Question about Toshiba MK4026GAX (hdd2193) 40 GB Hard Drive
Can't access drive from My Computer
Just got a Toshiba portable hdd (MK4026GAX). Connected up everything looks ok on device manager, shows as working correctly both under disk drives and usb controllers, checked for updated drivers but got the newest installed. Problem is the drive does not show on My Computer. What do i need to do to access the drive? Any help greatly appreciated (in dummy speak if poss, i'm pretty pc illiterate)
  • 64 Answers
Sometimes an additional drive doesn't show up because there is no free letter, especially if you are on a network. From Disk Management (right click on My Computer, Manage) if you see your drive there, try assigning it a letter. Or disconnect other drives that are mapped. Typically an external device wants to be "next" after your hard drive (usually c:) and CD-ROM (usually d:)
Posted on Apr 01, 2007
How do I start a manual backup with a Toshiba Convio 500GB HDD? Model number is 593400-A.
windows OS? what?
manual backup?
what are you doing? backing up data?
we can back up vast ways today.
1: to external HDD, (bingo?)
2: to DVD burner
3: to a home server
4: to the cloud or to a private FTP server (i use latter)
5: USB stick.
all you do is drag and drop files.
I looked up your model, and is an external drive."portable"
so plug it in, see it in program manager,? you must see it or its dead.
is this the first time using this device,? unstated.
if it works on other PC, then it works.
it may not on this PC if your USB ports are weak. no PC stated.
try all USB ports yet?
does it show up in disk manager, ? it must
if you have USB errors in device manager, then we fix this first.
all drivers for USB must be good on this PC
the pc must be connected to the internet or PnP will be 1/2 dead.
when you plug in any USB device, the PC goes, (bingdong) for USB going online, and then shows up in diskmanagers.
if the drive is new, you must assign drive letter to the disk in disk manager, then it needs to be formatted, if virgin disk.
ok?
Apr 17, 2018 | Toshiba Computers & Internet
Toshiba 1tb hdd external hard drive not reading
Try using HDD Regenerator to check and possibly to repair the disk. HDD Regenerator allows to repair bad sectors on damaged hard disk drives without losses of the existing data. http://ulozto.sk/xzjZ2Bd/hdd-regenerator-1-71-keygen-h33t-murtajiz-zip
Jan 11, 2013 | Toshiba (1TBEXT-HDD) (1TBEXTHDD) 1000 GB...
When I plug in the Toshiba HardDrive, it doesn't show on the drives list. I inserted it before and it showed just fine. I even stored some files inside it. but now it's not showing at all.
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this program to recover your files.
http://www.asoftech.com/adr/
Sep 27, 2011 | Toshiba E05A100PBU3XS Canvio 1TB USB 3.0...
I need to open my Toshiba Canvio portable disk.
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this file recovery program called asoftech data recovery to recover your files.
Aug 16, 2011 | Toshiba Canvio 500 GB USB 20 Portable...
My Lap top HDD is not showing up when connected to my Desk top. my siemens lap top hinges broke. I tried working with it and damaged screen. Removed HDD drive and found a free case at home with the USB...
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Jul 12, 2011 | Silver Jeans MOBILE DISK HD-234-U2P...
Can the MK4026GAX @5400 rrm be used to replace my deceased Toshiba MK3021GAS @4200 which fits into my dell inspiron 8500 using a adaptor directly into the recepticle (slide in from side & screw on...
Yes, all IDE 2.5-inch disk-drives use the same pin-out. SATA-interface disk-drives have quite-different interfaces than IDE drives, but all SATA devices share a common interface.
Nov 06, 2010 | Toshiba MK4026GAX (hdd2193) 40 GB Hard...
Hello my DVD drive will not play and will not show
Can you check whether you Disc Drive is well connected ?
to check the device :
Right click on my Computer
Select Properties
Hardware devices
Device Manage :
Check your Dvd/cd drives.. whether everything is connected.
If not try re-installing the device or to update it.
or try this
go to start
right click on my computer
click on manage
then click on storage
then click on disk management
then right click on your device and select add letters and path
window will pop up then click on add
the select an alphabet and click on ok
Hope your problem got solved. Thanks
Apr 20, 2010 | Toshiba Satellite L305-S5911 Notebook PC
Replacement hdd for a Toshiba MK4026GAX (ATA)
Any brand-new ATA hard-drive (you probably won't find any new hard-drive smaller than 80GB) will be compatible. Pay a few extra dollars for a 7200 RPM drive (rather than 4200 or 5400 RPM).
Nov 14, 2009 | Toshiba MK4026GAX (hdd2193) 40 GB Hard...
Usb port detected but i cannot access the portable hdd because there is no displayed ickon of hdd in the my computer page
Is this on a Windows system?
If so, try right-clicking the My Computer icon, and in the popup menu select Manage. This will bring up computer management, where you can go to disk management. In disk management check if you see the drive, if it has a partition and drive letter.
See here for more ideas and details.
Oct 08, 2009 | Toshiba 120GB USB 2.0 Portable External...
Toshiba MK4026GAX (hdd2193) 40 GB Hard Drive Logo
422 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
