Question about RCA HD52W59 HDTV Projection Television
What next? ok . i replaced the fly-back,cp150,cp114, cp120. the tv comes on and the screen is blue. i can't change the channel or bring up the menu. plus the tv stay on for about 2 min then goes off .what could it be . help help !!!!!!!
  • 1 more comment
  • REEOS Dec 19, 2008
    also the blue screen goes out before the green power light goes out.there is on blinking.
    I HAVE CHECKED AND FOUND NO LEAKS. HOW EVER I DID FIND A BURN SPOT. BOARD B (BLUE) cb385 , jb314 , jb33? , rb364 all is under or by the burn spot . Can these be replaced or do i need to got a new blue board?????
    I'M JUST GOING TO REPLACE THE BLUE BOARD AND HOPE THIS FIX IT. THE BLUE BOARD IS THE FIRST BOARD OF THE THREE. THANK YOU VERY MUCH. PS WERE CAN I GET THIS BLUE BOARD FROM. DID NOT HAVE TIME TO CHECK TO SEE IF THE OTHER WORKED.
  • RCA Master
  • 5,138 Answers
Check your tubes look to see if any of projection fluid is leaking,or if any has leaked onto chassis,alot of these tvs also had problem with that, also recheck second ribbon connection make sure it is in good ,they had trouble with ribbons and the connector plugs.
Posted on Dec 19, 2008
  • ladywinn
    ladywinn Dec 19, 2008
    This is probly your problem replace Blue CRT board, unplug crt board from neck of blue tube turn set on see if you have a picture then of course only green and red will light.
  • ladywinn
    Call UED they might have CRT board 1-800-648-6657 if they dont let me know will do some checking to see who else may have them.Give them your make model and chassis number when you call.
Power light will come on for about 5 sec, then turn off. I receive no picture or sound
Replace this capacitor:
cp140, cp150, cp114, cp120 ( vented).
Re-solder fly back transformer.
Any question, let me know please.
Thank you for visit fix ya
Aug 04, 2011 | RCA HD56W66 56" HDTV
Our 52 inch RCA tv Model #D52W20 will not come on when we power it on. If we keep hitting the on button it will eventually come on. When it first started it would come on in about 10 min now it takes...
Replace the CP150, CP120 and CP114 Capacitors. You can get the RCA repair kit called the ATC221 CP150, CP114 and CP120 repair kit from www.tvrepairworld.com which contains the caps for the ATC221 and ITC222 versions of your model along with the CD with repair instructions.
Apr 25, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
When i power the tv on, the green power button lights up for a second, then shuts off with no picture
sounds like the cP150, CP120 and CP114 capacitors need replacement. You can get the CP150, CP120 and CP114 repair kit from www.tvrepairworld.com the kit contains the capacitors and the CD with instructions.
Mar 02, 2011 | RCA HD52W59 HDTV Projection Television
When we turn the tv on in blinks the green light 3 times and never turns on. what is wrong with it?
Feb 26, 2011 | RCA R52WH73 Projection Television
Television has a hard time coming on. power button comes on and off. takes forever for tv to come on
Thats most likely caused by bad caps CP150, CP120 and CP114 on the deflection / Power board. You can get the cp150, CP120 and CP114 repair kit from www.tvrepairworld.com which contains the capacitors and the CD with repair instructions.
Jul 18, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a RCA R56wh78 projection power button flashing green.
Thats the classisc sign that the CP150, CP114 and CP120 capacitors need replacement. You can get the repair kit called CP150, CP120 and CP114 at www.tvrepairworld.com which contains the capacitors and the CD with step by step instructions on how to do the repair.
Dec 04, 2009 | RCA HD52W56 52" Rear Projection HDTV
Tv power light comes on & off 3 times but the tv wont come on, tv repairman said the filters needed to be replaced he said there was too much noise for the signal to get thru
On your deflection board there is 3 capacitors cp150 cp114 cp120--------cp150 2200uf 16v cp114&120 will be 220uf 35v if cp150 is puffed up on top it is bad ,you will need to replace all 3 caps.
Apr 02, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
61" RCA Projection TV Model #: d61w20
You could have shorted Yoke and if so you have to replace all 3 yokes another thing that can cause this is Capacitors on Deflection board cp150,cp114,cp120 If cp150 2200uf 16v is puffed up on top then it is bad ,so replace all 3 caps other 2 are 220uf 35v.
Jan 02, 2009 | RCA D61W20 61" Rear Projection Television
Tv wont come on
There is 3 capacitors on Deflection board cp150 2200uf 16v look to see if it is puffed up on top if so it is bad so replace other 2 caps cp114 and cp120 220uf 35v they are green with gold writing on them.
Dec 26, 2008 | RCA HD52W66 Projection Television
RCA HD52W59 HDTV Projection Television Logo
54 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
