Question about Soyo Computers & Internet
RE: soyo topaz s. I need to adjust the brightness
First the monitor showed bright yellow. So I pulled the plugs and rebooted. Now the greyed print is very light and some of the colors seem dim. I can adjust the contrast and it is ok but can't seem to get to the brightness to lower it down a bit. The buttons on the side of the screen are "Menu, +, -, vol,mode, and Auto".
The Auto doesn't seem to do anything. The Mode, bring up a box the says "HIGHLIGHT." Full,Half, Window, Off. I can't seem to navigate to these titles.
SOURCE: Acer AL1715 - insufficient brightness
No there isn't any. there is probably a part that is damaged due to the surge u should get a new one or send it back to the company
Posted on Feb 02, 2008
SOURCE: Samsung 220wm monitor brightness and contrast adjustment
umm... you are NOT supposed to use mouse !!
These are on-screen displays and you can use the other buttons (up down and select) to navigate through and then to change the values !
Posted on Feb 23, 2008
jemmyrash
  • 180 Answers
SOURCE: Samsung 19" monitor control problems
Your logic board need to service.
Posted on Apr 20, 2008
SOURCE: Dell 15 inch monitor, brightness/contrast window
Press and hold the + button, You will get a message that the monitor is going into auto adjust. After that problem solved.
Posted on Jan 19, 2009
myjosh007
  • 530 Answers
SOURCE: Contrast and Brightness require adjustment
hi im josh in cebu phils. Maureen may i help you? If it happened yesterday that the contrast box keep on coming. there's a problem in your monitor.so try to check the buttons if covered with dust cleaning may solved the problem.Maureen if you have the manual use it in adjusting the resolution and if you dont have try to press the button mark + or increase just press both of the to the brightnest as posible so that you may be able to proceed another action. thats all for now.hope i helped you.good luck.
Posted on Feb 26, 2009
Sunlight prevents me from seeing my monitor
If you mean the LCD display on the back of the camera you can adjust the brightness in the camera menu. Press the menu button, move to the yellow spanner with 2 dots top right, below this you'll see LCD brightness, highlight this and press set you'll then go to another screen showing a scale 1 to 7 use the left / right button to move the pointer closer to 7 to increase the screen brightness.
May 19, 2014 | Canon EOS 600D Rebel T3i Digital Camera
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
Unable to reduce brightness windows7 ultimate hp1670
laptop ot desktop monitor ?
Adjust your monitor's brightness and contrast
Brightness and contrast symbols
Laptop display. Laptop displays don't have brightness or contrast buttons on the front.
For a majority of laptops, there isn't a control for setting the contrast.
However, you can set the brightness of many laptops by pressing and holding the Fn key, and then pressing a function key to decrease brightness ( ) or increase brightness ( ).
http://windows.microsoft.com/en-US/windows7/Calibrate-your-display#
When using Display Color Calibration on a laptop, set the display to the maximum brightness setting.
Adjusting brightness automatically using adaptive brightness
Adaptive brightness is a feature in Windows that uses a light sensor to automatically adjust the display brightness to match the lighting conditions in your computer's surroundings.
To use adaptive brightness, you must have light sensors installed and enabled on your computer.
To determine if your laptop or computer monitor supports adaptive brightness, look for the Enable adaptive brightness setting in Power Options (mentioned in the following procedure) or check the information that came with your computer.
To turn adaptive brightness on or off
Open Power Options by clicking the Start button , clicking Control Panel, clicking System and Security, and then clicking Power Options.
Under any plan, click Change plan settings.
Click Change advanced power settings.
In the list, expand Display, and then expand Enable adaptive brightness.
To turn adaptive brightness on or off when your computer is running on battery power, click On battery, and then, in the list, click On or Off.
To turn adaptive brightness on or off when your computer is plugged into an outlet, click Plugged in, and then, in the list, click On or Off.
Click Apply. Click OK.
hope this helps
Jul 26, 2012 | HP...
Viewsonic VA902b too bright. menu control greyed out
open the monitor draw the screw and there is a big black part called E.H.T.to which has preset to rotate it with screwdriver in on condition of monitor untill sufficient brightness will come
Mar 09, 2010 | Computers & Internet
MONITOR VT17N71, SN C0542C0739 I CANNOT GET THE RESOLUTION THAT I THINK THE SCREEN SHOULD HAVE. I'VE TRIED ADJUSTING THE BRIGHTNESS...BUT IT'S ALWAYS TOO BRIGHT. I'VE TRIED ADJUSTING THE CONTRAST,...
Hi.
Just a general suggestion.
Are the graphics drivers loaded.
(Assuming you are using Windows) what happens when you rightclick on the desktop screen and you click on the Settings Tab
Jan 06, 2010 | Soyo Computers & Internet
I do drawings in Autocad and Photoshop on my 24" soyo topaz s
to adjust the setting on your monitor follow this steps:
right click on the desktop-properties-click Settings Tab-here you find the Screen Resolution then you can adjust it how you want then click Apply and you're done.
Dec 15, 2009 | Soyo MT-NI-DYLM2058 Monitor
Very dark screen
Hi yes it looks like the inverter has failed and will need replacing, or if your compitent enough you can fix it at board level. The usual suspecs are a small SMD fuse on the inverter board / power supply board and/or buldging capacitors which look like blue or black cans.
hope this helps.
jonno
Feb 10, 2009 | Soyo 19" LCD Flat Panel Monitor
Grey screen
Are you able to adjust the contrast or brightness? Try to turn them down to about 50%.
Jan 08, 2008 | HP f1905 19" Flat Panel LCD Monitor
CRT monitor too bright
I have/had same problem. I have ATI Radeon display adapter and in driver settings there was adjustment for brightness. I adjusted that to minimum and now the brightness is pretty good (still little bit too bright, monitor setting 0%). Other succestions welcome...
Sep 28, 2006 | Keytec Sony Multiscan E500 21 in. CRT...
Computers & Internet Logo
Top Soyo Computers & Internet Experts
Roy May
Marvin
Marvin
David
David
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
