Rear...
Philips 50P8341 50" Rear Projection Television Logo
309 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
