Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Side side door noise(fridge side door)
Whenever you open the right side (fridge side of side by side) 100% it makes a clunk and if look at the bottem of door where it rotates around a shaft you can see a spacer or gasket that moves at the same time of noise . The gasket or spacer jerks and noise happens at the same time? can i replace the spacer / gasket? ? do i remove something at top and just pick the door up?
thanks
sonny
Is This country Great or What
  • 71 Answers
You need the lower hinge and cam kit. remeve the top hinge then lift the door off the hinge and replace the hinge and the cam on the door.
Posted on Dec 19, 2008
My GE Adora side by side makes ice but the water dispenser barely dispenses.
Did you recently move the fridge? One possibility is that the supply line in the back of the fridge is kinked. Usually it is coiled so you can move the fridge out and back damage but if it gets kinked, it would limit the water supply like a hose does when kinked. Also, the supply line is usually tapped from under the sink. Make sure the valve that supplies the line (usually 1/4 inch line) is fully opened. If that fails to help, then you're back to the solenoid valve for water that is not fully opening. Should give a solid clunk when actuated. G
Jan 27, 2014 | GE Adora (DSF25KGTBG) Side by Side...
Its a Double French doors pull out freezer on bottom, model number GFSS6KKYSS..my brother has plugged it back in after defrosting all the ice and we can't hear the fan, apparently not working yet? Is this...
On a regular fridge there is a timer located at the back of the fridge that activates the auto defrost on and off during a predetermined cycle. The timer provides power to an electrical heater (black cable) curled around the freezing elements, this action defrosts the cooler. This timer has an unusual rotating shaft on which a screw driver is used to rotate it and it is designed that rotation can only be in one direction. Look at the rear of your fridge and try to locate this timer, it is normaly mounted on the edge of a side panel near the coils.
Once you have located it , use a screw driver that fits the groove of the rotating shaft and rotate it in the allowed direction (as you can only turn it in one direction) the fan should the run, if not, slowly continue rotation 360 degrees and until it does . IT IS POSSIBLE THE TIMER IS DEFECTIVE...REPLACE IT WITH IDENTICAL TYPE AND MODEL. This should be the cure to your problem. Good luck.
jam
Oct 10, 2017 | GE GFSS6KKYSS (259 cu ft) Bottom Freezer...
Fridge door squeaks, freezer door bumps
Slacken the three screws, align the door and tighten the screws up again. Try not to lean on the door when it's open.
Apr 21, 2012 | Refrigerators
I think I have a water problem? I hear a clunking noise at various times from I think the right bottom of the unit. Water and Ice seem to be working fine.
Hi.
The clunking noise is the compressor. It usually means that one of the internal mounts that secure the compressor motor is gone. The whole compressor needs replacement.
First ensure that the fridge is at level. A not well leveled unit's compressor can make noise.
If fridge level is OK, call the Whirlpool customer service number listed on manual. The compressor has a long warranty. If the fridge is the one in question you may still be covered for the part.
Regards.
Ginko.
Mar 23, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
GE TFS28PB Lower Hinge on Fridge door defective.
you have to get cam closure part # wr2x9246 and door stopper wr2x9247
Apr 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge door clunks
could not find part # for you...but there is of most doors on hinge a white plastic pad with "bumps" ...its a two part, they were out...easy to fix with someone help holding door..took me 2 minutes
Mar 18, 2009 | Whirlpool ES5LHAXS Side by Side...
Water dispenser makes cluking sound
I set fire to my house and claimed the fridge on insurance.
however I was uninsured and now require financial assistance.
please send
1. $2950 so i can buy a new fridge
2. $0.05 if you are concerned about my mental health
3. an insult if i am wasting your time.
rgds..John
Jan 07, 2009 | Whirlpool ED2FHEXN Side by Side...
Loud noise
First, UNPLUG YOUR DRYER! Now open the dryer door and remove the 2 screws at the door hinges... remove the door and set aside, then remove the 2 screws opposite the hinges. Grasp the front panel near the top, just below the top panel and pull it toward you... do this on both sides. Tilt the panel forward then lift it off of the lower clips.
With the front panel gone, you'll see a 5/16" screw just below the top panel on both sides, top left and right. Remove these and the clips too... now you can lift the top panel like the hood of your car.
To gain further access, remove the 6 (3 on each side) screws holding the front drum support/blower vent panel, then set this aside.
If you want to remove the drum... first, take a flashlight and look closely at how the belt is routed around the idler pulley and the motor shaft. (You'll have to re-route it for reassembly.) Reach in there with both hands, with one hand rotate the spring loaded idler pulley back to release tension off the belt, then with the other hand remove the belt from the motor shaft. Now lift and pull the drum out the front of the cabinet.
Check to make sure the rollers in the back rotate freely. You can remove the rollers, buff the roller shafts with emery cloth, lube the shaft with light oil (like sewing machine oil) and reinstall the rollers. Lube the idler pulley also. Rotate the motor by hand and listen for the squeak you described.
Also check the front drum support panel you removed earlier. The drum rides on this as it rotates... As you are looking at the drum support from the drum side, inspect the 10 o'clock to the 2 o'clock area closely. If the glides (teflon) are worn it'll squeak when it rotates.
Hope this helps. Oh yeah! Almost forgot.... the belt won't squeak at all. It'll be the motor, rollers or drum glides.
Nov 02, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
198 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
